CDCP1803RTHR
CDCP1803RTHR
    ROCHESTER(罗切斯特)
    24-VFQFN Exposed Pad
    LOW SKEW CLOCK DRIVER
CDCP1803RTHR 数据手册
CDCP1803 www.ti.com SCAS727F – NOVEMBER 2003 – REVISED DECEMBER 2013 1:3 LVPECL CLOCK BUFFER WITH PROGRAMMABLE DIVIDER Check for Samples: CDCP1803 FEATURES 1 S1 VDD0 Y0 Y0 VDD0 24 23 22 21 20 19 18 VDDPECL 2 17 VDD1 IN 3 16 Y1 IN 4 15 Y1 VDDPECL 5 14 VDD1 VBB 6 (1) VSS(1) 9 13 10 11 12 S0 VSS NC 8 VDD2 7 Y2 • • • 1 Y2 • EN VDD2 • • • • RGE PACKAGE (TOP VIEW) S2 • Distributes One Differential Clock Input to Three LVPECL Differential Clock Outputs Programmable Output Divider for Two LVPECL Outputs Low-Output Skew 15 ps (Typical) VCC Range 3 V–3.6 V Signaling Rate Up to 800-MHz LVPECL Differential Input Stage for Wide CommonMode Range Provides VBB Bias Voltage Output for SingleEnded Input Signals Receiver Input Threshold ±75 mV 24-Terminal QFN Package (4 mm × 4 mm) Accepts Any Differential Signaling: LVDS, HSTL, CML, VML, SSTL-2, and Single-Ended: LVTTL/LVCMOS VSS • Thermal pad must be connected to VSS. P0024-02 DESCRIPTION S2 VDD0 Y0 Y0 VDD0 S1 23 22 21 20 19 EN 1 18 S0 VDDPECL 2 17 VDD1 IN 3 16 Y1 IN 4 15 Y1 VDDPECL 5 14 VDD1 VBB 6 13 VSS (1) 7 8 9 10 11 12 VDD2 Y2 Y2 VDD2 NC VSS(1) VSS The CDCP1803 has three control terminals, S0, S1, and S2, to select different output mode settings; see Table 1 for details. The CDCP1803 is characterized for operation from –40°C to 85°C. For use in singleended driver applications, the CDCP1803 also provides a VBB output terminal that can be directly connected to the unused input as a common-mode voltage reference. 24 RTH PACKAGE (TOP VIEW) The CDCP1803 clock driver distributes one pair of differential clock inputs to three pairs of LVPECL differential clock outputs Y[2:0] and Y[2:0] with minimum skew for clock distribution. The CDCP1803 is specifically designed for driving 50-Ω transmission lines. Thermal pad must be connected to VSS. P0025-02 1 Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet. PRODUCTION DATA information is current as of publication date. Products conform to specifications per the terms of the Texas Instruments standard warranty. Production processing does not necessarily include testing of all parameters. Copyright © 2003–2013, Texas Instruments Incorporated CDCP1803 SCAS727F – NOVEMBER 2003 – REVISED DECEMBER 2013 www.ti.com These devices have limited built-in ESD protection. The leads should be shorted together or the device placed in conductive foam during storage or handling to prevent electrostatic damage to the MOS gates. FUNCTIONAL BLOCK DIAGRAM Y0 IN LVPECL Y0 IN Y1 LVPECL Div 1 Div 2 Div 4 Div 8 Div 16 Y1 Y2 LVPECL Y2 VBB Bias Generator VDD − 1.3 V (Imax < 1.5 mA) Control S1 S2 S0 EN B0059-02 2 Submit Documentation Feedback Copyright © 2003–2013, Texas Instruments Incorporated Product Folder Links :CDCP1803 CDCP1803 www.ti.com SCAS727F – NOVEMBER 2003 – REVISED DECEMBER 2013 TERMINAL FUNCTIONS TERMINAL NAME EN IN, IN NO. 1 3, 4 I/O I (with 60-kΩ pullup) I (differential) DESCRIPTION ENABLE: Enables or disables all outputs simultaneously. EN = 1: outputs on according to S[2:0] settings EN = 0: outputs Y[2:0] off (high impedance) See Table 1 for details. Differential input clock. Input stage is sensitive and has a wide common-mode range. Therefore, almost any type of differential signal can drive this input (LVPECL, LVDS, CML, HSTL). Because the input is high-impedance, it is recommended to terminate the PCB transmission line before the input (e.g., with 100 Ω across input). Input can also be driven by a single-ended signal if the complementary input is tied to VBB. A moreadvanced scheme for single-ended signals is given in the Application Information section near the end of this document. The inputs employ an ESD structure protecting the inputs in case of an input voltage exceeding the rails by more than ~0.7 V. Reverse biasing of the IC through these inputs is possible and must be prevented by limiting the input voltage < VDD. NC S[2:0] VBB 12 No connect. Leave this terminal open or tie to ground. 