CDCR83A
www.ti.com
SCAS811 – AUGUST 2005
DIRECT RAMBUS™ CLOCK GENERATOR
FEATURES
400-MHz Differential Clock Source for Direct
Rambus™ Memory Systems for an 800-MHz
Data Transfer Rate
Fail-Safe Power Up Initialization
Synchronizes the Clock Domains of the
Rambus Channel With an External System or
Processor Clock
Three Power Operating Modes to Minimize
Power for Mobile and Other Power-Sensitive
Applications
Operates From a Single 3.3-V Supply and
120 mW at 300 MHz (Typ)
Packaged in a Shrink Small-Outline Package
(DBQ)
Supports Frequency Multipliers: 4, 6, 8, 16/3
No External Components Required for PLL
Supports Independent Channel Clocking
Spread Spectrum Clocking Tracking
Capability to Reduce EMI
Designed for Use With TI's 133-MHz Clock
Synthesizers CDC924 and CDC921
Cycle-Cycle Jitter Is Less Than 50 ps at
400 MHz
Certified by Gigatest Labs to Exceed the
Rambus DRCG Validation Requirement
Supports Industrial Temperature Range of
–40°C to 85°C
DBQ PACKAGE
(TOP VIEW)
VDDIR
REFCLK
VDDP
GNDP
GNDI
PCLKM
SYNCLKN
GNDC
VDDC
VDDIPD
STOPB
PWRDNB
1
24
2
23
3
22
4
21
5
19
7
18
8
17
9
16
10
15
11
14
12
13
S0
S1
VDDO
GNDO
CLK
NC
CLKB
GNDO
VDDO
MULT0
MULT1
S2
NC − No internal connection
DESCRIPTION
The Direct Rambus clock generator (DRCG) provides the necessary clock signals to support a Direct Rambus
memory subsystem. It includes signals to synchronize the Direct Rambus channel clock to an external system or
processor clock. It is designed to support Direct Rambus memory on a desktop, workstation, server, and mobile
PC motherboards. DRCG also provides an off-the-shelf solution for a broad range of Direct Rambus memory
applications.
The DRCG provides clock multiplication and phase alignment for a Direct Rambus memory subsystem to enable
synchronous communication between the Rambus channel and ASIC clock domains. In a Direct Rambus
memory subsystem, a system clock source provides the REFCLK and PCLK clock references to the DRCG and
memory controller, respectively. The DRCG multiplies REFCLK and drives a high-speed BUSCLK to RDRAMs
and the memory controller. Gear ratio logic in the memory controller divides the PCLK and BUSCLK frequencies
by ratios M and N such that PCLKM = SYNCLKN, where SYNCLK = BUSCLK/4. The DRCG detects the phase
difference between PCLKM and SYNCLKN and adjusts the phase of BUSCLK such that the skew between
PCLKM and SYNCLKN is minimized. This allows data to be transferred across the SYNCLK/PCLK boundary
without incurring additional latency.
Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas
Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet.
DIRECT RAMBUS, Rambus are trademarks of Rambus Inc.
PRODUCTION DATA information is current as of publication date.
Products conform to specifications per the terms of the Texas
Instruments standard warranty. Production processing does not
necessarily include testing of all parameters.
Copyright © 2005, Texas Instruments Incorporated
CDCR83A
www.ti.com
User control is provided by multiply and mode selection terminals. The multiply terminals provide selection of one
of four clock frequency multiply ratios, generating BUSCLK frequencies ranging from 267 MHz to 400 MHz with
clock references ranging from 33 MHz to 100 MHz. The mode select terminals can be used to select a bypass
mode where the frequency multiplied reference clock is directly output to the Rambus channel for systems where
synchronization between the Rambus clock and a system clock is not required. Test modes are provided to
bypass the PLL and output REFCLK on the Rambus channel and to place the outputs in a high-impedance state
for board testing.
The CDCR83A has a fail-safe power up initialization state-machine which supports proper operation under all
power up conditions.
