CDC2586
www.ti.com
SCAS337D – FEBRUARY 1993 – REVISED APRIL 2004
3.3-V PHASE-LOCK LOOP CLOCK DRIVER WITH 3-STATE OUTPUTS
FEATURES
Low Output Skew for Clock-Distribution
and Clock-Generation Applications
Operates at 3.3-V VCC
Distributes One Clock Input to 12
Outputs
Two Select Inputs Configure Up to Nine
Outputs to Operate at One-Half or Double
the Input Frequency
No External RC Network Required
External Feedback (FBIN) Synchronizes the
Outputs to the Clock Input
Application for Synchronous DRAM,
High-Speed Microprocessor
TTL-Compatible Inputs and Outputs
Outputs Have Internal 26-Ω Series
Resistors to Dampen Transmission-Line
Effects
State-of-the-Art EPIC-IIB™ BiCMOS Design
Significantly Reduces Power Dissipation
Distributed VCC and Ground Pins Reduce
Switching Noise
Packaged in 52-Pin Thin Quad Flat Package
GND
SEL1
SEL0
AGND
FBIN
AGND
AV CC
CLKIN
NC
AVCC
OE
TEST
CLR
PAH PACKAGE
(TOP VIEW)
1
52 51 50 49 48 47 46 45 44 43 42 41 40
39
2
38
3
37
4
36
5
35
6
34
7
33
8
32
9
31
10
30
11
29
12
28
13
27
14 15 16 17 18 19 20 21 22 23 24 25 26
VCC
4Y3
GND
VCC
4Y2
GND
VCC
4Y1
GND
GND
VCC
3Y3
GND
GND
2Y2
VCC
GND
2Y3
VCC
GND
GND
3Y1
VCC
GND
3Y2
VCC
GND
1Y1
VCC
GND
1Y2
VCC
GND
1Y3
VCC
GND
GND
2Y1
VCC
NC – No internal connection
DESCRIPTION
The CDC2586 is a high-performance, low-skew, low-jitter clock driver. It uses a phase-lock loop (PLL) to
precisely align, in both frequency and phase, the clock output signals to the clock input (CLKIN) signal. It is
specifically designed for use with popular microprocessors operating at speeds from 50 MHz to 100 MHz or
down to 25 MHz on outputs configured for half-frequency operation. Each output has an internal 26-Ω series
resistor that improves the signal integrity at the load. The CDC2586 operates at nominal 3.3-V VCC.
Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas
Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet.
EPIC-IIB is a trademark of Texas Instruments.
PRODUCTION DATA information is current as of publication date.
Products conform to specifications per the terms of the Texas
Instruments standard warranty. Production processing does not
necessarily include testing of all parameters.
Copyright © 1993–2004, Texas Instruments Incorporated
CDC2586
www.ti.com
The feedback input (FBIN) synchronizes the output clocks in frequency and phase to CLKIN. One of the twelve
output clocks must be fed back to FBIN for the PLL to maintain synchronization between CLKIN and the outputs.
The output used as feedback is synchronized to the same frequency as CLKIN.
The Y outputs can be configured to switch in phase and at the same frequency as CLKIN. Select inputs (SEL1,
SEL0) configure up to nine Y outputs, in banks of three, to operate at one-half or double the CLKIN frequency
depending on which output is fed back to FBIN (see Table 1 and Table 2). All output signal duty cycles are
adjusted to 50% independent of the duty cycle at CLKIN.
Output-enable (OE) provides output control. When OE is high, the outputs are in the high-impedance state.
When OE is low, the outputs are active. TEST is used for factory testing of the device and can be used to bypass
the PLL. TEST should be strapped to GND for normal operation.
Unlike many products containing PLLs, the CDC2586 does not require external RC networks. The loop filter for
the PLL is included on-chip, minimizing component count, board space, and cost.
