T0006115-EU
T0006115-EU
    TEKTELIC
    智能房间传感器 传感器 LoRa,LoRaWAN 输出
T0006115-EU 数据手册
KONA Smart Room Sensor LoRaWAN® connected Home and Office Environment Monitoring The KONA Smart Room Sensor integrates practical functionality into a very small form factor. The Smart Room Sensor is an ideal solution for holistically monitoring the home and office environment. The device is capable of measuring and reporting temperature, humidity, light, movement, motion, shock, detecting leaks, open / closed doors and windows. It also supports battery status updates for easy maintenance. The sensor is optimized for long battery life and excellent wireless performance. It is fully configurable over-the-air by the user for custom applications, behaviours, thresholds, trigger events and reports, enabling it to support many different Smart Home and Office IoT applications. The Smart Room Sensor is available in two packaging options (Base variant and PIR variant). Features Applications User Configurable Parameters and Thresholds Movement Detect (Doors, Windows, Drawers) Designed for Optimal Battery Life G-Force Measurement (Settable Trigger) Multiple PIR Masking Options Motion Detection (PIR) Long Battery Life On / Off External Contact Wall, Ceiling or Table Mount Configurations On / Off Internal Magnetic Switch Simple Deployment Pulse Reading (Water, Gas, other metering) Sleek and Unobstructed Design Light Detection (On / Off) Temperature Measurement 42 mm 17 mm Humidity Measurement Moisture / Leak Detection Available SKU’s (Digi-Key) 42 mm INFO@TEKTELIC.COM +1.403.338.6900 T-Code Region Type T0006115 North America Smart Room Sensor Base T0006116 North America Smart Room Sensor PIR T0006117 Europe Smart Room Sensor Base T0006118 Europe Smart Room Sensor PIR WWW.TEKTELIC.COM KONA Smart Room Sensor LoRaWAN® connected Home and Office Environment Monitoring Technical and Functional System Specifications General System Parameters Optimized Battery Life (Years) - CR2477 Operational Temperature 0°C to 60°C (10°C to 40°C optimal) Operational Temperature 20°C Storage Temperature -30°C to 60°C (0°C to 30°C optimal) Tx Power 14 dBm Relative Humidity- 5% - 95% Non-Condensing Rx Cycle/Hour 1 Ingress Protection IP30 Size 42 x 42 x 17 mm (enclosure) Operational (Operational) Variant Transmission SF 10 125 kHz SF 7 125 kHz SF 8 500 kHz 42 x 42 x 20 mm (with bracket) 4 packets / hour 4.8 11.2 13.0 Weight (including batteries) 25g 3 packets / hour 5.9 12.5 14.1 Battery CR2477 2 packets / hour 7.8 14.1 15.5 External Connector (Base Variant) Connector Type: JST A02ZR02ZR28H305B 1 packets / hour 11.0 16.3 17.1 ≤ 20Hz (Pulse Reading) 1 packets / day 18.5 19.0 19.1 Driven by open drain/relay contact 4 packets / hour 2.2 4.0 4.4 3 packets / hour 2.5 4.3 4.6 2 packets / hour 3.0 4.6 5.0 Base Wireless Parameters PIR RF Power 15 dBm 1 packets / hour 4.0 5.1 5.3 RF Sensitivity up to -137dBm 1 packets / day 5.5 5.5 5.6 LoRa Radio SX1261 Supported ISM Bands NA915, EU868, EU433, AU915, AS923 PIR Detection Range (Wall Mount) CN470, CN779, IN865, KR920, RU864 X Angle 70° Antenna Internal Y Angle 20° LoRa Device Class A Z Range 5m Sensor Variants Sensor Function PIR Detection Range (Ceiling Mount) X Angle 70° Motion Detection (PIR) Y Angle 84° External Connector Height 3m (Pulse Reading) Moisture/Leak Detection Accelerometer PIR Variant Base Variant * Assumes object in center of field of view Regulatory Compliance G-Force Measurement Safety IEC 60950-1 (CE) On/Off External Contact Regulatory ETSI EN 300 220 Light Detection Temperature Humidity ETSI EN 301-489-1/-3 FCC 15.247 FCC 15.209 Specifications subject to change without notice. TEKTELIC Communications is a premier supplier of best-in-class LoRaWAN® IoT Gateways, Sensors, and custom applications. These elements combined provide a powerful end-to-end solution that can be easily, quickly, and cost effectively deployed to address the most demanding IoT challenges. For more information please visit www.tektelic.com
T0006115-EU 价格&库存
很抱歉,暂时无法提供与“T0006115-EU”相匹配的价格&库存,您可以联系我们找货
T0006115-EU
  • 1+741.493981+95.92357
库存:2
