SLK2721
www.ti.com
SLLS532B – JUNE 2002 – REVISED MARCH 2007
OC-48+FEC/24/12/3 SONET/SDH MULTIRATE TRANSCEIVER
WITH ENHANCED JITTER TOLERANCE
FEATURES
Fully Integrated SONET/SDH Transceiver to
Support Clock/Data Recovery and
Multiplexer/Demultiplexer Functions
Enhanced Jitter Tolerance Over SLK2701
Supports 2.7 Gbps OC-48 FEC Rate, OC-48,
OC-24, OC-12, Gigabit Ethernet, and OC-3
Data Rate With Autorate Detection
Supports Transmit Only, Receiver Only,
Transceiver and Repeater Functions in a
Single Chip Through Configuration Pins
Supports SONET/SDH Frame Detection
On-Chip PRBS Generation and Verification
Supports 4-Bit LVDS (OIF99.102) Electrical
Interface
Single 2.5-V Power Supply
Interfaces to Back Plane, Copper Cables, or
Optical Modules
Hot Plug Protection
Low Jitter PECL-Compatible Differential Serial
Interface With Programmable De-Emphasis for
the Serial Output
On-Chip Termination for LVDS and
PECL-Compatible Interface
Receiver Differential Input Thresholds 150 mV
Minimum
Supports SONET Loop Timing
Low Power 2 kV
622-MHz Reference Clock
Maintains Clock Output in Absence of Data
Local and Remote Loopback
Parity Checking and Generation for the LVDS
Interface
100-Pin PZP Package With PowerPAD™
Design
DESCRIPTION
The SLK2721 device is a single chip, multirate transceiver that derives high-speed timing signals for SONET/
SDH-based equipment. The device performs clock and data recovery, serial-to-parallel/parallel-to-serial
conversion, and a frame detection function conforming to the SONET/SDH standards.
The device can be configured to operate under OC-48, OC-24, OC-12, or OC-3 data rate through the rate
selection pins or the autorate detection function. An external reference clock operating at 622.08 MHz is
required for the recovery loop, and it also provides a stable clock source in the absence of serial data
transitions.
The SLK2721 device accepts 4-bit LVDS parallel data/clock and generates a NRZ SONET/SDH-compliant signal
at the OC-3, OC-12, OC-24, or OC-48 data rate. It also recovers the data and clock from the serial SONET
stream and demultiplexes it into 4-bit LVDS parallel data for full duplex operation. TXDATA0 and RXDATA0 are
the first bits that are transmitted and received in time, respectively. The serial interface is a low jitter,
PECL-compatible differential interface.
The SLK2721 device supports an FEC data rate up to 2.7 Gbps when configured to operate at the OC-48 data
rate and provided with an external reference clock that is properly scaled.
AVAILABLE OPTIONS
TA
–40°C to 85°C
(1)
PACKAGE (1)
PowerPAD QUAD (PZP)
SLK2721IPZP
For the most current package and ordering information, see the Package Option Addendum at the end
of this document, or see the TI Web site at www.ti.com.
Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas
Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet.
PowerPAD is a trademark of Texas Instruments.
PRODUCTION DATA information is current as of publication date.
Products conform to specifications per the terms of the Texas
Instruments standard warranty. Production processing does not
necessarily include testing of all parameters.
Copyright © 2002–2007, Texas Instruments Incorporated
SLK2721
www.ti.com
These devices have limited built-in ESD protection. The leads should be shorted together or the device placed in conductive foam
during storage or handling to prevent electrostatic damage to the MOS gates.
DESCRIPTION (CONTINUED)
The SLK2721 device provides a comprehensive suite of built-in tests for self-test purposes including local and
remote loopback and pseudorandom bit stream (PRBS) (27-1) generation and verification.
The device comes in a 100-pin VQFP package that requires a single 2.5-V supply with 3.3-V tolerant inputs on
the control pins. The SLK2721 device is very power efficient, dissipating less than 900 mW at 2.488 Gbps, the
OC-48 data rate. It is characterised for operation from –40°C to 85°C.
BLOCK DIAGRAM
2
Submit Documentation Feedback
SLK2721
www.ti.com
3
SLK2721
www.ti.com
TERMINAL FUNCTIONS
TERMINAL
NAME
NO.
TYPE
DESCRIPTION
CLOCK PINS
REFCLKP
REFCLKN
94
95
LVDS/PECL
compatible input
Differential reference input clock. There is an on-chip 100-Ω termination resistor
differentially placed between REFCLKP and REFCLKN. The dc bias is also provided
on-chip for the ac-coupled case.
RXCLKP
RXCLKN
67
68
LVDS output
Receive data clock. The data on RXDATA(0:3) is on the falling edges of RXCLKP. The
interface of RXDATA(0:3) and RXCLKP is source synchronous (see Figure 6).
TXCLKP
TXCLKN
79
80
LVDS input
Transmit data clock. The data on TXDATA(0:3) is latched on the rising edge of
TXCLKP.
TXCLKSRCP
TXCLKSRCN
70
71
LVDS output
Transmit clock source. A clock source generated from the SLK2721 device to the
downstream device (i.e., framer) that could be used by the downstream device to
transmit data back to the SLK2721 device. This clock is frequency-locked to the local
reference clock.
