T0005204
T0005204
    TEKTELIC
    4G/3G DHCP,LoRa,LoRaWAN 网关 以太网,RJ-45
T0005204 数据手册
KONA Micro IoT Gateway Enterprise LoRaWAN® Gateway for Mission Critical Deployments The KONA Micro IoT Gateway is designed for enterprise and lightweight industrial applications that require “Always On” connectivity. Configured with an internal 3G/4G modem and a built-in battery backup, the KONA Micro IoT gateway continues to operate and transmits sensor data to the network even when the main site has lost power. Simple to configure and cost effective, it is an ideal hub for deployment of enterprise-level applications in areas where LoRaWAN® coverage is not yet readily available or for private networks where the operator requires unfettered access to the gateways regardless of their deployment location. Key Features Key Product Differentiators Enable critical enterprise IoT applications with ‘Always On’ connectivity. Battery backup and an integrated 3G/4G modem. NA 915, EU868, AUS923, JP920 ISM Bands Reduce set up costs with plug-n-play installation using a custom provisioned factory image. Time Duplex 8 Rx / 1 Tx Four Hour Battery Backup Integrated Cellular 3G/4G Modem Improve coverage and service resulting in increased IoT application adoption and customer satisfaction. External LoRa Antenna Simplify management with the KonaFT OAM tool. Operational Status LED Operational status indicated with multi-function LED. 27 dBM Tx Power Fully integrated with the broader eco-system of LoRa™ network servers and sensors. Plug - n - Play Operation Factory Image for Mass Deployment In-Service Updates INFO@TEKTELIC.COM +1.403.338.6900 WWW.TEKTELIC.COM KONA Micro IoT Gateway Enterprise LoRaWAN® Gateway for Mission Critical Deployments Technical and Functional System Specifications Mechanical Parameters LoRa Radio Parameters MTBF 830,000 hours ISM Bands NA915, EU868, AS923, JP920, CH779 DC Power Consumption
T0005204 价格&库存
很抱歉,暂时无法提供与“T0005204”相匹配的价格&库存,您可以联系我们找货