Because it is based on PLL circuitry, the CDC2586 requires a stabilization time to achieve phase lock of the
feedback signal to the reference signal. This stabilization time is required following power up and application of a
fixed-frequency, fixed-phase signal at CLKIN, as well as following any changes to the PLL reference or feedback
signals. Such changes occur upon change of the select inputs, enabling of the PLL via TEST, and upon enable
of all outputs via OE.
The CDC2586 is characterized for operation from 0°C to 70°C.
DETAILED DESCRITPION OF OUTPUT CONFIGURATIONS
The voltage-controlled oscillator (VCO) used in the CDC2586 PLL has a frequency range of 100 MHz to 200
MHz, twice the operating frequency range of the CDC2586 outputs. The output of the VCO is divided by two and
four to provide reference frequencies with a 50% duty cycle of one-half and one-fourth the VCO frequency. The
SEL0 and SEL1 inputs select which of the two signals are buffered to each bank of device outputs.
One device output must be externally wired to FBIN to complete the PLL. The VCO operates such that the
frequency and phase of this output matches that of the CLKIN signal. In the case that a VCO/2 output is wired to
FBIN, the VCO must operate at twice the CLKIN frequency resulting in device outputs that operate at either the
same or one-half the CLKIN frequency. If a VCO/4 output is wired to FBIN, the device outputs operate at twice or
the same as the CLKIN frequency.
2
CDC2586
www.ti.com
Output Configuration A
Output configuration A is valid when any output configured as a 1x frequency output in Table 1 is fed back to
FBIN. The input frequency range for CLKIN is 50 MHz to 100 MHz when using output configuration A. Outputs
configured as 1/2 outputs operate at half the CLKIN frequency, while outputs configured as 1x outputs operate at
Table 1. Output Configuration A (1)
INPUTS
SEL0
L
L
None
All
L
H
1Yn
2Yn, 3Yn, 4Yn
H
L
1Yn, 2Yn
3Yn, 4Yn
H
H
1Yn, 2Yn, 3Yn
4Yn
SEL1
(1)
OUTPUTS
1/2×
FREQUENCY
1×
FREQUENCY
n = 1, 2, 3
Output Configuration B
Output configuration B is valid when any output configured as a 1x frequency output in Table 2 is fed back to
FBIN. The input frequency range for CLKIN is 25 MHz to 50 MHz when using output configuration B. Outputs
configured as 1x outputs operate at the CLKIN frequency, while outputs configured as 2x outputs operate at
double the frequency of CLKIN.
Table 2. Output Configuration B (1)
INPUTS
SEL1
(1)
OUTPUTS
SEL0
1×
FREQUENCY
2×
FREQUENCY
L
L
All
None
L
H
1Yn
2Yn, 3Yn, 4Yn
H
L
1Yn, 2Yn
3Yn, 4Yn
H
H
1Yn, 2Yn, 3Yn
4Yn
n = 1, 2, 3
3
CDC2586
www.ti.com
FUNCTIONAL BLOCK DIAGRAM
OE
CLR
FBIN
Phase-Lock Loop
CLK
÷2
CLR
÷2
TEST
SEL0
SEL1
One of Four Identical
Outputs – 1Yn
Select
Logic
1Y1–1Y3
Outputs – 2Yn
2Y1–2Y3
Outputs – 3Yn
3Y1–3Y3
Outputs – 4Yn
4Y1–4Y3
4
CDC2586
www.ti.com
Terminal Functions
TERMINAL
NAME
NO.
I/O
DESCRIPTION
CLKIN
45
I
Clock input. CLKIN is the clock signal to be distributed by the CDC2586 clock-driver circuit. CLKIN
provides the reference signal to the integrated PLL that generates the clock output signals. CLKIN must
have a fixed frequency and fixed phase for the PLL to obtain phase lock. Once the circuit is powered
up and a valid CLKIN signal is applied, a stabilization time is required for the PLL to phase lock the
feedback signal to its reference signal.
CLR
40
I
CLR is used for testing purposes only.