SERIAL SIDE DATA PINS
SRXDIP
SRXDIN
14
15
PECL compatible
input
Receive differential pairs; high-speed serial inputs
STXDOP
STXDON
9
8
PECL compatible
output
Transmit differential pairs; high-speed serial outputs
73
74
LVDS output
Frame sync pulse. This signal indicates the frame boundaries of the incoming data
stream. If the frame-detect circuit is enabled, FSYNC pulses for four RXCLKP and
RXCLKN clock cycles, when it detects the framing patterns.
66-63
60-57
LVDS output
Receive data pins. Parallel data on this bus is valid on the falling edge of RXCLKP
(refer to Figure 6). RXDATA0 is the first bit received in time.
56
55
LVDS output
Receive data parity output
88-81
LVDS input
Transmit data pins. Parallel data on this bus is clocked on the rising edge of TXCLKP.
TXDATA0 is the first bit transmitted in time.
99
98
LVDS input
Transmit data parity input
PARALLEL SIDE DATA PINS
FSYNCP
FSYNCN
RXDATA[0:3]
P/N
RXPARP
RXPARN
TXDATA[0:3]
P/N
TXPARP
TXPARN
CONTROL/STATUS PINS
4
AUTO_DETECT
34
TTL input (with
pulldown)
Data rate autodetect enable. Enable the autodetection function for different data rates.
When AUTO_DETECT is high, the autodetection circuit generates RATEOUT0 and
RATEOUT1 to indicate the data rates for the downstream device.
CONFIG0
CONFIG1
17
18
TTL input (with
pulldown)
Configuration pins. Put the device under one of the four operation modes: TX only, RX
only, transceiver, or repeater. (See Table 3)
ENABLE
44
TTL input (with
pullup)
Standby enable. When this pin is held low, the device is disabled for IDDQ testing.
When high, the device operates normally.
FRAME_EN
27
TTL input (with
pullup)
Frame sync enable. When this pin is asserted high, the frame synchronization circuit for
byte alignment is turned on.
LCKREFN
24
TTL input (with
pullup)
Lock to reference. When this pin is low, RXCLKP/N output is forced to lock to REFCLK.
When high, RXCLKP/N is the divided down clock extracted from the receive serial data.
LLOOP
53
TTL input (with
pulldown)
Local loopback enable. When this pin is high, the serial output is internally looped back
to its serial input.
LOL
45
TTL output
Loss of lock. When the clock recovery loop has locked to the input data stream and the
phase differs by less than 100 ppm from REFCLK, then LOL is high. When the phase of
the input data stream differs by more than 100 ppm from REFCLK, then LOL is low. If
the difference is too large (> 500 ppm), the LOL output is not valid.
LOOPTIME
51
TTL input (with
pulldown)
Loop timing mode. When this pin is high, the PLL for the clock synthesizer is bypassed.
The recovered clock timing is used to send the transmit data.
LOS
46
TTL output
Loss of signal. When no transitions appear on the input data stream for more than 2.3
µs, a loss of signal occurs and LOS goes high. The device also transmits all zeroes
downstream using REFCLK as its clock source. When a valid SONET signal is received,
the LOS signal goes low.
PAR_VALID
2
TTL output
Parity checker output. The internal parity checker on the parallel side of the transmitter
checks for even parity. If there is a parity error, the pin is pulsed low for two clock
cycles.
SLK2721
www.ti.com
TERMINAL FUNCTIONS (continued)
TERMINAL
NAME
NO.
TYPE
DESCRIPTION
PRBSEN
41
TTL input (with
pulldown)
PRBS testing enable. When this pin is asserted high, the device is put into the PRBS
testing mode.
PRBSPASS
42
TTL output
PRBS test result. This pin reports the status of the PRBS test results (high = pass).
When PRBSEN is disabled, the PRBSPASS pin is set low. When PRBSEN is enabled
and a valid PRBS is received, then the PRBSPASS pin is set high.
PRE1
PRE2
4
5
TTL input (with
pulldown)
Programmable de-emphasis control. Combinations of these two bits can be used to
optimize serial data transmission.
PS
21
TTL input (with
pulldown)
Polarity select. This pin, used with the SIGDET pin, sets the polarity of SIGSET. When
high, SIGDET is an active low signal. When low, SIGDET is an active high signal.
RATEOUT0
RATEOUT1
37
36
TTL output
Autorate detection outputs. When AUTO_DETECT is high, the autodetection circuit
generates these two bits to indicate the data rates for the downstream device.
RESET
48
TTL input (with
pulldown)
TXFIFO and LOL reset pin. Low is reset and high is normal operation.
RLOOP
54
TTL input (with
pulldown)
Remote loopback enable. When this pin is high, the serial input is internally looped back
to its serial output with the timing extracted from the serial data.
RSEL0
RSE1L
39
38
TTL input (with
pulldown)
Data rate configuration pins. Put the device under one of the four data rate operations:
OC-48, OC-24, OC-12, or OC-3.
RX_MONITOR
47
TTL input (with
pulldown)
RX parallel data monitor in repeater mode. This pin is only used when the device is put
under repeater mode. When high, the RX demultiplexer circuit is enabled and the
parallel data is presented. When low, the demultiplexer is shut down to save power.
