SN74FB2033ARC
SN74FB2033ARC
    ROCHESTER(罗切斯特)
    52-QFP
    REGISTERED BUS TRANSCEIVER
SN74FB2033ARC 数据手册
SN74FB2033A 8-BIT TTL/BTL REGISTERED TRANSCEIVER SCBS174M – NOVEMBER 1991 – REVISED SEPTEMBER 2001 D D D D D Compatible With IEEE Std 1194.1-1991 (BTL) TTL A Port, Backplane Transceiver Logic (BTL) B Port Open-Collector B-Port Outputs Sink 100 mA BIAS VCC Pin Minimizes Signal Distortion During Live Insertion or Withdrawal D D High-Impedance State During Power Up and Power Down B-Port Biasing Network Preconditions the Connector and PC Trace to the BTL High-Level Voltage TTL-Input Structures Incorporate Active Clamping Networks to Aid in Line Termination CLKAB/LEAB IMODE1 IMODE0 BG VCC OEA BG GND BIAS VCC B1 AI2 AO1 AI1 GND VCC RC PACKAGE (TOP VIEW) 52 51 50 49 48 47 46 45 44 43 42 41 40 1 39 2 38 3 37 4 36 5 35 6 34 7 33 8 32 9 31 10 30 11 29 12 28 13 27 GND B2 GND B3 GND B4 GND B5 GND B6 GND B7 GND OEB GND B8 CLKBA/LEBA OMODE0 OMODE1 VCC OEB 14 15 16 17 18 19 20 21 22 23 24 25 26 AO7 AI8 AO8 GND VCC GND AO2 AI3 AO3 AI4 AO4 LOOPBACK AI5 AO5 AI6 AO6 AI7 GND description The SN74FB2033A is an 8-bit transceiver featuring a split input (AI) and output (AO) bus on the TTL-level A port. The common-I/O, open-collector B port operates at backplane transceiver logic (BTL) signal levels. The logic element for data flow in each direction is configured by two mode inputs (IMODE1 and IMODE0 for B-to-A, OMODE1 and OMODE0 for A-to-B) as a buffer, a D-type flip-flop, or a D-type latch. When configured in the buffer mode, the inverted input data appears at the output port. In the flip-flop mode, data is stored on the rising edge of the appropriate clock input (CLKAB/LEAB or CLKBA/LEBA). In the latch mode, the clock inputs serve as active-high transparent latch enables. Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet. Copyright  2001, Texas Instruments Incorporated PRODUCTION DATA information is current as of publication date. Products conform to specifications per the terms of Texas Instruments standard warranty. Production processing does not necessarily include testing of all parameters. POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 1 SN74FB2033A 8-BIT TTL/BTL REGISTERED TRANSCEIVER SCBS174M – NOVEMBER 1991 – REVISED SEPTEMBER 2001 description (continued) Data flow in the B-to-A direction, regardless of the logic element selected, is further controlled by the LOOPBACK input. When LOOPBACK is low, B-port data is the B-to-A input. When LOOPBACK is high, the output of the selected A-to-B logic element (prior to inversion) is the B-to-A input. The AO port-enable/-disable control is provided by OEA. When OEA is low or when VCC is less than 2.5 V, the AO port is in the high-impedance state. When OEA is high, the AO port is active (high or low logic levels). The B port is controlled by OEB and OEB. If OEB is low, OEB is high, or VCC is less than 2.5 V, the B port is inactive. If OEB is high and OEB is low, the B port is active. BG VCC and BG GND are the bias-generator reference inputs. The A-to-B and B-to-A logic elements are active, regardless of the state of their associated outputs. The logic elements can enter new data (in flip-flop and latch modes) or retain previously stored data while the associated outputs are in the high-impedance (AO port) or inactive (B port) states. Output clamps are provided on the BTL outputs to reduce switching noise. One clamp reduces inductive ringing effects on VOH during a low-to-high transition. The other clamps out ringing below the BTL VOL voltage of 0.75 V. Both clamps are active only during ac switching and do not affect the BTL outputs during steady-state conditions. BIAS VCC establishes a voltage between 1.62 V and 2.1 V on the BTL outputs when VCC is not connected. ORDERING INFORMATION TA PACKAGE† ORDERABLE PART NUMBER TOP-SIDE MARKING 0°C to 70°C QFP – RC Tube SN74FB2033ARC FB2033A † Package drawings, standard packing quantities, thermal data, symbolization, and PCB design guidelines are available at www.ti.com/sc/package. 