T21MU12KCI
T21MU12KCI
    TEMPREL
    12 PROBE, 1/8 PROBE DIAMATER
T21MU12KCI 数据手册
K-Cal 1/8"OD x 12" U Mini-Plug Inconel Item #: T21MU12KCI Product Info A quick disconnect thermocouple with compacted MgO insulation employing a glass-filled, nylon connector directly on the sheath. This specific K Type T21 Thermocouple Probe with attached connectors is a molded on mini-plug. It is ungrounded and the probe length is 12”. The probe diameter is .125” (1/8”) with Inconel material. The connector max temp rating is 525F (274C) and the probe max temp rating is 2150F (1175C). Item Specifications • Calibration K Type • Connector ANSI Color Yellow • Connector Max Temp Rating 525°F (274°C) • Connector Molded on Mini-Plug • Element Single • Junction Type Ungrounded • Lower Continuous Temperature Range -325°F to +32°F (-200°C to +0°C) • Max Continuous Temperature Range +32°F to +2280°F (0°C to +1250°C) • Model T21 • Probe Diameter 0.125" (1/8") • Probe Length Group 12" • Probe Length 12" • Probe Material Inconel • Probe Max Temp Rating 2150°F (1175°C) • Thermocouple Dissimilar Metals Nickel Chromium vs Nickel Aluminum
T21MU12KCI 价格&库存
很抱歉,暂时无法提供与“T21MU12KCI”相匹配的价格&库存,您可以联系我们找货