The CDCR83A is characterized for operation over free-air temperatures of –40°C to 85°C.
FUNCTIONAL BLOCK DIAGRAM
PWRDWNB
S0
S1
S2
STOPB
Test MUX
Bypass MUX
ByPCLK
PLLCLK
CLK
PLL
Phase
Aligner
B
REFCLK
A
CLKB
PACLK
φD
2
PCLKM
MULT0
MULT1
SYNCLKN
FUNCTION TABLE (1)
S0
S1
S2
CLK
CLKB
Normal
MODE
Phase aligned clock
Phase aligned clock B
Bypass
1
PLLCLK
PLLCLKB
Test
1
1
REFCLK
REFCLKB
Output test (OE)
x
Hi-Z
Hi-Z
Reserved
Reserved
1
Reserved
1
1
1
Hi-Z
Hi-Z
(1)
2
X = don't care, Hi-Z = high impedance
CDCR83A
www.ti.com
TERMINAL FUNCTIONS
TERMINAL
NAME
NO.
I/O
DESCRIPTION
CLK
O
Output clock
CLKB
18
O
Output clock (complement)
GNDC
8
GND for phase aligner
GNDI
5
GND for control inputs
GNDO
17, 21
GND for clock outputs
GNDP
4
MULT0
15
I
PLL multiplier select
MULT1
14
I
NC
19
GND for PLL
Not used
PCLKM
6
I
Phase detector input
PWRDNB
12
I
Active low power down
REFCLK
2
I
Reference clock
S0
24
I
Mode control
S1
23
I
Mode control
S2
13
I
Mode control
STOPB
11
I
Active low output disable
SYNCLKN
7
I
VDDC
9
VDD for phase aligner
VDDIPD
10
Reference voltage for phase detector inputs and STOPB
VDDIR
1
Reference voltage for REFCLK
VDDO
16, 22
VDDP
3
VDD for clock outputs
VDD for PLL
3
CDCR83A
www.ti.com
PLL DIVIDER SELECTION
Table 1 lists the supported REFCLK and BUSCLK frequencies. Other REFCLK frequencies are permitted,
provided that (267 MHz < BUSCLK < 400 MHz) and (33 MHz < REFCLK < 100 MHz).
Table 1. REFCLK and BUSCLK Frequencies
MULT0
MULT1
REFCLK
(MHz)
MULTIPLY
RATIO
BUSCLK (1)
(MHz)
4
267
50
6
300
67
6
400
1
1
33
8
267
1
1
50
8
400
1
16/3
356
(1)
BUSCLK will be undefined until a valid reference clock is available at REFCLK. After applying
REFCLK, the PLL requires stabilization time to achieve phase lock.
Table 2. Clock Output Driver States
STATE
PWRDNB
STOPB
CLK
Powerdown
X
GND
CLK stop
1
Normal
1
1
(1)
VX,
CLKB
GND
VX,
STOP
PACLK/PLLCLK/REFCLK (1)
STOP
PACLKB/PLLCLKB/REFCLKB
Depending on the state of S0, S1, and S2
ABSOLUTE MAXIMUM RATINGS
over operating free-air temperature range (unless otherwise noted) (1)
UNIT
VDD
Supply voltage range (2)
VO
Output voltage range at any output terminal
VI
Input voltage rangeat any input terminal
–0.5 V to 4 V
–0.5 V to VDD + 0.5 V
Continuous total power dissipation
See Dissipation Rating Table
TA
Operating free-air temperature range
–40°C to 85°C
Tstg
Storage temperature range
–65°C to 150°C
Lead temperature 1,6 mm (1/16 inch) from case for 10 seconds
(1)
(2)
260°C
Stresses beyond those listed under absolute maximum ratings may cause permanent damage to the device. These are stress ratings
only, and functional operation of the device at these or any other conditions beyond those indicated under recommended operating
conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability.