SIGDET
TTL input (with
pulldown)
Signal detect. This pin is generally connected to the output of an optical receiver. This
signal may be active high or active low depending on the optical receiver. The SIGDET
input is XORed with the PS pin to select the active state. When SIGDET is in the
inactive state, data is processed normally. When activated, indicating a loss of signal
event, the transmitter transmits all zeroes and force the LOS signal to go high.
SPILL
49
TTL output
TX FIFO collision output
TESTEN
43
TTL input (with
pulldown)
Production test mode enable. This pin must be left unconnected or tied low.
VOLTAGE SUPPLY AND RESERVED PINS
GND
GNDA
GNDLVDS
1, 6, 19, Ground
23, 26, 28,
30, 31, 33,
40
10, 13
Ground
61, 69, 76, Ground
77, 89, 93,
96, 100
Digital logic ground
Analog ground
LVDS ground
GNDPLL
12
Supply
PLL ground
RSVD
52
Reserved
This pin needs to be tied to ground or left floating for normal operation.
VDD
VDDA
VDDLVDS
VDDPLL
3, 22, 25, Supply
29, 32, 35,
50
7, 16
Supply
62, 72, 75, Supply
78, 90–92,
97
11
Supply
Digital logic supply voltage (2.5 V)
Analog voltage supply (2.5 V)
LVDS supply voltage (2.5 V)
PLL voltage supply (2.5 V)
5
SLK2721
www.ti.com
DETAILED DESCRIPTION
The SLK2721 device is designed to support the OC-48/24/12/3 data rates. It also supports a higher data rate
that may be required for FEC support, up to 2.7 Gbps. The operating data speed can be configured through the
RSEL0 and RSEL1 pins as indicated in Table 1 for normal SONET rates. For FEC support, the clock and data
rates need to be scaled up as required. The highest data and clock rates supported are 675 Mbps and 675 MHz,
respectively.
Table 1. Data Rate Select
SERIAL DATA RATE
RSEL0
RSEL1
PARALLEL LVDS DATA RATE
TXCLK/RXCLK
OC-48: 2.488 Gbps
622.08 Mbps
622.08 MHz
OC-24: 1.244 Gbps
1
311.04 Mbps
311.04 MHz
OC-12: 622 Mbps
155.52 Mbps
155.52 MHz
OC-3: 155.52 Mbps
1
1
38.88 Mbps
38.88 MHz
The user can also enable the autorate detection circuitry through the AUTO_DETECT pin. The device
automatically detects the OC-N of the data line rate and generates two bits of output to indicate the data rate to
other devices in the system. When using AUTO_DETECT, RSEL0 and RSEL1 need to be set to 00 or be
unconnected.
Table 2. Data Rate Reporting Under Autorate Detection Mode
SERIAL DATA RATE
RATEOUT0
RATEOUT1
TXCLK/RXCLK
OC-48: 2.488 Gbps
622.08 Mbps
622.08 MHz
OC-24: 1.244 Gbps
1
311.04 Mbps
311.04 MHz
OC-12: 622 Mbps
155.52 Mbps
155.52 MHz
OC-3: 155.52 Mbps
1
1
38.88 Mbps
38.88 MHz
The SLK2721 device has four operational modes controlled by two configuration pins. Table 3 lists these
operational modes. When the device is put in a certain mode, unused circuit blocks are powered down to
conserve system power.
While the transceiver mode, transmit only mode, and receive only mode are straightforward, the repeater mode
of operation is shown in Figure 4. The receive serial data is recovered by the extracted clock, and it is then sent
back out on the transmit serial outputs. The data eye is open both vertically and horizontally in this process. In
the repeater mode, the user can select to turn on the RX demultiplexer function through RX_MONITOR pin and
allow the parallel data to be presented. This feature enables the repeater device not only to repeat but also to
listen in.
Table 3. Operational Modes
6
MODE
CONFIG0
CONFIG1
DESCRIPTION
1
Full duplex transceiver mode
2
Transmit only mode
3
1
Receive only mode
4
1
1
Repeater mode
SLK2721
www.ti.com
High-Speed Electrical Interface
The high-speed serial I/O uses a PECL-compatible interface. The line could be directly coupled or ac-coupled.
Refer to Figure 10 and Figure 11 for configuration details. As shown in the figures, an on-chip 100-. termination
resistor is placed differentially at the receive end.
The PECL output also provides de-emphasis for compensating ac loss when driving a cable or PCB backplane
over long distance. The level of the de-emphasis is programmable via the PRE1 and PRE2 pins. Users can use
software to control the strength of the de-emphasis to optimize the device for a specific system requirement.
Table 4. Programmable De-emphasis
(1)
PRE1
PRE2
DE-EMPHASIS LEVEL
(Vodp/Vodd (1)-1)
De-emphasis disbled
1
10%
20%
1
1
30%
Vodp: Differential voltage swing when there is a transition in the data stream.
Vodd: Differential voltage swing when there is no transition in the data stream.