24, 19, 18 I (with 60-kΩ pullup) Select mode of operation. Defines the output configuration of Y[2:0], see Table 1 for configuration. 6 O Bias voltage output can be used to bias unused complementary input IN for singleended input signals. The output voltage of VBB is VDD – 1.3 V. When driving a load, the output current drive is limited to about 1.5 mA. VDDPECL VDD[2:0] 2, 5 Supply Supply voltage PECL input + internal logic 8, 11, 14, 17, 20, 23 Supply PECL output supply voltage for output Y[2:0]. Each output can be disabled by pulling the corresponding VDDx to GND. CAUTION: In this mode, no voltage from outside may be forced, because internal diodes could be forced in forward direction. Thus, it is recommended to disconnect the output if it is not being used. VSS Y[2:0] Y[2:0] 7, 13 Supply 9, 15, 21 10, 16, 22 O (LVPECL) Device ground LVPECL clock outputs. These outputs provide low-skew copies of IN or down-divided copies of clock IN based on selected mode of operation S[2:0]. If an output is unused, the output can simply be left open to save power and minimize noise impact to the remaining outputs. Submit Documentation Feedback Copyright © 2003–2013, Texas Instruments Incorporated Product Folder Links :CDCP1803 3 CDCP1803 SCAS727F – NOVEMBER 2003 – REVISED DECEMBER 2013 www.ti.com CONTROL TERMINAL SETTINGS The CDCP1803 has three control terminals (S0, S1, and S2) and an enable terminal (EN) to select different output mode settings. Setting for Mode 20: EN = 1 S2 = 1 S1 = 0 S0 = 1 CDCP1803 REN = Open EN RS2 = Open S2 RS1 = 0 Ω S1 RS0 = Open S0 S0084-02 Figure 1. Control Terminal Setting for Example 4 Submit Documentation Feedback Copyright © 2003–2013, Texas Instruments Incorporated Product Folder Links :CDCP1803 CDCP1803 www.ti.com SCAS727F – NOVEMBER 2003 – REVISED DECEMBER 2013 Table 1. Selection Mode Table LVPECL (1) (1) MODE EN S2 S1 S0 Y0 Y1 Y2 0 0 x x x 1 1 0 0 0 ÷1 ÷1 ÷1 2 1 0 0 VDD/2 ÷1 Off (high-z) Off (high-z) 3 1 0 0 1 ÷1 ÷1 Off (high-z) 4 1 0 VDD/2 0 ÷1 ÷2 Off (high-z) 5 1 0 VDD/2 VDD/2 ÷1 ÷4 Off (high-z) 6 1 0 VDD/2 1 ÷1 ÷8 Off (high-z) 7 1 0 1 0 ÷1 Off (high-z) ÷1 8 1 0 1 1 ÷1 ÷2 ÷1 9 1 VDD/2 0 0 ÷1 ÷4 ÷1 10 1 VDD/2 0 VDD/2 ÷1 ÷8 ÷1 11 1 VDD/2 0 1 ÷1 Off (high-z) ÷2 12 1 VDD/2 VDD/2 0 ÷1 ÷1 ÷2 13 1 VDD/2 VDD/2 VDD/2 ÷1 ÷2 ÷2 14 1 VDD/2 VDD/2 1 ÷1 ÷4 ÷2 15 1 VDD/2 1 0 ÷1 ÷8 ÷2 16 1 VDD/2 1 VDD/2 ÷1 Off (high-z) ÷4 17 1 VDD/2 1 1 ÷1 ÷1 ÷4 18 1 1 0 0 ÷1 ÷2 ÷4 19 1 1 0 VDD/2 ÷1 ÷4 ÷4 20 1 1 0 1 ÷1 ÷8 ÷4 21 1 1 VDD/2 0 ÷1 Off (high-z) ÷8 22 1 1 VDD/2 VDD/2 ÷1 ÷1 ÷8 23 1 1 VDD/2 1 ÷1 ÷2 ÷8 24 1 1 1 0 ÷1 ÷4 ÷8 25 1 1 1 VDD/2 ÷1 ÷8 ÷8 26 1 1 1 1 ÷1 Off (high-z) ÷ 16 27 VDD/2 0 0 0 ÷1 ÷1 ÷ 16 28 VDD/2 0 0 VDD/2 ÷1 ÷2 ÷ 16 29 VDD/2 0 0 1 ÷1 ÷4 ÷ 16 Off (high-z) 30 VDD/2 0 VDD/2 0 ÷1 ÷8 ÷ 16 Rsv VDD/2 1 VDD/2 1 Reserved Reserved Reserved Rsv VDD/2 1 1 0 N/A Low Low The LVPECL outputs are open-emitter stages. Thus, if the unused LVPECL outputs Y0, Y1, or Y2 are left unconnected, then the current consumption is minimized and noise impact to remaining outputs is neglectable. Also, each output can be individually disabled by connecting the corresponding VDD input to GND. Submit Documentation Feedback Copyright © 2003–2013, Texas Instruments Incorporated Product Folder Links :CDCP1803 5 CDCP1803 SCAS727F – NOVEMBER 2003 – REVISED DECEMBER 2013 www.ti.com ABSOLUTE MAXIMUM RATINGS over operating free-air temperature (unless otherwise noted) (1) VDD Supply voltage –0.3 V to 3.8 V VI Input voltage –0.2 V to (VDD + 0.2 V) VO Output voltage –0.2 V to (VDD + 0.2 V) Differential short-circuit current, Yn, Yn, IOSD Continuous Electrostatic discharge (HBM 1.5 kΩ, 100 pF), ESD >2000 V Moisture level 24-terminal QFN package (solder reflow temperature of 235°C) MSL Tstg Storage temperature TJ Maximum junction temperature (1) 2 –65°C to 150°C 125°C Stresses beyond those listed under absolute maximum ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under recommended operating conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. RECOMMENDED OPERATING CONDITIONS VDD Supply voltage TA Operating free-air temperature MIN TYP MAX 3 3.3 3.6 V 85 °C –40 UNIT ELECTRICAL CHARACTERISTICS over operating free-air temperature range (unless otherwise noted) LVPECL INPUT IN, IN MAX UNIT fclk Input frequency PARAMETER 0 800 MHz VCM High-level input common mode 1 VDD – 0.3 VIN TYP (1) 500 1300 Input voltage swing between IN and IN (2) 125 1300 Input current RIN Input impedance CI Input capacitance at IN, IN 6 MIN Input voltage swing between IN and IN IIN (1) (2) TEST CONDITIONS VI = VDD or 0 V ±10 300 V mV μA kΩ 1 pF Is required to maintain ac specifications Is required to maintain device functionality Submit Documentation Feedback Copyright © 2003–2013, Texas Instruments Incorporated Product Folder Links :CDCP1803 CDCP1803 www.ti.com SCAS727F – NOVEMBER 2003 – REVISED DECEMBER 2013 ELECTRICAL CHARACTERISTICS (continued) over operating free-air temperature range (unless otherwise noted) LVPECL OUTPUT DRIVER Y[2:0], Y[2:0] PARAMETER MAX UNIT 0 800 MHz Termination with 50 Ω to VDD – 2 V VDD – 1.18 VDD – 0.81 V Low-level output voltage Termination with 50 Ω to VDD – 2 V VDD – 1.98 VDD – 1.55 V Output voltage swing between Y and Y, see Figure 3. Termination with 50 Ω to VDD – 2 V 500 fclk Output frequency, see Figure 3. VOH High-level output voltage VOL VO IOZL Output 3-state current IOZH TEST CONDITIONS TYP mV VDD = 3.6 V, VO = 0 V 5 VDD = 3.6 V, VO = VDD – 0.8 V tr/tf Rise and fall times 20% to 80% of VOUTPP, see Figure 7. tskpecl(o) Output skew between any LVPECL output Y[2:0] and Y[2:0] See Note A in Figure 6. tDuty Output duty-cycle distortion (1) Crossing point-to-crossing point distortion tsk(pp) Part-to-part skew Any Y, see Note B in Figure 6. CO Output capacitance VO = VDD or GND LOAD Expected output load (1) MIN 10 200 15 –50 50 μA 350 ps 30 ps 50 ps 300 ps 1 pF 50 Ω For an 800-MHz signal, the 50-ps error would result in a duty cycle distortion of ±4% when driven by an ideal clock input signal. LVPECL INPUT-TO-LVPECL OUTPUT PARAMETERS MAX UNIT tpd(lh) Propagation delay, rising edge PARAMETER VOX to VOX TEST CONDITIONS MIN 320 TYP 600 ps tpd(hl) Propagation delay, falling edge VOX to VOX 320 600 ps tsk(p) LVPECL pulse skew VOX to VOX, see Note C in Figure 6. 100 ps MAX UNIT JITTER CHARACTERISTICS PARAMETER TEST CONDITIONS MIN TYP JITTER CHARACTERISTICS tjitterLVPECL Additive phase jitter from input to LVPECL output Y[2:0], see Figure 2. 12 kHz to 20 MHz, fout = 250 MHz to 800 MHz, divide-by-1 mode 0.15 50 kHz to 40 MHz, fout = 250 MHz to 800 MHz, divide-by-1 mode 0.25 ps rms Submit Documentation Feedback Copyright © 2003–2013, Texas Instruments Incorporated Product Folder Links :CDCP1803 7 CDCP1803 SCAS727F – NOVEMBER 2003 – REVISED DECEMBER 2013 www.ti.com ADDITIVE PHASE NOISE vs FREQUENCY OFFSET FROM CARRIER – LVPECL LVPECL OUTPUT SWING vs FREQUENCY 0.90 −110 −120 0.85 −125 −130 −135 −140 −145 0.75 0.70 VDD = 3 V 0.65 0.60 0.55 −150 0.50 −155 0.45 −160 10 100 VDD = 3.6 V 0.80 LVPECL Output Swing − V Additive Phase Noise − dBc/Hz −115 VDD = 3.3 V TA = 25°C f = 622 MHz ÷1 Mode 1k 10k 100k 1M 10M 0.40 0.1 100M VDD = 3.3 V TA = 25°C Load = 50 Ω to VDD − 2 V 0.3 0.5 0.7 0.9 1.1 1.3 1.5 f − Frequency − GHz f − Frequency Offset From Carrier − Hz G002 G001 Figure 2. Figure 3. SUPPLY CURRENT ELECTRICAL CHARACTERISTICS over recommended operating free-air temperature range (unless otherwise noted) PARAMETER IDDZ 8 MIN Full load No load Outputs enabled, no output load, f = 800 MHz for LVPECL outputs, VDD = 3.6 V Supply current IDD TEST CONDITIONS All outputs enabled and terminated with 50 Ω to VDD – 2 V on LVPECL outputs, f = 800 MHz for LVPECL outputs, VDD = 3.3 V Supply current saving per LVPECL output stage disabled, no load f = 800 MHz for LVPECL output, VDD = 3.3 V Supply current, 3-state All outputs in high-impedance state