All voltage values are with respect to the GND terminals.
DISSIPATION RATINGS
(1)
4
PACKAGE
TA≤ 25°C
POWER RATING
DERATING FACTOR
ABOVE TA = 25°C (1)
TA = 70°C
POWER RATING
TA = 85°C
POWER RATING
DBQ
1400 mW
11 mW/°C
905 mW
740 mW
This is the inverse of the junction-to-ambient thermal resistance when board-mounted and with no air flow.
CDCR83A
www.ti.com
RECOMMENDED OPERATING CONDITIONS
VDD
Supply voltage
VIH
High-level input voltage (CMOS)
VIL
Low-level input voltage (CMOS)
Initial phase error at phase detector inputs
(required range for phase aligner)
VIL
REFCLK low-level input voltage
VIH
REFCLK high-level input voltage
VIL
Input signal low voltage (STOPB)
VIH
Input signal high voltage (STOPB)
MIN
NOM
MAX
UNIT
3.135
3.3
3.465
V
0.7 × VDD
V
0.3 × VDD
V
0.5 × tc(PD)
V
0.3 × VDDIR
V
–0.5 × tc(PD)
0.7 × VDDIR
V
0.3 × VDDIPD
0.7 × VDDIPD
V
Input reference voltage for (REFCLK) (VDDIR)
1.235
3.465
Input reference voltage for (PCLKM and SYSCLKN) (VDDIPD)
1.235
3.465
IOH
High-level output current
IOL
Low-level output current
TA
V
–40
V
V
–16
mA
16
mA
85
°C
TIMING REQUIREMENTS
tc(in)
Input cycle time
MIN
MAX
10
40
ns
250
ps
Input cycle-to-cycle jitter
Input duty cycle over 10,000 cycles
fmod
Input frequency modulation,
40%
30
Modulation index, nonlinear maximum 0.5%
Phase detector input cycle time (PCLKM and SYNCLKN)
SR
Input slew rate
Input duty cycle (PCLKM and SYNCLKN)
UNIT
60%
33
kHz
0.6%
30
100
1
4
25%
75%
ns
V/ns
5
CDCR83A
www.ti.com
ELECTRICAL CHARACTERISTICS
over recommended operating free-air temperature range (unless otherwise noted)
TEST CONDITIONS (1)
PARAMETER
MIN TYP (2)
MAX
UNIT
VO(STOP)
Output voltage during CLK Stop (STOPB = 0)
See Figure 1
1.1
2
VO(X)
Output crossing-point voltage
See Figure 1 and Figure 6
1.3
1.8
V
VO
Output voltage swing
See Figure 1
0.4
0.6
V
VIK
Input clamp voltage
VDD = 3.135 V,
–1.2
V
II = –18 mA
See Figure 1
VOH
High-level output voltage
2
VDD = min to max,
IOH = –1 mA
VDD = 3.135 V,
IOH = –16 mA
See Figure 1
VOL
Low-level output voltage
IOH
VDD = min to max,
IOH = 1 mA
0.1
VDD = 3.135 V,
IOH = 16 mA
0.5
VDD = 3.135 V,
VO = 1 V
VDD = 3.3 V,
VO = 1.65 V
VDD = 3.465 V,
VO = 3.135 V
VDD = 3.135 V,
VO = 1.95 V
VDD = 3.3 V,
VO = 1.65 V
VDD = 3.465 V,
VO = 0.4 V
IOZ
High-impedance-state output current
S0 = 0, S1 = 1
IOZ(STOP)
High-impedance-state output current during
CLK stop
Stop = 0, VO = GND or VDD
IOZ(PD)
High-impedance-state output current in
power-down state
PWRDNB = 0, VO = GND or VDD
IIH
High-level input
current
Low-level input
current
IIL
ZO
Output impedance
Reference current
PWRDNB, S0, S1,
S2, MULT0, MULT1
