B0492
B0492
    TERASIC(友晶科技)
    - 电源
B0492 数据手册
EDACPOWER Electronic Co., Ltd. Description : Switching Power Supply 1-0. General Description The purpose of the document is to specify a Single phase AC input, single output switching power supply. This specification is suitable for: EA11003A Series This product is AC to DC switching power transfer device, it can provide for a 12V, 7.5A max & 90W max DC output with constant voltage source. This Specification defines the input, output, performance characteristics, environment, noise and safety requirement for a power supply. 2-0. Input Requirements 2-1. Input Voltage Rated Voltage 100-240 Vac +/- 10% full range. Normal line input 115Vac/60Hz,220Vac/50Hz. 2-2. Input Frequency 47~63 Hz 2-3. Input Current a. 2.5A (Max.) @ 115Vac input with full load. b. 1.25A(Max.) @ 230Vac input with full load. 2-4. Efficiency(Out put voltage >6V) (Warm up 30 minutes) □ Nameplate Output Power 0 to ≦ 1 Watt Energy Star Spec ≧0.48 * Pno+ 0.14 □ >1 ≦ 50 Watts ≧〔0.0626 * Ln(Pno)〕+ 0.622 ■ >50 to 250 Watts ≧ 0.87 ≧ 87% (avg.) @ Normal input & 25% , 50% , 75% , 100% of max output load. Meet CEC Level V requirement or Eup Step 2. 2-5. Configuration 3-wire AC input (Line ,Neutral, FG) 2-6. Input Fuse The hot line side of the input shall have a fuse, rating (3.15A/250V) 2-7. Inrush Current ≦ 50A at 110 Vac ≦ 100A at 220 Vac At cold start, maximum load. EDACPOWER Electronic Co., Ltd. Description : Switching Power Supply 2-8. Line Regulation This line regulation is less than ± 1%, of rated output voltage @ full load . 2-9. Hold Up Time ≧ 10 mSec., @ Normal line, with full load. 2-10. Rise Time ≦50 mSec., @ 115V AC input, with full load. From 10% to 90% of output voltage. 2-11. Turn-ON Time The output voltage should rise to 90% of rated output voltage in less than 3 SEC. from AC apply to 110Vac start up. 2-12. Harmonic Standard and Power Factor The adapter complied with IEC 61000-3-2 class D harmonic standard while input power over than 75W. The P.F. shall >0.95 @100Vac input and >0.9 @240Vac input. 2-13. No Load Power Consumption. Less than ≦ 0.5 Watts., @ 230Vac / 50Hz. Meet CEC Level V Requirement. 3-0. Output Requirements 3-1. Output Voltage and Current Output Voltage (Vdc) Current Min.(A) Current Max.(A) +12V 0 7.5A 3-2. Load Regulation Voltage (Vdc) Tolerance (%) +12V +5/, -5 3-3. Dynamic Load Regulation ±5% excursion for 50% - 100% or 100% - 50% load change of DC output at any frequency up to 1KHz(duty 50%) EDACPOWER Electronic Co., Ltd. Description : Switching Power Supply 3-4. Ripple & Noise The power supply shall not exceed the following limits on the indicated voltage for 60Hz or 50Hz ripple, Switching frequency ripple and noise and dynamic load variations measured with a 20MHz bandwidth Output Ripple/Noise +12V 2.0% max. of rated output voltage Input condition : for rated voltage , Output condition : for max load Ripple / Noise: 60Hz ripple + switching ripple and noise Ripple & Noise are measured at the end of output cable which are added a 0.1uF ceramic capacitor and a 47uF electrolytic capacitor 3-5. Over Voltage Protection 150% Max. of rated voltage. The output voltage shall be shutdown and latched when OVP occurred. 3-6. Over Current Protection 110~150% of rated output current. The adapter can withstand continuous short at DC output and no damage. It will enter into normal condition if the fault condition is removed. 3-7. Stability 2% Max. at constant load with constant input (after 30 minutes of operation). 3-8.Temperature Rise Less than 45℃ on top/bottom case at normal AC input & 80% load of DC output at environment temperature 25℃. 3-9. Drop-out (Power Line Disturbance) Output voltage shall remain within the specified regulation range, through the absence of a line input during 1/2 cycle, at full load and normal AC line input 3-10. Voltage Isolation The DC ground will be isolated from the AC neutral and AC line. EDACPOWER Electronic Co., Ltd. Description : Switching Power Supply 4-0.Reliability 4-1. MTBF ( MIL-HDBK-217F) The power supply shall be designed and produced to have a mean time between failures (MTBF) of 50,000 operating hours at 90% confidence-level while operating under the following conditions. Test condition : Input: 220Vac 45 minutes on , 15 minutes off Output: 80% of rated load Temperature : 40 +/- 5 ℃ Quantity : 45 pcs Result : without failure after 30 days burn-in 5-0. Environment 5-1 Temperature a. Operating : 0 to 40 ℃ b. Storage : -20 to 85 ℃ 5-2 Humidity a. Operating : 10 to 90 % b. Storage: 5 to 90 % 5-3 Altitude From sea level to 2,000 Meter ( operation ) and 5,000 Meter ( non operation ) 6-0. Safety 6-1. Hi-Pot Test 4242 Vdc 5mA 3 Sec. between primary and secondary circuit 6-2. Insulation Test 500Vdc, 3 Sec. between primary and secondary circuit IR should ≧ 50 MΩ. 6-3. Leakage Current ≦ 500 uA, at 240Vac/50 Hz 6-4. Safety UL, CUL, TUV/GS, CE, FCC, EK, DOIR+C-TICK, CCC, PSE, BSMI, NOM EDACPOWER Electronic Co., Ltd. Description : Switching Power Supply 6-5. EMS Items Specification Reference Contact: ± 4KV ESD IEC 61000-4-2 Air: ± 8KV RS Frequency: 1KHz Field Strength: 3V/M IEC 61000-4-3 EFT 1.0 KV on input AC power ports. IEC 61000-4-4 Line to Line: ± 1KV (peak) SURGE IEC 61000-4-5 Line to F.G : ± 2KV (peak) 6-6. EMI Comply with Standards CISPR 22, EN 55022 Class B 7-0. Mechanical Characteristics 7-1. Physical Size : 133 mm (L) * 59 mm (W) * 34 mm (H) 7-2. Enclosure material : 94V-1 minimum 7-3. Output Cable (Reference) : UL1185 #16 7-4. Vibration Test The vibration frequencies are set at 20Hz, with total amplitude of 1.5mm Along the 3 directions namely X-Y-Z. The each direction should be vibrated for 60 minutes, after testing no abnormal electrical or mechanical should occur. 7-5. Drop Test (Referencing to CSA C22.2 No.950/UL1950/UL1310/EN60950) Products shall be dropped from a height of 900 mm onto a horizontal surface consists of hardwood at 13mm thick, mounted on two layers of plywood each 19mm to 20mm thick, all supported on a concrete or equivalent non-resilient floor. Upon conclusion of test, the equipment need not be operational. 7-6. Net Weight (Reference) : 450 g 电源适配器 型号 输入 输出 注意 室内产品使用 出厂日期 中国制造
B0492 价格&库存
很抱歉,暂时无法提供与“B0492”相匹配的价格&库存,您可以联系我们找货