by control logic, f = 0 Hz, VDD = 3.6 V Submit Documentation Feedback TYP MAX UNIT 140 90 mA 0.5 mA 10 Copyright © 2003–2013, Texas Instruments Incorporated Product Folder Links :CDCP1803 CDCP1803 www.ti.com SCAS727F – NOVEMBER 2003 – REVISED DECEMBER 2013 SUPPLY CURRENT vs FREQUENCY 150 I DD − Supply Current − mA VDD = 3.3 V, TA = 255C, 50 W to VDD −2 V for LVPECL 145 3 LVPECL Outputs(P1) Running 140 135 130 100 300 500 700 900 1100 1300 1500 f − Frequency − MHz G003 Figure 4. PACKAGE THERMAL RESISTANCE PARAMETER RθJA-1 QFN-24 package thermal resistance RθJA-2 QFN-24 package thermal resistance with thermal vias in PCB (1) (1) TEST CONDITIONS (1) 4-layer JEDEC test board (JESD51-7), airflow = 0 ft/min 4-layer JEDEC test board (JESD51-7) with four thermal vias of 22-mil diameter each, airflow = 0 ft/min MIN TYP MAX UNIT 106.6 °C/W 55.4 °C/W It is recommended to provide four thermal vias to connect the thermal pad of the package effectively with the PCB and ensure a good heat sink. Example: Calculation of the junction-lead temperature with a 4-layer JEDEC test board using four thermal vias: TChassis = 85°C (temperature of the chassis) Peffective = Imax × Vmax = 90 mA × 3.6 V = 324 mW (max power consumption inside the package) θTJunction = θJA-2 × Peffective = 55.45°C/W × 324 mW = 17.97°C TJunction = θTJunction + TChassis = 17.97°C + 85°C = 103°C (the maximum junction temperature of Tdie-max = 125°C is not violated) Submit Documentation Feedback Copyright © 2003–2013, Texas Instruments Incorporated Product Folder Links :CDCP1803 9 CDCP1803 SCAS727F – NOVEMBER 2003 – REVISED DECEMBER 2013 www.ti.com CONTROL INPUT CHARACTERISTICS over recommended operating free-air temperature range PARAMETER TEST CONDITIONS tsu Setup time, S0, S1, S2, and EN terminals before clock IN th Hold time, S0, S1, S2, and EN terminals after clock IN t(disable) Time between latching the EN low transition and when all outputs are disabled (how much time is required until the outputs turn off) t(enable) Time between latching the EN low-to-high transition and when outputs are enabled based on control settings (how much time passes before the outputs carry valid signals) Rpullup Internal pullup resistor on S[2:0] and EN input VIH(H) Three-level input high, S0, S1, S2, and EN terminals (1) VIL(L) Three-level low, S0, S1, S2, and EN terminals IIH (1) TYP MAX ns 0 ns 42 10 ns 1 μs 60 78 kΩ V 0.1 VDD V –5 μA 85 μA MAX UNIT VI = VDD VI = GND UNIT 25 0.9 VDD Input current, S0, S1, S2, and EN terminals IIL MIN 38 Leaving this terminal floating automatically pulls the logic level high to VDD through an internal pullup resistor of 60 kΩ. BIAS VOLTAGE VBB over operating free-air temperature range PARAMETER VBB TEST CONDITIONS Output reference voltage MIN VDD = 3 V–3.6 V, IBB = –0.2 mA VDD – 1.4 TYP VDD – 1.2 V OUTPUT REFERENCE VOLTAGE (VBB) vs LOAD 4.0 VDD = 3.3 V VBB − Output Reference Voltage − V 3.5 3.0 2.5 2.0 1.5 1.0 0.5 0.0 −5 0 5 10 15 20 25 30 35 I − Load − mA G004 Figure 5. 10 Submit Documentation Feedback Copyright © 2003–2013, Texas Instruments Incorporated Product Folder Links :CDCP1803 CDCP1803 www.ti.com SCAS727F – NOVEMBER 2003 – REVISED DECEMBER 2013 PARAMETER MEASUREMENT INFORMATION IN IN Y0 Y0 tpd(LH1) Y1 Y1 tpd(LH2) Y2 Y2 NOTES: A. Output skew , tsk(o), is calculated as the greater of: − The difference between the fastest and the slowest tpd(LH)n (n = 0…2) − The difference between the fastest and the slowest tpd(HL)n (n = 0…2) B. Part-to-part skew , tsk(pp), is calculated as the greater of: − The difference between the fastest and the slowest tpd(LH)n ( (n = 0…2 for LVPECL across multiple devices − The difference between the fastest and the slowest tpd(HL)n ( (n = 0…2 for LVPECL across multiple devices C. Pulseskew , tsk(p), is calculated as the magnitude of the absolute time difference between the high-to-low (tpd(HL) and the low-to-high (tpd(LH) propagation delays when a single switching input causes one or more outputs