SN74AS805BDWR
SN74AS805BDWR
    ROCHESTER(罗切斯特)
    SOIC20_300MIL
    NOR GATE
SN74AS805BDWR 数据手册
           SDAS023C − DECEMBER 1982 − REVISED JANUARY 1995 SN54ALS805A, SN54AS805B . . . J PACKAGE SN74ALS805A, SN74AS805B . . . DW OR N PACKAGE (TOP VIEW) High Capacitive-Drive Capability ′ALS805A Has Typical Delay Time of 4.2 ns (CL = 50 pF) and Typical Power Dissipation of 4.2 mW Per Gate ′AS805B Has Typical Delay Time of 2.6 ns (CL = 50 pF) and Typical Power Dissipation of 12 mW Per Gate Package Options Include Plastic Small-Outline (DW) Packages, Ceramic Chip Carriers (FK), and Standard Plastic (N) and Ceramic (J) 300-mil DIPs • • 1A 1B 1Y 2A 2B 2Y 3A 3B 3Y GND description These devices contain six independent 2-input NOR drivers. They perform the Boolean functions Y = A + B or Y = A • B in positive logic. OUTPUT Y H X L X H L L L H logic symbol† 1A 1B 2A 2B 3A 3B 4A 4B 5A 5B 6A 6B 1 2 19 3 18 4 17 5 16 6 15 7 14 8 13 9 12 10 11 VCC 6B 6A 6Y 5B 5A 5Y 4B 4A 4Y 4 3 2 1 20 19 18 5 17 6 16 7 15 8 14 9 10 11 12 13 6A 6Y 5B 5A 5Y 3Y GND 4Y 4A 4B B 2 1Y 1B 1A VCC 2A 2B 2Y 3A 3B FUNCTION TABLE (each driver) INPUTS 20 SN54ALS805A, SN54AS805B . . . FK PACKAGE (TOP VIEW) The SN54ALS805A and SN54AS805B are characterized for operation over the full military temperature range of − 55°C to 125°C. The SN74ALS805A and SN74AS805B are characterized for operation from 0°C to 70°C. A 1 6B • • logic diagram (positive logic) ≥1 3 4 6 5 1A 1Y 1B 2A 2Y 2B 7 9 8 3A 3Y 3B 12 11 13 4A 4Y 4B 15 14 16 5A 5Y 5B 18 17 19 6Y 6A 6B 1 2 3 1Y 4 5 6 2Y 7 8 9 3Y 12 13 11 4Y 15 16 14 5Y 18 19 17 6Y † This symbol is in accordance with ANSI/IEEE Std 91-1984 and IEC Publication 617-12. Copyright  1995, Texas Instruments Incorporated   !"#$ % &'!!($ #%  )'*+&#$ ,#$(!,'&$% &!" $ %)(&&#$% )(! $.( $(!"%  (/#% %$!'"($% %$#,#!, 0#!!#$1- !,'&$ )!&(%%2 ,(% $ (&(%%#!+1 &+',( $(%$2  #++ )#!#"($(!%- • DALLAS, TEXAS 75265 • HOUSTON, TEXAS 77251−1443 POST OFFICE BOX 655303 POST OFFICE BOX 1443 1            SDAS023C − DECEMBER 1982 − REVISED JANUARY 1995 absolute maximum ratings over operating free-air temperature range (unless otherwise noted)† Supply voltage, VCC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 V Input voltage, VI . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 V Operating free-air temperature range, TA: SN54ALS805A . . . . . . . . . . . . . . . . . . . . . . . . . . . . −55°C to 125°C SN74ALS805A . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0°C to 70°C Storage temperature range . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −65°C to 150°C † Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. recommended operating conditions SN54ALS805A SN74ALS805A MIN NOM MAX MIN NOM MAX 4.5 5 5.5 4.5 5 5.5 UNIT VCC VIH Supply voltage VIL IOH Low-level input voltage 0.7 0.8 V High-level output current −12 −15 mA IOL TA Low-level output current 24 mA 70 °C High-level input voltage 2 2 V 12 Operating free-air temperature −55 125 V 0 electrical characteristics over recommended operating free-air temperature range (unless otherwise noted) PARAMETER VIK VOH SN54ALS805A TYP‡ MAX TEST CONDITIONS MIN VCC = 4.5 V, VCC = 4.5 V to 5.5 V, II = −18 mA IOH = − 0.4 mA VCC = 4.5 V IOH = − 3 mA IOH = − 12 mA VOL VCC = 4.5 V II IIH VCC = 5.5 V, VCC = 5.5 V, IIL IO§ VCC = 5.5 V, VCC = 5.5 V, ICCH ICCL VCC = 5.5 V, VCC = 5.5 V, SN74ALS805A TYP‡ MAX MIN −1.2 VCC − 2 2.4 −1.2 VCC − 2 2.4 3.2 V 3.2 V 2 IOH = − 15 mA IOL = 12 mA UNIT 2 0.25 IOL = 24 mA VI = 7 V 0.4 0.25 0.4 0.35 0.5 0.1 VI = 2.7 V VI = 0.4 V VO = 2.25 V VI = 0 −20 mA 20 20 µA −0.1 −0.1 mA −112 mA mA −112 −30 2 4 2 4 8 14 8 14 mA ‡ All typical values are at VCC = 5 V, TA = 25°C. § The output conditions have been