FBIN
48
I
Feedback input. FBIN provides the feedback signal to the internal PLL. FBIN must be hardwired to one
of the 12 clock outputs to provide frequency and phase lock. The internal PLL adjusts the output clocks
to obtain zero phase delay between FBIN and CLKIN.
OE
42
I
Output enable. OE is the output enable for all outputs. When OE is low, all outputs are enabled. When
OE is high, all outputs are in the high-impedance state. Since the feedback signal for the PLL is taken
directly from an output, placing the outputs in the high-impedance state interrupts the feedback loop;
therefore, when a high-to-low transition occurs at OE, enabling the output buffers, a stabilization time is
required before the PLL obtains phase lock.
SEL1, SEL0
51, 50
I
Output configuration select. SEL0 and SEL1 select the output configuration for each output bank (e.g.,
1/2×, 1×, or 2×) (see Table 1 and Table 2).
TEST
41
I
TEST is used to bypass the PLL circuitry for factory testing of the device. When TEST is low, all
outputs operate using the PLL circuitry. When TEST is high, the outputs are placed in a test mode that
bypasses the PLL circuitry. TEST should be strapped to GND for normal operation.
O
Output ports. These outputs are configured by the select inputs (SEL1, SEL0) to transmit one-half or
one-fourth the frequency of the VCO. The relationship between the CLKIN frequency and the output
frequency is dependent on the select inputs and the frequency of the output being fed back to FBIN
(see Table 1 and Table 2). The duty cycle of the Y output signals is nominally 50%, independent of the
duty cycle of CLKIN. Each output has an internal series resistor to dampen transmission-line effects
and improve the signal integrity at the load.
O
Output ports. 4Y1-4Y3 transmit one-half the frequency of the VCO regardless of the state of the select
inputs. The relationship between the CLKIN frequency and the output frequency is dependent on the
frequency of the output being fed back to FBIN (see Table 1 and Table 2). The duty cycle of the Y
output signals is nominally 50%, independent of the duty cycle of CLKIN. Each output has an internal
series resistor to dampen transmission-line effects and improve the signal integrity at the load.
1Y1-1Y3
2Y1-2Y3
3Y1-3Y3
4Y1-4Y3
2, 5, 8 12,
15, 18 22,
25, 28
32, 35, 38
ABSOLUTE MAXIMUM RATINGS
over operating free-air temperature range (unless otherwise noted)
(1)
UNIT
Supply voltage range, VCC
-0.5 V to 4.6 V
Input voltage range, VI (2)
-0.5 V to 7 V
Voltage range applied to any output in the high state or power-off state, VO (2)
-0.5 V to 5.5 V
Current into any output in the low state, IO
24 mA
Input clamp current, IIK(VI< 0)
-20 mA
Output clamp current, IOK(VO< 0)
Maximum power dissipation at TA = 55°C (in still air)
Storage temperature range, Tstg
(1)
(2)
(3)
-50 mA
(3)
1.2 W
-65°C to 150°C
Stresses beyond those listed under "absolute maximum ratings” may cause permanent damage to the device. These are stress ratings
only, and functional operation of the device at these or any other conditions beyond those indicated under "recommended operating
conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability.
The input and output negative-voltage ratings may be exceeded if the input and output clamp-current ratings are observed.
The maximum package power dissipation is calculated using a junction temperature of 150°C and a board trace length of 75 mils. For
more information, see the Package Thermal Considerations application note in the ABT Advanced BiCMOS Technology Data Book,
literature number SCBD002.
5
CDC2586
www.ti.com
RECOMMENDED OPERATING CONDITIONS
(1)
MIN
MAX
VCC
Supply voltage
3
3.6
VIH
High-level input voltage
2
VIL
Low-level input voltage
VI
Input voltage
IOH
High-level output current
IOL
Low-level output current
TA
Operating free-air temperature
(1)
UNIT
V
V
0.8
V
5.5
V
-12
mA
12
mA
70
°C
Unused inputs must be held high or low to prevent them from floating.