to switch, tsk(p) = | tpd(HL) − tpd(LH) |. Pulse skew is sometimes referred to as pulse width distortion or duty cycle skew. T0067-02 Figure 6. Waveforms for Calculation of tsk(o) and tsk(pp) Yn VOH Yn VOL 80% VOUT(pp) 0V 20% |Yn*Yn| tr tf T0058-02 Figure 7. LVPECL Differential Output Voltage and Rise/Fall Time PCB DESIGN FOR THERMAL FUNCTIONALITY It is recommended to take special care of the PCB design for good thermal flow from the QFN 24-terminal package to the PCB. Due to the three LVPECL outputs, the current consumption of the CDCP1803 is fixed. JEDEC JESD51-7 specifies thermal conductivity for standard PCB boards. Submit Documentation Feedback Copyright © 2003–2013, Texas Instruments Incorporated Product Folder Links :CDCP1803 11 CDCP1803 SCAS727F – NOVEMBER 2003 – REVISED DECEMBER 2013 www.ti.com PARAMETER MEASUREMENT INFORMATION (continued) Modeling the CDCP1803 with a standard 4-layer JEDEC board results in a 59.5°C maximum temperature with RθJA of 106.62°C/W for 25°C ambient temperature. When deploying four thermal vias (one per quadrant), the thermal flow improves significantly, yielding 42.9°C maximum temperature with RθJA of 55.4°C/W for 25°C ambient temperature. To ensure sufficient thermal flow, it is recommended to design with four thermal vias in applications enabling all four outputs at once. Package Thermal Pad (Underside) Thermal Via Dia 0.020 In. Top Side Island Heat Dissipation VSS Copper Plane VSS Copper Plane M0029-01 Figure 8. Recommended Thermal Via Placement See the Quad Flatpack No-Lead Logic Packages (SCBA017) and QFN/SON PCB Attachment (SLUA271) application reports for further package-related information. 12 Submit Documentation Feedback Copyright © 2003–2013, Texas Instruments Incorporated Product Folder Links :CDCP1803 CDCP1803 www.ti.com SCAS727F – NOVEMBER 2003 – REVISED DECEMBER 2013 APPLICATION INFORMATION LVPECL RECEIVER INPUT TERMINATION The input of the CDCP1803 has a high impedance and comes with a large common-mode voltage range. For optimized noise performance, it is recommended to properly terminate the PCB trace (transmission line). If a differential signal drives the CDCP1803, then a 100-Ω termination resistor is recommended to be placed as close as possible across the input terminals. An even better approach is to install 2 × 50-Ω resistors, with the center tap connected to a capacitor (C) to terminate odd-mode noise and make up for transmission line mismatches. The VBB output can also be connected to the center tap to bias the input signal to (VDD – 1.3 V) (see Figure 9). CDCP1803 CAC IN 50 Ω LVPECL 50 Ω 150 Ω 50 Ω CAC IN 50 Ω VBB 150 Ω C S0085-02 Figure 9. Recommended AC-Coupling LVPECL Receiver Input Termination CDCP1803 130 Ω IN 50 Ω LVPECL 83 Ω 130 Ω IN 50 Ω 83 Ω S0086-02 Figure 10. Recommended DC-Coupling LVPECL Receiver Input Termination The CDCP1803 can also be driven by single-ended signals. Typically, the input signal becomes connected to one input, while the complementary input must be properly biased to the center voltage of the incoming input signal. For LVCMOS signals, this would be VCC/2, realized by a simple voltage divider (e.g., two 10-kΩ resistors). The best option (especially if the dc offset of the input signal might vary) is to ac-couple the input signal and then rebias the signal using the VBB reference output. See Figure 11. Submit Documentation Feedback Copyright © 2003–2013, Texas Instruments Incorporated Product Folder Links :CDCP1803 13 CDCP1803 SCAS727F – NOVEMBER 2003 – REVISED DECEMBER 2013 www.ti.com CDCP1803 CAC IN CLK Rdc IN VBB CCT NOTE: CAC − AC-coupling capacitor (e.g., 10 nF) CCT − Capacitor keeps voltage at IN constant (e.g., 10 nF) Rdc − Load and correct duty cycle (e.g., 50 Ω) VBB − Bias voltage output S0087-02 Figure 11. Typical Application Setting for Single-Ended Input Signals Driving the CDCP1803 DEVICE BEHAVIOR DURING RESET AND CONTROL-TERMINAL SWITCHING Output Behavior From Enabling the Device (EN = 