chosen to produce a current that closely approximates one half of the true short-circuit output current, IOS. 2 VI = 4.5 V 0.1 V • POST OFFICE BOX 655303 DALLAS, TEXAS 75265 POST OFFICE BOX 1443 HOUSTON, TEXAS 77251−1443 •            SDAS023C − DECEMBER 1982 − REVISED JANUARY 1995 switching characteristics (see Figure 1) PARAMETER FROM (INPUT) VCC = 4.5 V to 5.5 V, CL = 50 pF, RL = 500 Ω, TA = MIN to MAX† TO (OUTPUT) SN54ALS805A tPLH tPHL A or B UNIT SN74ALS805A MIN MAX MIN MAX 1 12 2 7 1 9 2 8 Y ns † For conditions shown as MIN or MAX, use the appropriate value specified under recommended operating conditions. absolute maximum ratings over operating free-air temperature range (unless otherwise noted)‡ Supply voltage, VCC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 V Input voltage, VI . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 V Operating free-air temperature range, TA: SN54AS805B . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −55°C to 125°C SN74AS805B . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0°C to 70°C Storage temperature range . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −65°C to 150°C ‡ Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. recommended operating conditions§ SN54AS805B SN74AS805B MIN NOM MAX MIN NOM MAX 4.5 5 5.5 4.5 5 5.5 UNIT VCC VIH Supply voltage VIL IOH Low-level input voltage 0.8 0.8 V High-level output current −40 −48 mA 40 48 mA 70 °C High-level input voltage 2 IOL Low-level output current TA Operating free-air temperature −55 § These high sink- or source-current devices are not recommended for use above 40 MHz. • POST OFFICE BOX 655303 DALLAS, TEXAS 75265 POST OFFICE BOX 1443 HOUSTON, TEXAS 77251−1443 • 2 125 0 V V 3            SDAS023C − DECEMBER 1982 − REVISED JANUARY 1995 electrical characteristics over recommended operating free-air temperature range (unless otherwise noted) PARAMETER VIK VOH SN54AS805B TYP† MAX TEST CONDITIONS MIN VCC = 4.5 V, VCC = 4.5 V to 5.5 V, II = −18 mA IOH = − 2 mA VCC = 4.5 V IOH = − 3 mA IOH = − 40 mA VOL VCC = 4.5 V II IIH VCC = 5.5 V, VCC = 5.5 V, IIL IO‡ VCC = 5.5 V, VCC = 5.5 V, ICCH ICCL VCC = 5.5 V, VCC = 5.5 V, SN74AS805B TYP† MAX MIN −1.2 VCC − 2 2.4 −1.2 VCC − 2 2.4 3.2 V 3.2 V 2 IOH = − 48 mA IOL = 40 mA UNIT 2 0.25 IOL = 48 mA VI = 7 V 0.5 0.35 0.5 0.1 VI = 2.7 V VI = 0.4 V VO = 2.25 V VI = 0 −50 0.1 mA 20 20 µA −0.5 −0.5 mA −200 mA mA −200 −50 6.5 10 6.5 10 20 32 20 32 VI = 4.5 V V mA † All typical values are at VCC = 5 V, TA = 25°C. ‡ The output conditions have been chosen to produce a current that closely approximates one half of the true short-circuit output current, IOS. switching characteristics (see Figure 1) PARAMETER FROM (INPUT) TO (OUTPUT) VCC = 4.5 V to 5.5 V, CL = 50 pF, RL = 500 Ω, TA = MIN to MAX§ SN54AS805B tPLH tPHL A or B Y SN74AS805B MIN MAX MIN MAX 1 4.8 1 4.3 1 4.8 1 4.3 § For conditions shown as MIN or MAX, use the appropriate value specified under recommended operating conditions. 4 • POST OFFICE BOX 655303 DALLAS, TEXAS 75265 POST OFFICE BOX 1443 HOUSTON, TEXAS 77251−1443 • UNIT ns            SDAS023C − DECEMBER 1982 − REVISED JANUARY 1995 PARAMETER MEASUREMENT INFORMATION SERIES 54ALS/74ALS AND 54AS/74AS DEVICES 7V RL = R1 = R2 VCC S1 RL R1 Test Point From Output Under Test CL (see Note A) From Output Under Test RL Test Point CL (see Note A) CL (see Note A) LOAD CIRCUIT FOR BI-STATE TOTEM-POLE OUTPUTS LOAD CIRCUIT FOR OPEN-COLLECTOR OUTPUTS 3.5 V Timing Input Test Point From Output Under Test LOAD CIRCUIT FOR 3-STATE OUTPUTS 3.5 V High-Level Pulse 1.3 V R2 1.3 V 1.3 V 0.3 V 0.3 V tsu Data Input tw th 3.5 V 1.3 V 3.5 V Low-Level Pulse 1.3 V 0.3 V 1.3 V 0.3 V VOLTAGE WAVEFORMS PULSE DURATIONS