2 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 SN74FB2033A 8-BIT TTL/BTL REGISTERED TRANSCEIVER SCBS174M – NOVEMBER 1991 – REVISED SEPTEMBER 2001 Function Tables FUNCTION/MODE INPUTS FUNCTION/MODE OEA OEB OEB OMODE1 OMODE0 IMODE1 IMODE0 LOOPBACK L L X X X X X X L X H X X X X X X H L L L X X X AI to B, buffer mode X H L L H X X X AI to B, flip-flop mode X H L H X X X X AI to B, latch mode H L X X X L L L H X H X X L L L H L X X X L H L H X H X X L H L H L X X X H X L H X H X X H X L H L X X X L L H H X H X X L L H H L X X X L H H H X H X X L H H H L X X X H X H H X H X X H X H H H L X X X X L Isolation B to t AO AO, b buffer ff mode d B to t AO, AO flip-flop fli fl mode d B to t AO AO, llatch t h mode d AI to AO AO, buffer mode AI to AO, AO flip-flop flip flop mode AI to AO, AO latch mode AI to B, B to AO ENABLE/DISABLE INPUTS OEA OEB OUTPUTS OEB AO B L X X Hi Z H X X Active X L L Inactive (H) X L H Inactive (H) X H L Active X H H Inactive (H) BUFFER INPUT OUTPUT L H H L LATCH INPUTS CLK/LE DATA OUTPUT H L H H H L L X Q0 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 3 SN74FB2033A 8-BIT TTL/BTL REGISTERED TRANSCEIVER SCBS174M – NOVEMBER 1991 – REVISED SEPTEMBER 2001 Function Tables (Continued) LOOPBACK LOOPBACK Q† L B port Point P‡ H † Q is the input to the B-to-A logic element. ‡ P is the output of the A-to-B logic element (see functional block diagram). SELECT INPUTS MODE1 SELECTED LOGIC ELEMENT MODE0 L L Buffer L H Flip-flop H X Latch FLIP-FLOP INPUTS 4 OUTPUT CLK/ LE DATA L X Q0 ↑ L H ↑ H L POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 SN74FB2033A 8-BIT TTL/BTL REGISTERED TRANSCEIVER SCBS174M – NOVEMBER 1991 – REVISED SEPTEMBER 2001 functional block diagram 23 OEB OEB OMODE1 24 21 20 OMODE0 47 CLKAB/ LEAB Transceiver 1D C1 40 AI1 B1 50 P 1D C1 IMODE1 46 45 IMODE0 19 CLKBA/ LEBA 1D C1 51 Q AO1 OEA 1D 43 C1 One of Eight Channels LOOPBACK 7 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 5 SN74FB2033A 8-BIT TTL/BTL REGISTERED TRANSCEIVER SCBS174M – NOVEMBER 1991 – REVISED SEPTEMBER 2001 absolute maximum ratings over operating free-air temperature range (unless otherwise noted)† Supply voltage range, VCC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –0.5 V to 7 V Input clamp current range, VI: Except B port . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –1.2 V to 7 V B port . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –1.2 V to 3.5 V Voltage range applied to any B output in the disabled or power-off state, VO . . . . . . . . . . . . . . –0.5 V to 3.5 V Voltage range applied to any output in the high state, VO: A port . . . . . . . . . . . . . . . . . . . . . . . . –0.5 V to VCC Input clamp current, IIK: Except B port . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –40 mA B port . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –18 mA Current applied to any single output in the low state, IO: A port . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 48 mA Package thermal impedance, θJA (see Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 44°C/W Storage temperature range, Tstg . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –65°C to 150°C † Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. NOTE 1: The package thermal impedance is calculated in accordance with JESD 51-7. recommended operating conditions (see Note 2) VCC, BG VCC Supply voltage BIAS VCC Supply voltage VIH High level input voltage High-level VIL Low level input voltage Low-level IOH High-level output current IOL Low level output current Low-level ∆t/∆v Input transition rise or fall rate B port Except B port B port MIN NOM MAX UNIT 4.75 5 5.25 V 4.5 5 5.5 V 1.62 2.3 2 0.75 1.47 Except B port 0.8 AO port –3 AO port 24 B port Except B port 100 10 V V mA mA ns/V TA Operating free-air temperature 0 70 °C NOTE 2: To ensure proper device operation, all unused inputs must be terminated as follows: A and control inputs to VCC(5 V) or GND, and B inputs to GND only. Refer to the TI application report, Implications of Slow or Floating CMOS Inputs, literature number SCBA004. 6 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 SN74FB2033A 8-BIT TTL/BTL REGISTERED TRANSCEIVER SCBS174M – NOVEMBER 1991 – REVISED SEPTEMBER 2001 electrical characteristics over recommended operating free-air temperature range (unless otherwise noted) PARAMETER VIK TEST CONDITIONS MIN TYP† MAX UNIT –1.2 V 2.85 VCC–1.1 3.4 V 0.33 0.5 VCC = 4.75 V, VCC = 4.75 V to 5.25 V, II = –18 mA IOH = –10 µA VCC = 4 4.75 75 V IOH = –3 mA IOH = –32 mA VCC = 4 4.75 75 V IOL = 20 mA IOL = 55 mA B portt VCC = 4 4.75 75 V IOL = 100 mA IOL = 4 mA II Except B port IIH VI = 5.25 V VI = 2.7 V 100 Except B port B port‡ VCC = 0, VCC = 5.25 V, VCC = 0 to 5.25 V, 100 IIL Except B port B port‡ VI = 2.1 V VI = 0.5 V VI = 0.75 V VO = 2.1 V –100 VOH AO port AO port VOL IOH IOZPU IOZPD IOZH B port VCC = 0 to 5.25 V, VCC = 0 to 2.1 V, VCC = 2.1 V to 0, VCC = 5.25 V, AO port IOZL IOS§ AO port ICC Ci All outputs on Co AO port Cio VCC = 5 5.25 25 V VCC = 5.25 V, VCC = 5.25 V, AO port AI port and control inputs B port ort per IEEE Std 1194.1-1991 VCC = 5.25 V, VI = 0.5 V or 2.5 V 2.5 2 0.8 0.75 1.1 0.5 50 –50 VO = 0.5 V to 2.7 V VO = 0.5 V to 2.7 V VO = 2.7 V VO = 0.5 V VO = 0 IO = 0 V –40 µA µA 100 µA 50 µA –50 µA 50 µA –50 µA –80 –150 mA 45 70 mA 5 VO = 0.5 V or 2.5 V VCC = 0 to 4.75 V µA pF 5 pF 6 VCC = 4.75 V to 5.25 V 6 pF † All typical values are at VCC = 5 V. ‡ For I/O ports, the parameters IIH and IIL include the off-state output current. § Not more than one output should be shorted at a time, and the duration of the short circuit should not exceed one second. live-insertion characteristics over recommended operating free-air temperature range (see Note 3) PARAMETER ICC (BIAS VCC) VO IO B port B port TEST CONDITIONS VCC = 0 to 4.5 V VCC = 4.5 V to 5.5 V VB = 0 to 2 V, V VCC = 0, VCC = 0, VI (BIAS VCC) = 4.5 V to 5.5 V VB = 1 V, Vl (BIAS VCC) = 4.5 V to 5.5 V VCC = 0 to 5.5 V, VCC = 0 to 2.2 V, MIN MAX 10 Vl (BIAS VCC) = 4.5 4 5 V to 5 5.5 5V 10 1.62 UNIT µA 2.1 V OEB = 0 to 0.8 V 100 µA OEB = 0 to 5 V 100 –1 NOTE 3: The power-up sequence is GND, BIAS VCC, VCC. POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 7 SN74FB2033A 8-BIT TTL/BTL REGISTERED TRANSCEIVER SCBS174M – NOVEMBER 1991 – REVISED SEPTEMBER 2001 timing requirements over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) (see Figure 2) VCC = 5 V, TA = 25°C MIN 8 MIN MAX UNIT 150 MHz MAX fclock tw Clock frequency 150 Pulse duration CLKAB/LEAB or CLKBA/LEBA 3.3 3.3 ns tsu th Setup time Data before CLKAB/LEAB or CLKBA/LEBA↑ 2.7 2.7 ns Hold time Data after CLKAB/LEAB or CLKBA/LEBA↑ 0.7 0.7 ns POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 SN74FB2033A 8-BIT TTL/BTL REGISTERED TRANSCEIVER SCBS174M – NOVEMBER 1991 – REVISED SEPTEMBER 2001 switching characteristics over recommended ranges of supply voltage and operating free-air temperature (unless otherwise noted) (see Figure 2) PARAMETER fmax tPLH tPHL tPLH tPHL tPLH tPHL tPLH tPHL tPLH tPHL tPLH tPHL tPZH tPZL tPHZ tPLZ tPLH tPHL tPLH tPHL tPLH tPHL tPLH tPHL tPLH tPHL tPLH tPHL tr tf tr tf B-port