0 → 1) In disable mode (EN = 0), all output drivers are switched in high-Z mode. The S[2:0] control inputs are also switched off. In the same mode, all flip-flops are reset. The typical current consumption is below 500 μA. When the device is enabled again, it takes typically 1 μs for the settling of the reference voltage and currents. During this time, the outputs Y[2:0] and Y[2:0] drive a high signal. After the settle time, the outputs go into the low state. Due to the synchronization of each output driver signal with the input clock, the state of the waveforms after enabling the device is as shown in Figure 12. The inverting input and output signal is not included. The Y:/1 waveform is the undivided output driver state. 14 Submit Documentation Feedback Copyright © 2003–2013, Texas Instruments Incorporated Product Folder Links :CDCP1803 CDCP1803 www.ti.com SCAS727F – NOVEMBER 2003 – REVISED DECEMBER 2013 1 µs EN IN Y:/1 High-Z Undefined Y:/2 High-Z Undefined Y:/4 High-Z Undefined Low Low Low Signal State After the Device is Enabled (IN = Low) 1 µs Undivided State is Valid After the First Positive Transition of the Input Clock EN IN Y:/1 High-Z Undefined Y:/2 High-Z Undefined Y:/4 High-Z Undefined Low Low Low Signal State After the Device is Enabled (IN = High) T0068-01 Figure 12. Waveforms Submit Documentation Feedback Copyright © 2003–2013, Texas Instruments Incorporated Product Folder Links :CDCP1803 15 CDCP1803 SCAS727F – NOVEMBER 2003 – REVISED DECEMBER 2013 www.ti.com Enabling a Single Output Stage If a single output stage becomes enabled: • Y[2:0] is either low or high (undefined). • Y[2:0] is the inverted signal of Y[2:0]. With the first positive clock transition, the undivided output becomes the input clock state. The divided output states are equal to the actual internal divider. The internal divider is not reset while enabling single output drivers. ENABLE Yx: Disabled Enabled Undivided State is Valid After the First Positive Transition of the Input Clock IN Yx:/1 High-Z Undefined Yx:/x High-Z Undefined Divider State T0069-01 Figure 13. Signal State After an Output Driver Becomes Enabled While IN = 0 ENABLE Yx: Disabled Undivided State is Valid After the First Positive Transition of the Input Clock Enabled IN Yx:/1 High-Z Undefined Yx:/x High-Z Undefined Divider State T0070-01 Figure 14. Signal State After an Output Driver Becomes Enabled While IN = 1 spacer REVISION HISTORY Changes from Revision E (January 2007) to Revision F Page • Changed tsk(pp) Part-to-part skew - included a MAX value of 300 ps .................................................................................... 7 • Changed Note B in Figure 6 From: (n = 0…2 for LVPECL, n = 3 for LVCMOS) To: (n = 0…2 for LVPECLS) across ..... 11 16 Submit Documentation Feedback Copyright © 2003–2013, Texas Instruments Incorporated Product Folder Links :CDCP1803 PACKAGE OPTION ADDENDUM www.ti.com 18-Jan-2017 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan Lead/Ball Finish MSL Peak Temp (2) (6) (3) Op Temp (°C) Device Marking (4/5) CDCP1803RGER ACTIVE VQFN RGE 24 3000 Green (RoHS & no Sb/Br) CU NIPDAU Level-2-260C-1 YEAR -40 to 85 CDCP 1803 CDCP1803RGERG4 ACTIVE VQFN RGE 24 3000 Green (RoHS & no Sb/Br) CU NIPDAU Level-2-260C-1 YEAR -40 to 85 CDCP 1803 CDCP1803RGET ACTIVE VQFN RGE 24 250 Green (RoHS & no Sb/Br) CU NIPDAU Level-2-260C-1 YEAR -40 to 85 CDCP 1803 CDCP1803RGETG4 ACTIVE VQFN RGE 24 250 Green (RoHS & no Sb/Br) CU NIPDAU Level-2-260C-1 YEAR -40 to 85 CDCP 1803 CDCP1803RTHR OBSOLETE VQFN RTH 24 TBD Call TI Call TI -40 to 85 CDCP1803RTHT OBSOLETE VQFN RTH 24 TBD Call TI Call TI -40 to 85 (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) Eco Plan - The planned eco-friendly classification: Pb-Free (RoHS), Pb-Free (RoHS Exempt), or Green (RoHS & no Sb/Br) - please check http://www.ti.com/productcontent for the latest availability information and additional product content details. TBD: The Pb-Free/Green conversion