VOLTAGE WAVEFORMS SETUP AND HOLD TIMES 3.5 V Output Control (low-level enabling) 1.3 V 1.3 V 0.3 V tPZL Waveform 1 S1 Closed (see Note B) tPLZ 3.5 V Input tPZH 1.3 V 0.3 V tPHL tPLH VOH In-Phase Output VOL 0.3 V 1.3 V 1.3 V VOL tPLH tPHL VOH 1.3 V 1.3 V [3.5 V 1.3 V tPHZ Waveform 2 S1 Open (see Note B) 1.3 V VOH Out-of-Phase Output (see Note C) 0.3 V [0 V 1.3 V 1.3 V VOL VOLTAGE WAVEFORMS PROPAGATION DELAY TIMES VOLTAGE WAVEFORMS ENABLE AND DISABLE TIMES, 3-STATE OUTPUTS NOTES: A. CL includes probe and jig capacitance. B. Waveform 1 is for an output with internal conditions such that the output is low except when disabled by the output control. Waveform 2 is for an output with internal conditions such that the output is high except when disabled by the output control. C. When measuring propagation delay items of 3-state outputs, switch S1 is open. D. All input pulses have the following characteristics: PRR ≤ 1 MHz, tr = tf = 2 ns, duty cycle = 50%. E. The outputs are measured one at a time with one transition per measurement. Figure 1. Load Circuits and Voltage Waveforms • POST OFFICE BOX 655303 DALLAS, TEXAS 75265 POST OFFICE BOX 1443 HOUSTON, TEXAS 77251−1443 • 5 PACKAGE OPTION ADDENDUM www.ti.com 28-Aug-2010 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Drawing Pins Package Qty Eco Plan (2) Lead/ Ball Finish MSL Peak Temp (3) Samples (Requires Login) 5962-87794012A ACTIVE LCCC FK 20 1 TBD 5962-8779401RA ACTIVE CDIP J 20 1 TBD A42 N / A for Pkg Type 5962-8779401SA ACTIVE CFP W 20 1 TBD Call TI N / A for Pkg Type 5962-8869401SA OBSOLETE CFP W 20 TBD Call TI Call TI SN54ALS805AJ OBSOLETE CDIP J 20 TBD Call TI Call TI SN74ALS805ADWR ACTIVE SOIC DW 20 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM Purchase Samples SN74ALS805ADWRE4 ACTIVE SOIC DW 20 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM Purchase Samples SN74ALS805ADWRG4 ACTIVE SOIC DW 20 2000 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM Purchase Samples SN74ALS805AN3 OBSOLETE PDIP N 20 SN74AS805BDW NRND SOIC DW 20 25 SN74AS805BDWE4 NRND SOIC DW 20 SN74AS805BDWG4 NRND SOIC DW SN74AS805BN NRND PDIP Purchase Samples Purchase Samples Samples Not Available Samples Not Available Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM Samples Not Available 25 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM Samples Not Available 20 25 Green (RoHS & no Sb/Br) CU NIPDAU Level-1-260C-UNLIM Samples Not Available N 20 20 Pb-Free (RoHS) CU NIPDAU N / A for Pkg Type Samples Not Available 20 Pb-Free (RoHS) CU NIPDAU N / A for Pkg Type Samples Not Available SN74AS805BNE4 NRND PDIP N 20 OBSOLETE LCCC FK 20 TBD TBD Call TI Purchase Samples Call TI SNJ54ALS805AFK TBD POST-PLATE N / A for Pkg Type Call TI Call TI Replaced by SNJ54AS805BFK Call TI Call TI Replaced by SNJ54AS805BJ SNJ54ALS805AJ OBSOLETE CDIP J 20 SNJ54AS805BFK ACTIVE LCCC FK 20 1 TBD SNJ54AS805BJ ACTIVE CDIP J 20 1 TBD A42 N / A for Pkg Type Purchase Samples SNJ54AS805BW ACTIVE CFP W 20 1 TBD Call TI N / A for Pkg Type Purchase Samples (1) POST-PLATE N / A for Pkg Type The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. Addendum-Page 1 Purchase Samples PACKAGE OPTION ADDENDUM www.ti.com 28-Aug-2010 (2) Eco Plan - The planned eco-friendly classification: Pb-Free (RoHS), Pb-Free (RoHS Exempt), or Green (RoHS & no Sb/Br) - please check http://www.ti.com/productcontent for the latest availability information and additional product content details. TBD: The Pb-Free/Green conversion plan has not been defined. Pb-Free (RoHS): TI's terms "Lead-Free" or "Pb-Free" mean semiconductor products that are compatible with the current RoHS requirements for all 6 substances, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, TI