KONA Smart Room Sensor
LoRaWAN® connected Home and Office Environment Monitoring
The KONA Smart Room Sensor integrates practical
functionality into a very small form factor. The Smart
Room Sensor is an ideal solution for holistically
monitoring the home and office environment. The
device is capable of measuring and reporting
temperature, humidity, light, movement, motion,
shock, detecting leaks, open / closed doors and
windows. It also supports battery status updates for
easy maintenance.
The sensor is optimized for long battery life and
excellent wireless performance. It is fully configurable
over-the-air by the user for custom applications,
behaviours, thresholds, trigger events and reports,
enabling it to support many different Smart Home
and Office IoT applications. The Smart Room Sensor is
available in two packaging options (Base variant and
PIR variant).
Features
Applications
User Configurable Parameters and Thresholds
Movement Detect (Doors, Windows, Drawers)
Designed for Optimal Battery Life
G-Force Measurement (Settable Trigger)
Multiple PIR Masking Options
Motion Detection (PIR)
Long Battery Life
On / Off External Contact
Wall, Ceiling or Table Mount Configurations
On / Off Internal Magnetic Switch
Simple Deployment
Pulse Reading (Water, Gas, other metering)
Sleek and Unobstructed Design
Light Detection (On / Off)
Temperature Measurement
42 mm
17 mm
Humidity Measurement
Moisture / Leak Detection
Available SKU’s (Digi-Key)
42 mm
INFO@TEKTELIC.COM
+1.403.338.6900
T-Code
Region
Type
T0006115
North America
Smart Room Sensor Base
T0006116
North America
Smart Room Sensor PIR
T0006117
Europe
T0006118
Europe
WWW.TEKTELIC.COM
Technical and Functional System Specifications
General System Parameters
Optimized Battery Life (Years) - CR2477
Operational Temperature
0°C to 60°C (10°C to 40°C optimal)
20°C
Storage Temperature
-30°C to 60°C (0°C to 30°C optimal)
Tx Power
14 dBm
Relative Humidity-
5% - 95% Non-Condensing
Rx Cycle/Hour
1
Ingress Protection
IP30
Size
42 x 42 x 17 mm (enclosure)
Operational
(Operational)
Variant
Transmission
SF 10
125 kHz
SF 7
125 kHz
SF 8
500 kHz
42 x 42 x 20 mm (with bracket)
4 packets / hour
4.8
11.2
13.0
Weight (including batteries)
25g
3 packets / hour
5.9
12.5
14.1
Battery
CR2477
2 packets / hour
7.8
14.1
15.5
External Connector
(Base Variant)
Connector Type: JST A02ZR02ZR28H305B
1 packets / hour
11.0
16.3
17.1
≤ 20Hz (Pulse Reading)
1 packets / day
18.5
19.0
19.1
Driven by open drain/relay contact
4 packets / hour
2.2
4.0
4.4
3 packets / hour
2.5
4.3
4.6
2 packets / hour
3.0
4.6
5.0
Base
Wireless Parameters
PIR
RF Power
15 dBm
1 packets / hour
4.0
5.1
5.3
RF Sensitivity
up to -137dBm
1 packets / day
5.5
5.5
5.6
LoRa Radio
SX1261
Supported ISM Bands
NA915, EU868, EU433, AU915, AS923
PIR Detection Range (Wall Mount)
CN470, CN779, IN865, KR920, RU864
X Angle
70°
Antenna
Internal
Y Angle
20°
LoRa Device Class
A
Z Range
5m
Sensor Variants
Sensor Function
PIR Detection Range (Ceiling Mount)
X Angle
70°
Y Angle
84°
External Connector
Height
3m
(Pulse Reading)
Moisture/Leak Detection
Accelerometer
PIR Variant
Base Variant
* Assumes object in center of field of view
Regulatory Compliance
G-Force Measurement
Safety
IEC 60950-1 (CE)
On/Off External Contact
Regulatory
ETSI EN 300 220
Light Detection
Temperature
Humidity
ETSI EN 301-489-1/-3
FCC 15.247
FCC 15.209
Specifications subject to change without notice.
TEKTELIC Communications is a premier supplier of best-in-class LoRaWAN® IoT Gateways, Sensors, and custom applications. These
elements combined provide a powerful end-to-end solution that can be easily, quickly, and cost effectively deployed to address the most
demanding IoT challenges.
For more information please visit www.tektelic.com
很抱歉,暂时无法提供与“T0006116-EU”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+794.459361+102.77545