Figure 1. Output Differential Voltage Under De-emphasisl
LVDS Parallel Data Interface
The parallel data interface consists of a 4-bit parallel LVDS data and clock. The device conforms to the
OIF99.102 specification when operating at the OC-48 rate. When operating at lower serial rates, the clock and
data frequency are scaled down accordingly, as indicated in Table 1. The parallel data TXDATA[0:3] is latched
on the rising edge of TXCLK and then is sent to a data FIFO to resolve any phase difference between TXCLK
and REFCLK. If there is a FIFO overflow condition, the SPILL pin is set high. The FIFO resets itself to realign
between two clocks. The internal PLL for the clock synthesizer is locked to the REFCLK, and it is used as the
timing to serialize the parallel data (except for the loop timing mode where the recovered clock is used). On the
receive side, RXDATA[0:3] is updated on the rising edge of RXCLK. Figure 7 and Figure 8 show the timing
diagram for the parallel interface.
The SLK2721 device also has a built-in parity checker and generator for error detection of the LVDS interface.
On the transmit side, it accepts the parity bit, TXPARP/N, and performs the parity checking function for even
parity. If an error is detected, it pulses the PAR_VALID pin low for two clock cycles. On the receive side, the
parity bit, RXPARP/N, is generated for the downstream device for parity error checking.
Differential termination 100-Ω resistors are included on-chip between TXDATAP/N and TXCLKP/N.
Reference Clock
The device accepts a 622.08-MHz clock. The REFCLK input is compatible with the LVDS level and also the
3.3-V LVPECL level using ac-coupling. A 100-Ω differential termination resistor is included on-chip, as well as a
dc-biasing circuit (3 kΩ to VDD and 4.5 kΩ to GND) for the ac-coupled case. A high quality REFCLK must be
used on systems required to meet SONET/SDH standards. For non-SONET/SDH-compliant systems, loose
tolerances may be used.
7
SLK2721
www.ti.com
Clock and Data Recovery
The CDR unit of the SLK2721 device recovers the clock and data from the incoming data streams.
In the event of receive data loss, the PLL automatically locks to the local REFCLK to maintain frequency
stability. If the frequency of the data differs by more that 100 ppm with respect to the REFCLK frequency, the
LOL pin is asserted as a warning. Actual loss of lock occurs if the data frequency differs by more than 170 ppm.
Minimum Transition Density
The loop filter transfer function is optimized to enable the CDR to track ppm difference in the clocking and
tolerate the minimum transition density that can be received in a SONET data signal (±20 ppm). The transfer
function yields a typical capture time of 3500-bit times for random incoming NRZ data after the device is
powered up and achieves frequency locking.
The device tolerates up to 72 consecutive digits (CID) without sustaining an error.
Jitter Tolerance
Input jitter tolerance is defined as the peak-to-peak amplitude of sinusoidal jitter applied on the input signal that
causes the equivalent 1-dB optical/electrical power penalty. This refers to the ability of the device to withstand
input jitter without causing a recovered data error. The device has a jitter tolerance that exceeds the mask
shown in Figure 2 (GR-253 Figure 5-28). This jitter tolerance is specified using a pseudorandom data pattern of
231–1.
OC-N/STS-N
LEVEL
F0
(Hz)
F1
(Hz)
F2
(Hz)
F3
(kHz)
3
10
30
300
12
10
30
300
24
48
F4
(kHz)
A1
(Ulpp)
A2
(Ulpp)
A3
(Ulpp)
6.5
65
0.15
1.5
15
25
250
0.15
1.5
15
0.15
1.5
15
Not specified
10
600
6000
100
1000
Figure 2. Input Jitter Tolerance
Jitter Generation
The jitter of a serial clock and serial data outputs must not exceed 0.01 UIrms/0.1 UIp-p when a serial data with no
jitter is presented to the inputs. The measurement bandwidth for intrinsic jitter is 12 kHz to 20 MHz.
Loop Timing Mode
When LOOPTIME is high, the clock synthesizer used to serialize the transmit data is bypassed and the timing is
provided by the recovered clock. However, REFCLK is still needed for the recovery loop operation.
8
SLK2721
www.ti.com
Loss-of-Lock Indicator
The SLK2721 device has a lock detection circuit to monitor the integrity of the data input. When the clock
recovery loop is locked to the input serial data stream, the LOL signal goes high. If the recovered clock
frequency deviates from the reference clock frequency by more than 100 ppm, LOL goes low. If the data stream
clock rate deviates by more than 170 ppm, loss of lock occurs. If the data streams clock rate deviates more than
500 ppm from the local reference clock, the LOL output status might be unstable. Upon power up, the LOL goes
low until the PLL is close to phase lock with the local reference clock.
Loss of Signal
The loss-of-signal (LOS) alarm is set high when no transitions appear in the input data path for more than
2.3 µs. The LOS signal becomes active when the above condition occurs. If the serial inputs of the device are
ac-coupled to its source, the ac-coupling capacitor needs to be big enough to maintain a signal level above the
threshold of the receiver for the 2.3-µs no transition period. Once activated, the LOS alarm pin is latched high
until the receiver detects an A1A2 pattern. The recovered clock (RXCLK) is automatically locked to the local
reference when LOS occurs. The parallel data (RXDATAx) may still be processed even when LOS is activated.