Pb-Free products are suitable for use in specified lead-free processes. Pb-Free (RoHS Exempt): This component has a RoHS exemption for either 1) lead-based flip-chip solder bumps used between the die and package, or 2) lead-based die adhesive used between the die and leadframe. The component is otherwise considered Pb-Free (RoHS compatible) as defined above. Green (RoHS & no Sb/Br): TI defines "Green" to mean Pb-Free (RoHS compatible), and free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material) (3) MSL, Peak Temp. -- The Moisture Sensitivity Level rating according to the JEDEC industry standard classifications, and peak solder temperature. Important Information and Disclaimer:The information provided on this page represents TI's knowledge and belief as of the date that it is provided. TI bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. TI has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. TI and TI suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. In no event shall TI's liability arising out of such information exceed the total purchase price of the TI part(s) at issue in this document sold by TI to Customer on an annual basis. OTHER QUALIFIED VERSIONS OF SN54ALS805A, SN54AS805B, SN74ALS805A, SN74AS805B : • Catalog: SN74ALS805A, SN74AS805B • Military: SN54ALS805A, SN54AS805B NOTE: Qualified Version Definitions: • Catalog - TI's standard catalog product • Military - QML certified for Military and Defense Applications Addendum-Page 2 PACKAGE MATERIALS INFORMATION www.ti.com 29-Jul-2009 TAPE AND REEL INFORMATION *All dimensions are nominal Device SN74ALS805ADWR Package Package Pins Type Drawing SOIC DW 20 SPQ Reel Reel A0 Diameter Width (mm) (mm) W1 (mm) 2000 330.0 24.4 Pack Materials-Page 1 10.8 B0 (mm) K0 (mm) P1 (mm) W Pin1 (mm) Quadrant 13.0 2.7 12.0 24.0 Q1 PACKAGE MATERIALS INFORMATION www.ti.com 29-Jul-2009 *All dimensions are nominal Device Package Type Package Drawing Pins SPQ Length (mm) Width (mm) Height (mm) SN74ALS805ADWR SOIC DW 20 2000 346.0 346.0 41.0 Pack Materials-Page 2 IMPORTANT NOTICE Texas Instruments Incorporated and its subsidiaries (TI) reserve the right to make corrections, modifications, enhancements, improvements, and other changes to its products and services at any time and to discontinue any product or service without notice. Customers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. All products are sold subject to TI’s terms and conditions of sale supplied at the time of order acknowledgment. TI warrants performance of its hardware products to the specifications applicable at the time of sale in accordance with TI’s standard warranty. Testing and other quality control techniques are used to the extent TI deems necessary to support this warranty. Except where mandated by government requirements, testing of all parameters of each product is not necessarily performed. TI assumes no liability for applications assistance or customer product design. Customers are responsible for their products and applications using TI components. To minimize the risks associated with customer products and applications, customers should provide adequate design and operating safeguards. TI does not warrant or represent that any license, either express or implied, is granted under any TI patent right, copyright, mask work right, or other TI intellectual property right relating to any combination, machine, or process in which TI products or services are used. Information published by TI regarding third-party products or services does not constitute a license from TI to use such products or services or a warranty or endorsement thereof. Use of such information may require