ELECTRICAL CHARACTERISTICS
over recommended operating free-air temperature range (unless otherwise noted)
PARAMETER
VIK
VOH
TA = 25°C
MIN
VCC = 3 V,
II = -18 mA
VCC = MIN to MAX (1),
IOH = -100 µA
VCC-0.2
VCC = 3 V,
IOH = -12 mA
2
MAX
-1.2
0.2
IOL = 12 mA
0.8
VCC = 0,
VI = 3.6 V
±10
VCC = 3.6 V,
VI = VCC or GND
IOZH
VCC = 3.6 V,
VO = 3 V
IOZL
VCC = 3.6 V,
VO = 0
ICC
VCC = 3.6 V, IO= 0,
VI = VCC or GND
II
VCC = 3 V
UNIT
V
V
IOL = 100 µA
VOL
(1)
TEST CONDITIONS
±1
V
µA
10
µA
-10
µA
Outputs high
1
Outputs low
1
Outputs disabled
1
mA
Ci
VI = VCC or GND
4
pF
Co
VO = VCC or GND
8
pF
For conditions shown as MIN or MAX, use the appropriate value specified under recommended operating conditions.
TIMING REQUIREMENTS
over recommended ranges of supply voltage and operating free-air temperature
MIN
fclock
Clock frequency
VCO operating at four times the CLKIN frequency
25
50
VCO operating at double the CLKIN frequency
50
100
40%
60%
Input clock duty cycle
Stabilization time (1)
(1)
6
MAX
After SEL1, SEL0
50
After OE↓
50
After power up
50
After CLKIN
50
UNIT
MHz
µs
Time required for the integrated PLL circuit to obtain phase lock of its feedback signal to its reference signal. In order for phase lock to
be obtained, a fixed-frequency, fixed-phase reference signal must be present at CLKIN. Until phase lock is obtained, the specifications
for propagation delay and skew parameters given in the switching characteristicstable are not applicable.
CDC2586
www.ti.com
SWITICHING CHARACTERISTICS
over recommended ranges of supply voltage and operating free-air temperature, CL = 15 pF (see
Figure 3)
FROM
(INPUT)
PARAMETER
(1)
and Figure 1 through
TO
(OUTPUT)
MIN
MAX
UNIT
100
MHz
Y
45%
55%
CLKIN↑
Y↑
-500
+500
ps
CLKIN↑
Y↑
200
ps
0.5
ns
fmax
Duty cycle
tphase
error
(2)
jitter
tsk(o) (2)
tsk(pr)
(1)
(2)
(2)
1
ns
tr
1.4
ns
tf
1.4
ns
The specifications for parameters in this table are applicable only after any appropriate stabilization time has elapsed.
The propagation delay, tphase error, is dependent on the feedback path from any output to FBIN. The tphase error, tsk(o),and tsk(pr)
specifications are valid only for equal loading of all outputs.
PARAMETER MEASUREMENT INFORMATION
3V
Input
1.5 V
1.5 V
0V
tphase error
From Output
Under Test
CL = 15 pF
(see Note A)
500 Ω
2V
0.8 V
Output
tr
VOH
2V
1.5 V
0.8 V
VOL
tf
VOLTAGE WAVEFORMS
PROPAGATION DELAY TIMES
LOAD CIRCUIT
A.
CL includes probe and jig capacitance.
B.
All input pulses are supplied by generators having the following characteristics: PRR ≤ 100 MHz, ZO = 50 Ω,
tr≤ 2.5 ns, tf ≤ 2.5 ns.
C.
The outputs are measured one at a time with one transition per measurement.
Figure 1. Load Circuit and Voltage Waveforms
7
CDC2586
www.ti.com
PARAMETER MEASUREMENT INFORMATION (continued)
CLKIN
tphase error 1
Outputs
Operating
at 1/2 CLKIN
Frequency
tphase error 2
tphase error 3
Outputs
Operating
at CLKIN
Frequency
A.
B.