plan has not been defined. Pb-Free (RoHS): TI's terms "Lead-Free" or "Pb-Free" mean semiconductor products that are compatible with the current RoHS requirements for all 6 substances, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, TI Pb-Free products are suitable for use in specified lead-free processes. Pb-Free (RoHS Exempt): This component has a RoHS exemption for either 1) lead-based flip-chip solder bumps used between the die and package, or 2) lead-based die adhesive used between the die and leadframe. The component is otherwise considered Pb-Free (RoHS compatible) as defined above. Green (RoHS & no Sb/Br): TI defines "Green" to mean Pb-Free (RoHS compatible), and free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material) (3) MSL, Peak Temp. - The Moisture Sensitivity Level rating according to the JEDEC industry standard classifications, and peak solder temperature. (4) There may be additional marking, which relates to the logo, the lot trace code information, or the environmental category on the device. (5) Multiple Device Markings will be inside parentheses. Only one Device Marking contained in parentheses and separated by a "~" will appear on a device. If a line is indented then it is a continuation of the previous line and the two combined represent the entire Device Marking for that device. Addendum-Page 1 Samples PACKAGE OPTION ADDENDUM www.ti.com 18-Jan-2017 (6) Lead/Ball Finish - Orderable Devices may have multiple material finish options. Finish options are separated by a vertical ruled line. Lead/Ball Finish values may wrap to two lines if the finish value exceeds the maximum column width. Important Information and Disclaimer:The information provided on this page represents TI's knowledge and belief as of the date that it is provided. TI bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. TI has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. TI and TI suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. In no event shall TI's liability arising out of such information exceed the total purchase price of the TI part(s) at issue in this document sold by TI to Customer on an annual basis. OTHER QUALIFIED VERSIONS OF CDCP1803 : • Enhanced Product: CDCP1803-EP NOTE: Qualified Version Definitions: • Enhanced Product - Supports Defense, Aerospace and Medical Applications Addendum-Page 2 PACKAGE MATERIALS INFORMATION www.ti.com 4-Dec-2013 TAPE AND REEL INFORMATION *All dimensions are nominal Device Package Package Pins Type Drawing SPQ Reel Reel A0 Diameter Width (mm) (mm) W1 (mm) B0 (mm) K0 (mm) P1 (mm) W Pin1 (mm) Quadrant CDCP1803RGER VQFN RGE 24 3000 330.0 12.4 4.3 4.3 1.5 8.0 12.0 Q2 CDCP1803RGET VQFN RGE 24 250 330.0 12.4 4.3 4.3 1.5 8.0 12.0 Q2 Pack Materials-Page 1 PACKAGE MATERIALS INFORMATION www.ti.com 4-Dec-2013 *All dimensions are nominal Device Package Type Package Drawing Pins SPQ Length (mm) Width (mm) Height (mm) CDCP1803RGER VQFN RGE 24 3000 340.5 338.1 20.6 CDCP1803RGET VQFN RGE 24 250 340.5 338.1 20.6 Pack Materials-Page 2 IMPORTANT NOTICE FOR TI DESIGN INFORMATION AND RESOURCES Texas Instruments Incorporated (‘TI”) technical, application or other design advice, services or information, including, but not limited to, reference designs and materials relating to evaluation modules, (collectively, “TI Resources”) are intended to assist designers who are developing applications that incorporate TI products; by downloading, accessing or using any particular TI Resource in any way, you (individually or, if you are acting on behalf of a company, your company) agree to use it solely for this purpose and subject to the terms of this Notice. TI’s provision of TI Resources does not expand or otherwise alter TI’s applicable published warranties or warranty disclaimers for TI products, and no additional obligations or liabilities arise from TI providing such TI Resources. TI reserves the right to make corrections, enhancements, improvements and other