REFCLK, PCLKM,
SYNCLKN, STOPB
PWRDNB, S0, S1,
S2, MULT0, MULT1
V
2.4
1
IOL
REFCLK, PCLKM,
SYNCLKN, STOPB
VDD– 0.1
–32
–52
–51
–14.5
43
V
mA
–21
61.5
65
25.5
–10
mA
36
±10
µA
±100
µA
100
µA
10
VDD = 3.465 V,
µA
VI = VDD
10
–10
VDD = 3.465 V,
µA
VI = 0
–10
High state
RI at IO– 14.5 mA to –16.5 mA
15
35
50
Low state
RI at IO 14.5 mA to 16.5 mA
11
17
35
VDDIR, VDDIPD
VDD = 3.465 V
Ω
PWRDNB = 0
50
µA
PWRDNB = 1
0.5
mA
CI
Input capacitance
VI = VDD or GND
2
pF
CO
Output capacitance
VO = VDD or GND
3
pF
IDD(PD)
Supply current in pwoer-down state
REFCLK = 0 MHz to 100 MHz,
PWDNB = 0, STOPB = 1
IDD(CLKSTOP)
Supply current in CLK stop state
IDD(NORMAL)
Supply current in normal state
(1)
(2)
6
100
µA
BUSCLK configured for 400 MHz
30
mA
BUSCLK = 400 MHz
70
mA
VDD refers to any of the following; VDD, VDDIPD, VDDIR, VDDO, VDDC, and VDDP
All typical values are at VDD = 3.3 V, TA = 25°C.
CDCR83A
www.ti.com
SWITCHING CHARACTERISTICS
PARAMETER
tc(out)
TEST CONDITIONS
Clock output cycle time
MIN
2.5
267 MHz
t(jitter)
Total cycle jitter over 1, 2,
3, 4, 5, or 6 clock cycles
Infinite and stopped
phase alignment
300 MHz
356 MHz
Phase detector phase error for distributed loop
Output duty cycle over 10,000 cycles
t(DC,
err)
phase alignment
300 MHz
356 MHz
ps
50
error (2)
–100
100
ps
Dynamic phase error (2)
–100
100
ps
See Figure 4
45%
55%
80
70
See Figure 5
60
400 MHz
ps
50
tr, tf
Output rise and fall times (measured at 20%–80% of output
voltage)
See Figure 7
∆t
Difference between rise and fall times on a single device
(20%–80%) |tf– tr|
See Figure 7
(1)
(2)
ns
60
267 MHz
Output cycle-to-cycle duty
cycle error
UNIT
3.75
70
See Figure 3
Static phase
t(phase, SSC) PLL output phase error when tracking SSC
MAX
80
400 MHz
t(phase)
TYP (1)
160
400
ps
100
ps
Assured by design
STATE TRANSITION LATENCY SPECIFICATIONS
PARAMETER
t(powerup)
Delay time, PWRDNB↑ to CLK/CLKB output settled (excluding t(DISTLOCK))
Delay time, PWRDNB↑ to internal PLL and
clock are on and settled
t(VDDpowerup)
Delay time, power up to CLK/CLKB output
settled
Delay time, power up to internal PLL and
t(MULT)
MULT0 and MULT1 change to CLK/CLKB
output resettled (excluding t(DISTLOCK))
t(CLKON)
t(CLKSETL)
FROM
TO
Powerdown
Normal
TEST
CONDITIONS
See Figure 8
3
See Figure 8
VDD
3
Normal
ms
3
STOPB↑ to CLK/CLKB glitch-free clock
edges
CLK Stop
Normal
STOPB↑ to CLK/CLKB output settled to
within
50 ps of the phase before STOPB was
disabled
CLK Stop
Normal
t(CLKOFF)
STOPB↓ to CLK/CLKB output disabled
Normal
CLK Stop
t(powerdown)
Delay time, PWRDNB↓ to the device in the
power-down mode
Normal
t(STOP)
