501
501
    TEMPOCOMMUNICATIONS
    电缆,管道 定位器
501 数据手册
501 TRACKER II CABLE LOCATOR TRACE & DETERMINE THE DEPTH OF WIRES & METALLIC PIPES TESTING | TROUBLESHOOTING | ACCURACY Product Features: The Tracker II offers three methods of connection to fit every location job. Direct connection for maximum signal, inductive coupling for “live” cable and an internal inductive antenna for buried and inaccessible cables. The lightweight receiver provides both audible and visual indications of signal strength for accurate identification. VERSATILE Direct connection plus clamp or inductive transmitter connection allows use on “live” cables PRECISE Adjustable transmitter and receiver sensitivity for maximum accuracy Renewed Vision. Innovation Forward. FAST Estimate the depth of cable in seconds IRRIGATION TOOLS With its inductive signal application, the Tracker II can be used on active or dead systems. Now you can trace the path and determine the depth of wires and metallic pipes without having to deactivate the systems. High frequency transmitter provides range up to 4000 feet (1219 m) and depths to 7 feet (2 m). INCLUDED ACCESSORIES: • • • • • 501T Transmitter 501R Receiver 500CA Carrying Case with Inductive Antenna CS16 Cord Set IC-1 Inductive Coupler Specifications: Order Information: POWER SOURCE CAT. NO. Transmitter: Eight “AA” batteries Receiver: One 9V battery Battery Life: Transmitter 30 hours, receiver 10 hours nominal 447.5KHz Transmitter Frequency: 447.5KHz Transmitter Power: 40Vp-p (140mW) maximum Voltage Protection: 240VAC, 500VDC Automatic Shut-off: 90 min. transmitter & receiver DESCRIPTION 501 Tracker II HS-1 Headset for 501 CONSTRUCTION Transmitter/Receiver: Powder coated aluminum Case: Vacuum formed polyethylene DIMENSIONS Transmitter: 4.25 x 3 x 3.25” Receiver: 32 x 2.75 x 4” Case: 33.5 x 8.25 x 3.75” Weight: 6.7 lbs. (complete kit) 1390 Aspen Way Vista, CA • 92081 TC6857  02/20 Latin America Phone : 1.760.510.0558 | EMEA Phone: +44 (0) 1633 927050 ©2020 Tempo Communications Inc. • An ISO 9001 Company EMEA Address: Tempo Europe Limited Brecon House, William Brown Close, Cwmbran • NP44 3AB, UK TempoCom.com | tel 800.642.2155 Renewed Vision. Innovation Forward. Follow us on Social Media @TempoComms
很抱歉,暂时无法提供与“501”相匹配的价格&库存,您可以联系我们找货
    • 1+8121.957261+1052.76030