changes to its TI Resources. You understand and agree that you remain responsible for using your independent analysis, evaluation and judgment in designing your applications and that you have full and exclusive responsibility to assure the safety of your applications and compliance of your applications (and of all TI products used in or for your applications) with all applicable regulations, laws and other applicable requirements. You represent that, with respect to your applications, you have all the necessary expertise to create and implement safeguards that (1) anticipate dangerous consequences of failures, (2) monitor failures and their consequences, and (3) lessen the likelihood of failures that might cause harm and take appropriate actions. You agree that prior to using or distributing any applications that include TI products, you will thoroughly test such applications and the functionality of such TI products as used in such applications. TI has not conducted any testing other than that specifically described in the published documentation for a particular TI Resource. You are authorized to use, copy and modify any individual TI Resource only in connection with the development of applications that include the TI product(s) identified in such TI Resource. NO OTHER LICENSE, EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE TO ANY OTHER TI INTELLECTUAL PROPERTY RIGHT, AND NO LICENSE TO ANY TECHNOLOGY OR INTELLECTUAL PROPERTY RIGHT OF TI OR ANY THIRD PARTY IS GRANTED HEREIN, including but not limited to any patent right, copyright, mask work right, or other intellectual property right relating to any combination, machine, or process in which TI products or services are used. Information regarding or referencing third-party products or services does not constitute a license to use such products or services, or a warranty or endorsement thereof. Use of TI Resources may require a license from a third party under the patents or other intellectual property of the third party, or a license from TI under the patents or other intellectual property of TI. TI RESOURCES ARE PROVIDED “AS IS” AND WITH ALL FAULTS. TI DISCLAIMS ALL OTHER WARRANTIES OR REPRESENTATIONS, EXPRESS OR IMPLIED, REGARDING TI RESOURCES OR USE THEREOF, INCLUDING BUT NOT LIMITED TO ACCURACY OR COMPLETENESS, TITLE, ANY EPIDEMIC FAILURE WARRANTY AND ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. TI SHALL NOT BE LIABLE FOR AND SHALL NOT DEFEND OR INDEMNIFY YOU AGAINST ANY CLAIM, INCLUDING BUT NOT LIMITED TO ANY INFRINGEMENT CLAIM THAT RELATES TO OR IS BASED ON ANY COMBINATION OF PRODUCTS EVEN IF DESCRIBED IN TI RESOURCES OR OTHERWISE. IN NO EVENT SHALL TI BE LIABLE FOR ANY ACTUAL, DIRECT, SPECIAL, COLLATERAL, INDIRECT, PUNITIVE, INCIDENTAL, CONSEQUENTIAL OR EXEMPLARY DAMAGES IN CONNECTION WITH OR ARISING OUT OF TI RESOURCES OR USE THEREOF, AND REGARDLESS OF WHETHER TI HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. You agree to fully indemnify TI and its representatives against any damages, costs, losses, and/or liabilities arising out of your noncompliance with the terms and provisions of this Notice. This Notice applies to TI Resources. Additional terms apply to the use and purchase of certain types of materials, TI products and services. These include; without limitation, TI’s standard terms for semiconductor products http://www.ti.com/sc/docs/stdterms.htm), evaluation modules, and samples (http://www.ti.com/sc/docs/sampterms.htm). Mailing Address: Texas Instruments, Post Office Box 655303, Dallas, Texas 75265 Copyright © 2017, Texas Instruments Incorporated
CDCP1803RTHR
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一个高增益光晶体管输出的光耦器件,具有快速响应时间和高输入输出隔离电压。
3. 引脚分配:EL817有6个引脚,包括发光二极管的阳极、阴极和光晶体管的集电极、发射极、基极和电源引脚。
4. 参数特性:包括最大正向电流、最大反向电压、最大功率耗散等。
5. 功能详解:EL817通过输入电流控制发光二极管发光,光晶体管根据接收到的光信号导通或截止。
6. 应用信息:广泛应用于隔离电源、信号隔离、高速通信接口等。
7. 封装信息:EL817采用DIP-6封装。
CDCP1803RTHR 价格&库存
很抱歉,暂时无法提供与“CDCP1803RTHR”相匹配的价格&库存,您可以联系我们找货