Maximum time in CLKSTOP (STOPB = 0)
before reentering normal mode
(STOPB = 1)
STOPB
Normal
See Figure 10
Minimum time in normal mode
(STOPB = 1) before reentering CLKSTOP
(STOPB = 0)
Normal
CLK Stop
See Figure 10
Time from when CLK/CLKB output is
settled to when the phase error between
SYNCLKN and PCLKM falls within t(phase)
Unlocked
Locked
(1)
UNIT
ms
Normal
t(DISTLOCK)
TYP (1) MAX
3
Normal
t(ON)
MIN
See Figure 9
1
ms
10
ns
See Figure 10
cycles
See Figure 10
5
ns
1
ms
100
µs
See Figure 10
Powerdown See Figure 8
100
ms
5
ms
7
CDCR83A
www.ti.com
PARAMETER MEASUREMENT INFORMATION
68 Ω, ±5%
39 Ω, ±5%
10 pF
39 Ω, ±5%
68 Ω, ±5%
RT = 28 Ω
RT = 28 Ω
100 pF
10 pF
Figure 1. Test Load and Voltage Definitions (VO(STOP), VO(X), VO, VOH, VOL)
CLK
CLKB
tc(1)
tc(2)
Cycle-to-cycle jitter = | tc(1) − tc(2)| over 10000 consecutive cycles
Figure 2. Cycle-to-Cycle Jitter
CLK
CLKB
tc(3)
tc(4)
Cycle-to-cycle jitter = | tc(3) − tc(4)| over 10000 consecutive cycles
Figure 3. Short Term Cycle-to-Cycle Jitter Over Four Cycles
CLK
CLKB
tpd(1)
tc(5)
Duty cycle = (tpd(1)/tc(5))
Figure 4. Output Duty Cycle
8
CDCR83A
www.ti.com
PARAMETER MEASUREMENT INFORMATION (continued)
CLK
CLKB
tpd(2)
tpd(3)
tc(6)
tc(7)
Duty cycle error = tpd(2) − tpd(3)
Figure 5. Duty Cycle Error (Cycle-to-Cycle)
CLK
VO(X)+
VO(X), nom
VO(X)−
CLKB
Figure 6. Crossing-Point Voltage
VOH
80%
20%
VOL
tr
tf
Figure 7. Voltage Waveforms
PWRDNB
CLK/CLKB
t(power up)
t(power down)
Figure 8. PWRDNB Transition Timings
MULT0 and/or
MULT1
CLK/CLKB
t(MULT)
Figure 9. MULT Transition Timings
9
CDCR83A
www.ti.com
t(ON)
t(STOP)
STOPB
t(CLKSETL)
t(CLKON)
(see Note A)
CLK/CLKB
Output clock
not specified
glitches ok
A.
Clock enabled
and glitch free
Clock output settled
within 50 ps of the
phase before disabled
Vref = VO± 200 mV
Figure 10. STOPB Transition Timings
10
t(CLKOFF)
(see Note A)
PACKAGE OPTION ADDENDUM
www.ti.com
11-Apr-2013
PACKAGING INFORMATION
Orderable Device
Status
(1)
Package Type Package Pins Package
Drawing
Qty
Eco Plan
Lead/Ball Finish
(2)
MSL Peak Temp
Op Temp (°C)
Top-Side Markings
(3)
(4)
CDCR83ADBQ
ACTIVE
SSOP
DBQ
24
50
Green (RoHS
& no Sb/Br)
CU NIPDAU
Level-2-260C-1 YEAR
-40 to 85
CDCR83A
CDCR83ADBQG4
ACTIVE
SSOP
DBQ
24
50
Green (RoHS
& no Sb/Br)
CU NIPDAU
Level-2-260C-1 YEAR
-40 to 85
CDCR83A
CDCR83ADBQR
ACTIVE
SSOP
DBQ
24
2500
Green (RoHS
& no Sb/Br)
CU NIPDAU
Level-2-260C-1 YEAR
-40 to 85
CDCR83A
CDCR83ADBQRG4
ACTIVE
SSOP
DBQ
24
2500
Green (RoHS
& no Sb/Br)
CU NIPDAU
Level-2-260C-1 YEAR
-40 to 85
CDCR83A
(1)
The marketing status values are defined as follows:
ACTIVE: Product device recommended for new designs.
LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect.
NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design.
PREVIEW: Device has been announced but is not in production. Samples may or may not be available.
OBSOLETE: TI has discontinued the production of the device.
(2)
Eco Plan - The planned eco-friendly classification: Pb-Free (RoHS), Pb-Free (RoHS Exempt), or Green (RoHS & no Sb/Br) - please check http://www.ti.com/productcontent for the latest availability
information and additional product content details.
TBD: The Pb-Free/Green conversion plan has not been defined.
Pb-Free (RoHS): TI's terms "Lead-Free" or "Pb-Free" mean semiconductor products that are compatible with the current RoHS requirements for all 6 substances, including the requirement that
lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, TI Pb-Free products are suitable for use in specified lead-free processes.
Pb-Free (RoHS Exempt): This component has a RoHS exemption for either 1) lead-based flip-chip solder bumps used between the die and package, or 2) lead-based die adhesive used between
the die and leadframe. The component is otherwise considered Pb-Free (RoHS compatible) as defined above.
Green (RoHS & no Sb/Br): TI defines "Green" to mean Pb-Free (RoHS compatible), and free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight
in homogeneous material)
(3)
MSL, Peak Temp. -- The Moisture Sensitivity Level rating according to the JEDEC industry standard classifications, and peak solder temperature.
(4)
Multiple Top-Side Markings will be inside parentheses. Only one Top-Side Marking contained in parentheses and separated by a "~" will appear on a device. If a line is indented then it is a
continuation of the previous line and the two combined represent the entire Top-Side Marking for that device.
Important Information and Disclaimer:The information provided on this page represents TI's knowledge and belief as of the date that it is provided. TI bases its knowledge and belief on information
provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. TI has taken and
continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals.
TI and TI suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release.
In no event shall TI's liability arising out of such information exceed the total purchase price of the TI part(s) at issue in this document sold by TI to Customer on an annual basis.
Addendum-Page 1
Samples
www.ti.com
11-Apr-2013
Addendum-Page 2
PACKAGE MATERIALS INFORMATION
www.ti.com
16-Aug-2012
TAPE AND REEL INFORMATION
*All dimensions are nominal
Device
CDCR83ADBQR
Package Package Pins
Type Drawing
SSOP
DBQ
24
SPQ
Reel
Reel
A0
Diameter Width (mm)
(mm) W1 (mm)
2500
330.0
16.4
Pack Materials-Page 1
6.5
B0
(mm)
K0
(mm)
P1
(mm)
9.0
2.1
8.0
W
Pin1
(mm) Quadrant
16.0
Q1
www.ti.com
16-Aug-2012
Device
Package Type
Package Drawing
Pins
SPQ
Length (mm)
Width (mm)
Height (mm)
CDCR83ADBQR
SSOP
DBQ
24
2500
367.0
367.0
38.0
Pack Materials-Page 2
IMPORTANT NOTICE
Texas Instruments Incorporated and its subsidiaries (TI) reserve the right to make corrections, enhancements, improvements and other
changes to its semiconductor products and services per JESD46, latest issue, and to discontinue any product or service per JESD48, latest
issue. Buyers should obtain the latest relevant information before placing orders and should verify that such information is current and
complete. All semiconductor products (also referred to herein as “components”) are sold subject to TI’s terms and conditions of sale
supplied at the time of order acknowledgment.
TI warrants performance of its components to the specifications applicable at the time of sale, in accordance with the warranty in TI’s terms
and conditions of sale of semiconductor products. Testing and other quality control techniques are used to the extent TI deems necessary
to support this warranty. Except where mandated by applicable law, testing of all parameters of each component is not necessarily
performed.