Signal Detect
The SLK2721 device has an input SIGDET pin to force the device into the loss-of-signal state. This pin is
generally connected to the signal detect output of the optical receiver. Depending on the optics manufacturer,
this signal can be either active high or active low. To accommodate the differences, a polarity select (PS) is
used. For an active low, SIGDET input sets the PS pin high. For an active high, SIGDET input sets the PS pin
low. When the PS signal pin and SIGDET are of opposite polarities, the loss-of-signal state is generated and the
device transmits all zeroes downstream.
Multiplexer Operation
The 4-bit parallel LVDS data is clocked into an input buffer by a clock derived from the synthesized clock. The
data is then clocked into a 4:1 multiplexer. The D0 bit is the most significant bit and is shifted out first in the
serial output stream.
Demultiplexer Operation
The serial 2.5-Gbps data is clocked into a 1:4 demultiplexer by the recovered clock. The D0 bit is the first bit that
is received in time from the input serial stream. The 4-bit parallel data is then sent to the LVDS driver along with
the divided down recovered clock.
Frame Synchronization
The SLK2721 device has a SONET/SDH-compatible frame detection circuit that can be enabled or disabled by
the user. Frame detection is enabled when the FRAME_EN pin is high. When enabled, it detects the A1, A2
framing pattern, which is used to locate and align the byte and frame boundaries of the incoming data stream.
When FRAME_EN is low, the frame detection circuitry is disabled and the byte boundary is frozen to the location
found when detection was previously enabled.
The frame detect circuit searches the incoming data for three consecutive A1 bytes followed immediately by one
A2 byte. The data alignment circuit then aligns the parallel output data to the byte and frame boundaries of the
incoming data stream. During the framing process the parallel data bus will not contain valid and aligned data.
Upon detecting the third A1, A2 framing patterns that are separated by 125 µs from each other, the FSYNC
signal goes high for four RXCLK cycles, indicating frame synchronization has been achieved.
The probability that random data in a SONET/SDH data stream will mimic the framing pattern in the data
payload is extremely low. However, there is a state machine built in to prevent false reframing if a framing
pattern does show up in the data payload.
9
SLK2721
www.ti.com
Testability
The SLK2721 device has a comprehensive suite of built-in self-tests. The loopback function provides for
at-speed testing of the transmit/receive portions of the circuitry. The ENABLE pin allows for all circuitry to be
disabled so that an IDDQ test can be performed. The PRBS function allows for a built-in self-test (BIST).c
IDDQ Function
When held low, the ENABLE pin disables all quiescent power in both the analog and digital circuitry. This allows
for IDDQ testing on all power supplies and can also be used to conserve power when the link is inactive.
Local Loopback
The LLOOP signal pin controls the local loopback. When LLOOP is high, the loopback mode is activated and
the parallel transmit data is selected and presented on the parallel receive data output pins. The parallel transmit
data is also multiplexed and presented on the high-speed serial transmit pins. Local loopback can only be
enabled under transceiver mode.
Figure 3. Local Loopback Data Path
10
SLK2721
www.ti.com
Remote Loopback
The RLOOP signal pin controls the remote loopback. When RLOOP is high, the serial receive data is selected
and presented on the serial transmit data output pins. The serial received data is also demultiplexed and
presented on the parallel receive data pins. The remote loop can be enabled only when the device is under
transceiver mode. When the device is put under the repeater mode with RX_MONITOR high, it performs the
same function as remote loopback.
Figure 4. Remote Loopback Data Path/Repeater Mode Operation
PRBS
The SLK2721 device has two built-in pseudorandom bit stream (PRBS) functions. The PRBS generator is used
to transmit a PRBS signal. The PRBS verifier is used to check and verify a received PRBS signal.
When the PRBSEN pin is high, the PRBS generator and verifier are both enabled. A PRBS is generated and fed
into the parallel transmitter input bus. Data from the normal input source is ignored in PRBS mode. The PBRS
pattern is then fed through the transmitter circuitry as if it was normal data and sent out by the transmitter. The
output can be sent to a bit error rate tester (BERT) or to the receiver of another SLK2721 device. If an error
occurs in the PRBS pattern, the PRBSPASS pin is set low for two RXCLKP/N cycles.
Power-On Reset
Upon application of minimum valid power, the SLK2721 device generates a power-on reset. During the
power-on reset the PRXDATA[0:3] signal pins go to 3-state. RXCLKP and RXCLKN are held low. The length of
the power-on reset cycle is dependent upon the REFCLKP and REFCLKN frequency but is less than 1 ms in
duration.
11
SLK2721
www.ti.com
ABSOLUTE MAXIMUM RATINGS
over operating free-air temperature range (unless otherwise noted) (1)
VDD
VALUE
UNIT
–0.3 to 3
V
–0.3 to 4
V
–0.3 to 3
V
–0.3 to VDD + 0.3
V
Supply voltage
TTL input terminals
Voltage range
LVDS terminals
Any other terminal except above
PD
Package power dissipation
Tstg
Storage temperature
Electrostatic discharge
TA
See Dissipation Rating Table
–65 to 150
°C
2
kV
–40 to 85
°C
260
°C
HBM
Characterized free-air operating temperature range
Lead temperature 1,6 mm (1/16 inch) from case for 10 seconds
(1)
Stresses beyond those listed under absolute maximum ratings may cause permanent damage to the device. These are stress ratings
only, and functional operation of the device at these or any other conditions beyond those indicated under recommended operating
conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability.
