T0005315
T0005315
    TEKTELIC
    LORA RF CABLE NM TO NF 2M
T0005315 数据手册
RF Superflex Cable Technical Data Sheet Connecter Type Cable Type Description N/N 1/2” super cable N Male/N Female for YD9 Cable Assembly All dimensions are in mm Jumper Length (mm) Tolerances (mm) Part Number Insertion Loss VSWR 1000 ± 10 T0005196 ≤0.34dB(@900MHz) ≤1.2(DC to 3000MHz) 2000 ± 20 T0005315 ≤0.44dB(@900MHz) ≤1.2(DC to 3000MHz) 3000 ± 30 T0005316 ≤0.54dB(@900MHz) ≤1.2(DC to 3000MHz) 4000 ± 40 Custom Order Only ≤0.64dB(@900MHz) ≤1.2(DC to 3000MHz) 5000 ± 50 Custom Order Only ≤0.74dB(@900MHz) ≤1.2(DC to 3000MHz) Parts Connector 1 N Male Connector Center contact Brass (Ag plating) Outer contact Brass (CuSnZn plating) Fastener Brass (Ni plating) Dielectric PTFE Gasket Silicon Rubber Release Date Version 1.0 Center contact Bronze (Ag plating) Outer contact Brass (CuSnZn plating) Release Date: Dec. 17, 2019 Version: 1.0 Dielectric PTFE Cable 1/2” super cable Molding Black PE Marking label Wrap stick type Documents Connector specification IEC 61169-16 Electrical data Impedance 50 Ω Frequency DC to 3 GHz Insulation resistance ≥ 5000 MΩ Dielectric Strength 2000 V AC,1Min PIM (@900MHz、1800MHz; 2×20W) ≤-150 dBc (2 x 43 dBm) Mechanical data Max. tensile strength 300N Environmental data Temperature range -45 °C to +85 °C Change of temperature IEC 60068-2-14/GB/T 2423.22 Salt mist IEC 60068-2-11/GB/T 2423.17(48h) Vibration IEC 60068-2-6/GB/T 2423.10 Shock IEC 60068-2-27/GB/T 2423.5 Damp heat, steady state IEC 60068-2-3/GB/T 2423.3 Protection class IEC 60529/GB 4208 Suitable cables 1/2 super cable (YD9 cable) Release Date: Dec. 17, 2019 Version: 1.0
T0005315 价格&库存
很抱歉,暂时无法提供与“T0005315”相匹配的价格&库存,您可以联系我们找货