TI assumes no liability for applications assistance or the design of Buyers’ products. Buyers are responsible for their products and
applications using TI components. To minimize the risks associated with Buyers’ products and applications, Buyers should provide
adequate design and operating safeguards.
TI does not warrant or represent that any license, either express or implied, is granted under any patent right, copyright, mask work right, or
other intellectual property right relating to any combination, machine, or process in which TI components or services are used. Information
published by TI regarding third-party products or services does not constitute a license to use such products or services or a warranty or
endorsement thereof. Use of such information may require a license from a third party under the patents or other intellectual property of the
third party, or a license from TI under the patents or other intellectual property of TI.
Reproduction of significant portions of TI information in TI data books or data sheets is permissible only if reproduction is without alteration
and is accompanied by all associated warranties, conditions, limitations, and notices. TI is not responsible or liable for such altered
documentation. Information of third parties may be subject to additional restrictions.
Resale of TI components or services with statements different from or beyond the parameters stated by TI for that component or service
voids all express and any implied warranties for the associated TI component or service and is an unfair and deceptive business practice.
TI is not responsible or liable for any such statements.
Buyer acknowledges and agrees that it is solely responsible for compliance with all legal, regulatory and safety-related requirements
concerning its products, and any use of TI components in its applications, notwithstanding any applications-related information or support
that may be provided by TI. Buyer represents and agrees that it has all the necessary expertise to create and implement safeguards which
anticipate dangerous consequences of failures, monitor failures and their consequences, lessen the likelihood of failures that might cause
harm and take appropriate remedial actions. Buyer will fully indemnify TI and its representatives against any damages arising out of the use
of any TI components in safety-critical applications.
In some cases, TI components may be promoted specifically to facilitate safety-related applications. With such components, TI’s goal is to
help enable customers to design and create their own end-product solutions that meet applicable functional safety standards and
requirements. Nonetheless, such components are subject to these terms.
No TI components are authorized for use in FDA Class III (or similar life-critical medical equipment) unless authorized officers of the parties
have executed a special agreement specifically governing such use.
Only those TI components which TI has specifically designated as military grade or “enhanced plastic” are designed and intended for use in
military/aerospace applications or environments. Buyer acknowledges and agrees that any military or aerospace use of TI components
which have not been so designated is solely at the Buyer's risk, and that Buyer is solely responsible for compliance with all legal and
regulatory requirements in connection with such use.
TI has specifically designated certain components as meeting ISO/TS16949 requirements, mainly for automotive use. In any case of use of
non-designated products, TI will not be responsible for any failure to meet ISO/TS16949.
Products
Applications
Audio
www.ti.com/audio
Automotive and Transportation
www.ti.com/automotive
Amplifiers
amplifier.ti.com
Communications and Telecom
www.ti.com/communications
Data Converters
dataconverter.ti.com
Computers and Peripherals
www.ti.com/computers
DLP® Products
www.dlp.com
Consumer Electronics
www.ti.com/consumer-apps
DSP
dsp.ti.com
Energy and Lighting
www.ti.com/energy
Clocks and Timers
www.ti.com/clocks
Industrial
www.ti.com/industrial
Interface
interface.ti.com
Medical
www.ti.com/medical
Logic
logic.ti.com
Security
www.ti.com/security
Power Mgmt
power.ti.com
Space, Avionics and Defense
www.ti.com/space-avionics-defense
Microcontrollers
microcontroller.ti.com
Video and Imaging
www.ti.com/video
RFID
www.ti-rfid.com
OMAP Applications Processors
www.ti.com/omap
TI E2E Community
e2e.ti.com
Wireless Connectivity
www.ti.com/wirelessconnectivity
Mailing Address: Texas Instruments, Post Office Box 655303, Dallas, Texas 75265
Copyright © 2014, Texas Instruments Incorporated