DISSIPATION RATING TABLE
(1)
(2)
(3)
PACKAGE
TA≤ 25°C
POWER RATING
DERATING FACTOR (1)
ABOVE TA = 25¡ãC
TA = 85°C
POWER RATING
PZP (2)
3.4 W
33.78 mW/°C
1.3 W
PZP (3)
2.27 W
22.78 mW/°C
0.911 W
This is the inverse of the traditional junction-to-ambient thermal resistance (RθJA).
2 oz trace and copper pad with solder.
2 oz trace and copper pad without solder.
RECOMMENDED OPERATING CONDITIONS
VDD
Supply voltage
PD
Power dissipation
Frequency = 2.488 Gb/sec, PRBS pattern
Shutdown current
Enable = 0, VDDA, VDD pins, VDD = max
TA
Operating free-air temperature
MIN
NOM
MAX
UNIT
2.375
2.5
2.625
V
700
873
–40
mW
µA
°C
START UP SEQUENCE
To ensure proper start up, follow one of the following steps when powering up the SLK2721 device.
1. Keep ENABLE (pin 44) low until power supplies and reference clock have become stable.
2. Drive ENABLE (pin 44) low for at least 30 ns after power supplies and reference clock have become
stable.
12
SLK2721
www.ti.com
ELECTRICAL CHARACTERISTICS
over recommended operating conditions (unless otherwise noted)
PARAMETER
TEST CONDITIONS
MIN
TYP
MAX
UNIT
TTL
VIH
High-level input voltage
2
VIL
Low-level input voltage
IIH
Input high current
VDD = MAX, VIN = 2 V
IIL
Input low current
VDD = MAX, VIN = 0.4 V
–40
VOH
High-level output voltage
IOH = -1 mA
2.10
VOL
Low-level output voltage
IOH = 1 mA
CI
Input capacitance
3.6
V
0.80
V
40
µA
µA
2.3
0.25
V
0.5
V
4
pF
1575
mV
LVDS INPUT SIGNALS
VI
Input voltage
825
VID(th)
Input differential threshold voltage
100
CI
Input capacitance
RI
Input differential impedance
On-chip termination
tsu
Input setup time requirement
See Figure 7
300
ps
th
Input hold time requirement
See Figure 7
300
ps
T(duty)
Input clock duty cycle
mV
3
80
100
120
40%
60%
300
800
1070
1375
pF
Ω
LVDS OUTPUT SIGNALS
VOD
Output differential voltage
VOS
Output common mode voltage
∆VOD
Change VOD between 1 and 0
∆VOS
Change VOS between 1 and 0
RL = 100 ±1%
Output short circuit current
Outputs shorted to ground or shorted
together
Ioff
Power-off current
VDD = 0 V
t(cq_max)
tr/tf
mV
25
I(SP), I(SN),
I(SPN)
t(cq_min)
25
Clock-output time
See Figure 6
Output transition time
20% to 80%
Output clock duty cycle
Data output to FRAME_SYNC delay
24
mA
10
µA
100
100
100
300
45%
55%
4
7
ps
ps
Bit times
13
SLK2721
www.ti.com
TIMING REQUIREMENTS
PARAMETER
TEST CONDITIONS
MIN
TYP
MAX
UNIT
ppm
REFERENCE CLOCK (REFCLK)
Frequency tolerance (1)
–20
Duty cycle
40%
Jitter
60%
3
Frequency range abosolute value
(1)
50%
12 kHz to 20 MHz
622.08
ps rms
MHz
The ±20-ppm tolerance is required to meet SONET/SDH requirements. For non-SONET/SDH-compliant systems, looser tolerances may
apply.
PLL PERFORMANCE SPECIFICATIONS
PARAMETER
TEST CONDITIONS
PLL startup lock time
VDD, VDDC = 2.375 V, after REFCLK is stable
Acquisition lock time
Valid SONET signal or PRBS OC-48
MIN
TYP
MAX
1
2031
UNIT
ms
Bit Times
SERIAL TRANSMITTER/RECEIVER CHARACTERISTICS
PARAMETER
TEST CONDITIONS
Vodd = |STXDOP-STXDON|, transmit
differential output voltage under
de-emphasis
MIN
TYP
MAX
PRE1 = 0, PRE2 = 0, Rt = 50,
See Table 4 and Figure 1
650
850
1000
PRE1 = 1, PRE2 = 0
550
750
900
PRE1 = 0, PRE2 = 1
540
700
860
PRE1 = 1, PRE2 = 1
V(CMT)
Transmit common mode voltage range
Rt = 50 Ω
Receiver Input voltage requirement,
Vid = |SRXDIP-SRXDIN|
500
650
800
1100
1250
1400
150
V(CMR)
Receiver common mode voltage range
1100
Il
Receiver input leakage
–550
Rl
Receiver differential impedance
CI
Receiver input capacitance
80
UNIT
mV
mV
mV
1250
100
2250
mV
550
µA
120
Ω
1
pF
td(TX_Latency)
50
td(RX_Latency)
50
Bit Times
SERIAL DIFFERENTIAL SWITCHING CHARACTERISTICS
PARAMETER
TEST CONDITIONS
tt
Differential signal rise time (20% to 80%)
RL = 50 Ω
tj
Output jitter
Jitter-free data,
Jitter tolerance
RLOOP = 1,
See Figure 3
TYP
MAX
80
100
140
ps
0.05
0.1
UI(pp)
12 kHz to 20 MHz, RLOOP =
1
1MHz
14
MIN
0.15
0.4
100 kHz
1.5
4
1 kHz
1.5
9
UNIT
UI(pp)
SLK2721
www.ti.com
TYPICAL CHARACTERISTICS
Figure 5. Test Load and Voltage Definitions for LVDS Outputs
Figure 6. LVDS Output Waveform
Figure 7. LVDS Input Waveform
Figure 8. Transmitter Test Setup
15
SLK2721
www.ti.com
TYPICAL CHARACTERISTICS (continued)
Figure 9. High-Speed I/O Directly-Coupled Mode
Figure 10. High-Speed I/O AC-Coupled Mode
16
SLK2721
www.ti.com
APPLICATION INFORMATION
DESIGNING WITH THE PowerPAD PACKAGE
The SLK2721 device is housed in high-performance, thermally enhanced, 100-pin PZP PowerPAD packages.