C.
tphase error 4
tphase error 7
tphase error 5
tphase error 8
tphase error 6
tphase error 9
Output skew, tsk(o), is calculated as the greater of:
The difference between the fastest and slowest of tphase error n (n = 1, 2, . . . 6)
The difference between the fastest and slowest of tphase error n (n = 7, 8, 9)
Process skew, tsk(pr), is calculated as the greater of:
The difference between the maximum and minimum tphase
identical operating conditions
error n
(n = 1, 2, . . . 6) across multiple devices under
error n
(n = 7, 8, 9) across multiple devices under
For configuration A, see Table 1
Figure 2. Waveforms for Calculation of tsk(o)for Configuration A
8
CDC2586
www.ti.com
CLKIN
tphase error 10
Outputs
Operating
at CLKIN
Frequency
tphase error 11
tphase error 12
tphase error 13
Outputs
Operating
at 2 CLKIN
Frequency
tphase error 14
tphase error 15
A.
B.
C.
The difference between the fastest and slowest of tphase error n (n = 10, 11, . . . 15)
under identical operating conditions
error n
(n = 10, 11, . . . 15) across multiple devices
For configuration B, see Table 2
Figure 3. Waveforms for Calculation of tsk(o)for Configuration B
9
IMPORTANT NOTICE
Texas Instruments Incorporated and its subsidiaries (TI) reserve the right to make corrections, modifications,
enhancements, improvements, and other changes to its products and services at any time and to discontinue
any product or service without notice. Customers should obtain the latest relevant information before placing
orders and should verify that such information is current and complete. All products are sold subject to TI’s terms
and conditions of sale supplied at the time of order acknowledgment.
TI warrants performance of its hardware products to the specifications applicable at the time of sale in
accordance with TI’s standard warranty. Testing and other quality control techniques are used to the extent TI
deems necessary to support this warranty. Except where mandated by government requirements, testing of all
parameters of each product is not necessarily performed.
TI assumes no liability for applications assistance or customer product design. Customers are responsible for
their products and applications using TI components. To minimize the risks associated with customer products
and applications, customers should provide adequate design and operating safeguards.
TI does not warrant or represent that any license, either express or implied, is granted under any TI patent right,
copyright, mask work right, or other TI intellectual property right relating to any combination, machine, or process
in which TI products or services are used. Information published by TI regarding third-party products or services
does not constitute a license from TI to use such products or services or a warranty or endorsement thereof.
Use of such information may require a license from a third party under the patents or other intellectual property
of the third party, or a license from TI under the patents or other intellectual property of TI.
Reproduction of information in TI data books or data sheets is permissible only if reproduction is without
alteration and is accompanied by all associated warranties, conditions, limitations, and notices. Reproduction
of this information with alteration is an unfair and deceptive business practice. TI is not responsible or liable for
such altered documentation.
Resale of TI products or services with statements different from or beyond the parameters stated by TI for that
product or service voids all express and any implied warranties for the associated TI product or service and
is an unfair and deceptive business practice. TI is not responsible or liable for any such statements.
Following are URLs where you can obtain information on other Texas Instruments products and application
solutions:
Products
Applications
Amplifiers
amplifier.ti.com
Audio
www.ti.com/audio
Data Converters
dataconverter.ti.com
Automotive
www.ti.com/automotive
DSP
dsp.ti.com
Broadband
www.ti.com/broadband
Interface
interface.ti.com
Digital Control
www.ti.com/digitalcontrol
Logic
logic.ti.com
Military
www.ti.com/military
Power Mgmt
power.ti.com
Optical Networking
www.ti.com/opticalnetwork
Microcontrollers
microcontroller.ti.com
Security
www.ti.com/security
Telephony
www.ti.com/telephony
Video & Imaging
www.ti.com/video
Wireless
www.ti.com/wireless
Mailing Address:
Texas Instruments
Post Office Box 655303 Dallas, Texas 75265
Copyright 2004, Texas Instruments Incorporated
