P0581
P0581
    TERASIC(友晶科技)
    Cyclone V SE SoC TSoM 5CSEBA6 Cyclone® V SE FPGA + MCU/MPU SoC 评估板
P0581 数据手册
    Terasic SoC System on Module Evaluation KIT     TSoM (Terasic SoC System on Module) are small, integrated single-board computers with Cyclone® V SoCs at the core. The SoC SoM includes DDR3 memory, flash memory, power management, common interface controllers, and board support package (BSP) software to help you create a fully customized embedded design without starting from scratch.  Specifications  Module    FPGA: Cyclone V SE 5CSEBA6U23I7NDK (110K Les) Interface: DDR4 Edge (include 3.3V power source) Dimension: 50 mm x 70 mm FPGA side    DDR3 SDRAM 1GB, 32bit – 303MHz (Soft IP) LVDS Transmitter x15 & LVDS Receiver x17 pairs & GPIO x3 ( Total GPIO x67) Optional EPCS64 HPS side        Boot Selection DIP Switch: boot from eMMC or MicroSD Card DDR3 SDRAM 1GB, 32bit - 400MHz USB 2.0 PHY Gigabit Ethernet PHY 3.3V GPIO x25 (Can/UART/SPI/I2C/Trace Buses) 1.5V GPI x4 (Input pins) Optional eMMC 8GB Software Support   Linux BSP OpenCL BSP Block Diagram Evaluation Kit TSOM-BB is a baseboard designed for users to evaluate the TSOM board. The TSOM-BB features includes: System:    Power source : 5V DC On-board USB Blaster II DDR4 socket for TSOM installation FPGA side     LED x 2, Key x 2, Switch x 2 HDMI TX v1.4, 1080P Full-HD, Compatible with HDCP v1.4 TMD Header x2 (support 16 GPIO) ADC, 8-channel, 12-bit, 500Ksps. HPS side       MicroSD Socket Optional 512Mb QSPI FLASH (Need to rework Boot Selection resistor on Module) USB to UART (USB OTG PHY, Mini-B Connector) Ethernet (RJ45 Connector) USB OTG (Micro-AB Connector) 2x13 GPIO (include I2C/UART/SPI), Compatible with Raspberry Pi Expansion IO Top view of TSOM-BB board. TSOM installed on the TSOM-BB board.     Bottom view of TSOM-BB board. Layout  TSOM Module TSOM Baseboard Please note that all the source codes are provided "as-is". For further support or modification, please contact Terasic Support and your request will be transferred to Terasic Design Service. More resources about IP and Dev. Kit are available on Intel User Forums. Kit Contents  TSOM Module  TSOM Module TSOM Evaluation Kit 1. 2. 3. 4. 5. 6. 7. TSOM Module (installed) TSOM Baseboard Quick Start Guide Power DC Adapter (5V) Type A to Mini-B USB Cable x2 microSD card (installed) Four Silicon Footstands   No Title 1. [TSoM] Terasic SoC System on Module Evaluation KIT Part No: P0581 Weight: 500g 2. TSOM Module Part No: S0533 Weight: 500g                                https://www.terasic.com.tw/cgi‐bin/page/archive.pl?Language=English&CategoryNo=167&No=1211&PartNo=1/2‐6‐19
P0581 价格&库存
很抱歉,暂时无法提供与“P0581”相匹配的价格&库存,您可以联系我们找货