Use of a PowerPAD package does not require any special considerations except to note that the PowerPAD,
which is an exposed die pad on the bottom of the device, is a metallic thermal and electrical conductor. Correct
device operation requires that the PowerPAD be soldered to the thermal land. Do not run any etches or signal
vias under the device, but have only a grounded thermal land, as explained below. Although the actual size of
the exposed die pad may vary, the minimum size required for the keepout area for the 100-pin PZP PowerPAD
package is 12 mm × 12 mm.
A thermal land, which is an area of solder-tinned-copper, is required underneath the PowerPAD package. The
thermal land varies in size depending on the PowerPAD package being used, the PCB construction, and the
amount of heat that needs to be removed. In addition, the thermal land may or may not contain numerous
thermal vias, depending on PCB construction.
Other requirements for thermal lands and thermal vias are detailed in the TI application note PowerPAD.
Thermally Enhanced Package Application Report, TI literature number SLMA002, available via the TI Web
pages beginning at URL http://www.ti.com.
Figure 11. Example of a Thermal Land
For the SLK2721 device, this thermal land must be grounded to the low-impedance ground plane of the device.
This improves not only thermal performance but also the electrical grounding of the device. It is also
recommended that the device ground terminal landing pads be connected directly to the grounded thermal land.
The land size must be as large as possible without shorting device signal terminals. The thermal land may be
soldered to the exposed PowerPAD using standard reflow soldering techniques.a
While the thermal land may be electrically floated and configured to remove heat to an external heat sink, it is
recommended that the thermal land be connected to the low-impedance ground plane of the device. More
information may be obtained from the TI application note PHY Layout, TI literature number SLLA020.
17
PACKAGE OPTION ADDENDUM
www.ti.com
9-Aug-2016
PACKAGING INFORMATION
Orderable Device
Status
(1)
SLK2721IPZP
LIFEBUY
Package Type Package Pins Package
Drawing
Qty
HTQFP
PZP
100
90
Eco Plan
Lead/Ball Finish
MSL Peak Temp
(2)
(6)
(3)
Green (RoHS
& no Sb/Br)
CU NIPDAU
Level-3-260C-168 HR
Op Temp (°C)
Device Marking
(4/5)
-40 to 85
SLK2721
(1)
The marketing status values are defined as follows:
ACTIVE: Product device recommended for new designs.
LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect.
NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design.
PREVIEW: Device has been announced but is not in production. Samples may or may not be available.
OBSOLETE: TI has discontinued the production of the device.
(2)
Eco Plan - The planned eco-friendly classification: Pb-Free (RoHS), Pb-Free (RoHS Exempt), or Green (RoHS & no Sb/Br) - please check http://www.ti.com/productcontent for the latest availability
information and additional product content details.
TBD: The Pb-Free/Green conversion plan has not been defined.
Pb-Free (RoHS): TI's terms "Lead-Free" or "Pb-Free" mean semiconductor products that are compatible with the current RoHS requirements for all 6 substances, including the requirement that
lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, TI Pb-Free products are suitable for use in specified lead-free processes.
Pb-Free (RoHS Exempt): This component has a RoHS exemption for either 1) lead-based flip-chip solder bumps used between the die and package, or 2) lead-based die adhesive used between
the die and leadframe. The component is otherwise considered Pb-Free (RoHS compatible) as defined above.
Green (RoHS & no Sb/Br): TI defines "Green" to mean Pb-Free (RoHS compatible), and free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight
in homogeneous material)
(3)
MSL, Peak Temp. - The Moisture Sensitivity Level rating according to the JEDEC industry standard classifications, and peak solder temperature.
(4)
There may be additional marking, which relates to the logo, the lot trace code information, or the environmental category on the device.
(5)
Multiple Device Markings will be inside parentheses. Only one Device Marking contained in parentheses and separated by a "~" will appear on a device. If a line is indented then it is a continuation
of the previous line and the two combined represent the entire Device Marking for that device.