a license from a third party under the patents or other intellectual property of the third party, or a license from TI under the patents or other intellectual property of TI. Reproduction of TI information in TI data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. Reproduction of this information with alteration is an unfair and deceptive business practice. TI is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. Resale of TI products or services with statements different from or beyond the parameters stated by TI for that product or service voids all express and any implied warranties for the associated TI product or service and is an unfair and deceptive business practice. TI is not responsible or liable for any such statements. TI products are not authorized for use in safety-critical applications (such as life support) where a failure of the TI product would reasonably be expected to cause severe personal injury or death, unless officers of the parties have executed an agreement specifically governing such use. Buyers represent that they have all necessary expertise in the safety and regulatory ramifications of their applications, and acknowledge and agree that they are solely responsible for all legal, regulatory and safety-related requirements concerning their products and any use of TI products in such safety-critical applications, notwithstanding any applications-related information or support that may be provided by TI. Further, Buyers must fully indemnify TI and its representatives against any damages arising out of the use of TI products in such safety-critical applications. TI products are neither designed nor intended for use in military/aerospace applications or environments unless the TI products are specifically designated by TI as military-grade or "enhanced plastic." Only products designated by TI as military-grade meet military specifications. Buyers acknowledge and agree that any such use of TI products which TI has not designated as military-grade is solely at the Buyer's risk, and that they are solely responsible for compliance with all legal and regulatory requirements in connection with such use. TI products are neither designed nor intended for use in automotive applications or environments unless the specific TI products are designated by TI as compliant with ISO/TS 16949 requirements. Buyers acknowledge and agree that, if they use any non-designated products in automotive applications, TI will not be responsible for any failure to meet such requirements. Following are URLs where you can obtain information on other Texas Instruments products and application solutions: Products Applications Audio www.ti.com/audio Communications and Telecom www.ti.com/communications Amplifiers amplifier.ti.com Computers and Peripherals www.ti.com/computers Data Converters dataconverter.ti.com Consumer Electronics www.ti.com/consumer-apps DLP® Products www.dlp.com Energy and Lighting www.ti.com/energy DSP dsp.ti.com Industrial www.ti.com/industrial Clocks and Timers www.ti.com/clocks Medical www.ti.com/medical Interface interface.ti.com Security www.ti.com/security Logic logic.ti.com Space, Avionics and Defense www.ti.com/space-avionics-defense Power Mgmt power.ti.com Transportation and Automotive www.ti.com/automotive Microcontrollers microcontroller.ti.com Video and Imaging www.ti.com/video RFID www.ti-rfid.com Wireless www.ti.com/wireless-apps RF/IF and ZigBee® Solutions www.ti.com/lprf TI E2E Community Home Page e2e.ti.com Mailing Address: Texas Instruments, Post Office Box 655303, Dallas, Texas 75265 Copyright © 2011, Texas Instruments Incorporated
SN74AS805BDWR 价格&库存
很抱歉,暂时无法提供与“SN74AS805BDWR”相匹配的价格&库存,您可以联系我们找货