(6)
Lead/Ball Finish - Orderable Devices may have multiple material finish options. Finish options are separated by a vertical ruled line. Lead/Ball Finish values may wrap to two lines if the finish
value exceeds the maximum column width.
Important Information and Disclaimer:The information provided on this page represents TI's knowledge and belief as of the date that it is provided. TI bases its knowledge and belief on information
provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. TI has taken and
continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals.
TI and TI suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release.
In no event shall TI's liability arising out of such information exceed the total purchase price of the TI part(s) at issue in this document sold by TI to Customer on an annual basis.
Addendum-Page 1
Samples
www.ti.com
9-Aug-2016
Addendum-Page 2
IMPORTANT NOTICE
Texas Instruments Incorporated and its subsidiaries (TI) reserve the right to make corrections, enhancements, improvements and other
changes to its semiconductor products and services per JESD46, latest issue, and to discontinue any product or service per JESD48, latest
issue. Buyers should obtain the latest relevant information before placing orders and should verify that such information is current and
complete. All semiconductor products (also referred to herein as “components”) are sold subject to TI’s terms and conditions of sale
supplied at the time of order acknowledgment.
TI warrants performance of its components to the specifications applicable at the time of sale, in accordance with the warranty in TI’s terms
and conditions of sale of semiconductor products. Testing and other quality control techniques are used to the extent TI deems necessary
to support this warranty. Except where mandated by applicable law, testing of all parameters of each component is not necessarily
performed.
TI assumes no liability for applications assistance or the design of Buyers’ products. Buyers are responsible for their products and
applications using TI components. To minimize the risks associated with Buyers’ products and applications, Buyers should provide
adequate design and operating safeguards.
TI does not warrant or represent that any license, either express or implied, is granted under any patent right, copyright, mask work right, or
other intellectual property right relating to any combination, machine, or process in which TI components or services are used. Information
published by TI regarding third-party products or services does not constitute a license to use such products or services or a warranty or
endorsement thereof. Use of such information may require a license from a third party under the patents or other intellectual property of the
third party, or a license from TI under the patents or other intellectual property of TI.
Reproduction of significant portions of TI information in TI data books or data sheets is permissible only if reproduction is without alteration
and is accompanied by all associated warranties, conditions, limitations, and notices. TI is not responsible or liable for such altered
documentation. Information of third parties may be subject to additional restrictions.
Resale of TI components or services with statements different from or beyond the parameters stated by TI for that component or service
voids all express and any implied warranties for the associated TI component or service and is an unfair and deceptive business practice.
TI is not responsible or liable for any such statements.
Buyer acknowledges and agrees that it is solely responsible for compliance with all legal, regulatory and safety-related requirements
concerning its products, and any use of TI components in its applications, notwithstanding any applications-related information or support
that may be provided by TI. Buyer represents and agrees that it has all the necessary expertise to create and implement safeguards which
anticipate dangerous consequences of failures, monitor failures and their consequences, lessen the likelihood of failures that might cause
harm and take appropriate remedial actions. Buyer will fully indemnify TI and its representatives against any damages arising out of the use
of any TI components in safety-critical applications.
In some cases, TI components may be promoted specifically to facilitate safety-related applications. With such components, TI’s goal is to
help enable customers to design and create their own end-product solutions that meet applicable functional safety standards and
requirements. Nonetheless, such components are subject to these terms.
No TI components are authorized for use in FDA Class III (or similar life-critical medical equipment) unless authorized officers of the parties
have executed a special agreement specifically governing such use.
Only those TI components which TI has specifically designated as military grade or “enhanced plastic” are designed and intended for use in
military/aerospace applications or environments. Buyer acknowledges and agrees that any military or aerospace use of TI components
which have not been so designated is solely at the Buyer's risk, and that Buyer is solely responsible for compliance with all legal and
regulatory requirements in connection with such use.
TI has specifically designated certain components as meeting ISO/TS16949 requirements, mainly for automotive use. In any case of use of
non-designated products, TI will not be responsible for any failure to meet ISO/TS16949.
Products
Applications
Audio
www.ti.com/audio
Automotive and Transportation
www.ti.com/automotive
Amplifiers
amplifier.ti.com
Communications and Telecom
www.ti.com/communications
Data Converters
dataconverter.ti.com
Computers and Peripherals
www.ti.com/computers
DLP® Products
www.dlp.com
Consumer Electronics
www.ti.com/consumer-apps
DSP
dsp.ti.com
Energy and Lighting
www.ti.com/energy
Clocks and Timers
www.ti.com/clocks
Industrial
www.ti.com/industrial
Interface
interface.ti.com
Medical
www.ti.com/medical
Logic
logic.ti.com
Security
www.ti.com/security
Power Mgmt
power.ti.com
Space, Avionics and Defense
www.ti.com/space-avionics-defense
Microcontrollers
microcontroller.ti.com
Video and Imaging
www.ti.com/video
RFID
www.ti-rfid.com
OMAP Applications Processors
www.ti.com/omap
TI E2E Community
e2e.ti.com
Wireless Connectivity
www.ti.com/wirelessconnectivity
Mailing Address: Texas Instruments, Post Office Box 655303, Dallas, Texas 75265
Copyright © 2016, Texas Instruments Incorporated