input pulse rejection FROM (INPUT) VCC = 5 V, TA = 25°C TO (OUTPUT) MIN TYP MIN 150 AI (through mode) B B (through mode) AO AI (transparent) B B (transparent) AO OEB B OEB B OEA AO OEA AO CLKAB/LEAB B CLKBA/LEBA AO OMODE B IMODE AO LOOPBACK AO AI AO MAX UNIT MAX 150 MHz 2.3 3.6 4.6 2.3 5.6 1.9 3 4.2 1.9 4.5 2.5 4.2 5.5 2.5 6.1 3 4.2 5.6 3 5.7 2.3 3.6 4.6 2.3 5.6 1.9 3 4.1 1.9 4.5 2.5 4.2 5.5 2.5 6.1 3 4.2 5.6 3 5.7 2.4 3.7 4.7 2.4 5.8 1.8 3 4.1 1.8 4.4 2 3.4 4.3 2 5.2 2 3.3 4.4 2 4.8 2 3.5 4.6 2 5.1 2.7 4.2 5.1 2.7 5.4 2.1 4 5 2.1 5.5 1.6 2.8 3.9 1.6 4.3 3 4.7 5.8 3 6.9 2.8 4.3 5.6 2.8 6.1 2 3.6 4.9 2 5.4 2.2 3.5 4.7 2.2 5.1 2.4 5 6.1 2.4 7.2 2.4 4.5 6 2.4 6.7 1.8 4 5.3 1.8 5.9 2.3 4.1 5.2 2.3 5.4 2.4 5 7 2.4 8 3.1 4.6 5.7 3.1 5.9 1.9 3.7 5.5 1.9 6.1 2.6 4.2 5.6 2.6 5.8 Rise time,1.3 V to 1.8 V, B port 0.5 1.2 2.1 0.5 3 Fall time, 1.8 V to 1.3 V, B port 0.5 1.4 2.3 0.5 3 Rise time, 10% to 90%, AO 2 3.3 4.2 2 5 Fall time, 90% to 10%, AO 1 2.5 3.4 1 5 1 ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns output-voltage characteristics TEST CONDITIONS PARAMETER MIN MAX VOHP Peak output voltage during turnoff of 100 mA into 40 nH B port See Figure 1 VOHV Minimum output voltage during turnoff of 100 mA into 40 nH B port See Figure 1 1.62 V VOLV Minimum output voltage during high-to-low switch B port IOL = –50 mA 0.3 V POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 4.5 UNIT V 9 SN74FB2033A 8-BIT TTL/BTL REGISTERED TRANSCEIVER SCBS174M – NOVEMBER 1991 – REVISED SEPTEMBER 2001 PARAMETER MEASUREMENT INFORMATION 2.1 V 40 nH 9Ω From Output Under Test 30 pF Figure 1. Load Circuit for VOHP and VOHV 10 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 SN74FB2033A 8-BIT TTL/BTL REGISTERED TRANSCEIVER SCBS174M – NOVEMBER 1991 – REVISED SEPTEMBER 2001 PARAMETER MEASUREMENT INFORMATION 2.1 V 9Ω 7V 500 Ω From Output Under Test CL = 50 pF (see Note A) S1 Open Test Point From Output Under Test CL = 30 pF (see Note A) 500 Ω LOAD CIRCUIT FOR A OUTPUTS S1 Open 7V Open LOAD CIRCUIT FOR B OUTPUTS 3V Timing Input TEST tPLH/tPHL tPLZ/tPZL tPHZ/tPZH tw 1.5 V 3V 0V Input tsu 1.5 V 0V th VOLTAGE WAVEFORMS PULSE DURATION 3V Data Input 1.5 V 1.5 V 1.5 V 0V VOLTAGE WAVEFORMS SETUP AND HOLD TIMES 3V Output Control 1.5 V 1.5 V 0V 3V Input 1.5 V tPZL 1.5 V 0V tPHL tPLH 1.55 V 1.55 V VOH Output VOL VOLTAGE WAVEFORMS PROPAGATION DELAY TIMES (A TO B) 2.1 V Input 1.55 V 1.55 V tPLZ Output Waveform 1 S1 at 7 V (see Note B) 3.5 V 1.5 V VOL + 0.3 V VOL tPZH tPHZ Output Waveform 2 S1 at Open (see Note B) VOH VOH – 0.3 V 1.5 V ≈0 V VOLTAGE WAVEFORMS ENABLE AND DISABLE TIMES (A PORT) 1V tPHL VOHP tPLH VOHV VOH Output 1.5 V VOLV 1.5 V 2.1 V 1V VOL VOLTAGE WAVEFORMS PROPAGATION DELAY TIMES (B TO A) VOLTAGE WAVEFORMS NOTES: A. CL includes probe and jig capacitance. B. Waveform 1 is for an output with internal conditions such that the output is low except when disabled by the output control. Waveform 2 is for an output with internal conditions such that the output is high except when disabled by the output control. C. All input pulses are supplied by generators having the following characteristics: TTL inputs: PRR ≤ 10 MHz, ZO = 50 Ω, tr ≤ 2.5 ns, tf ≤ 2.5 ns; BTL inputs: PRR ≤ 10 MHz, ZO = 50 Ω, tr ≤ 2.5 ns, tf ≤ 2.5 ns. D. The outputs are measured one at a time with one transition per measurement. Figure 2. Load Circuits and Voltage Waveforms POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 11 IMPORTANT NOTICE Texas Instruments and its subsidiaries (TI) reserve the right to make changes to their products or to discontinue any product or service without notice, and advise customers to obtain the latest version of relevant information to verify, before placing orders, that information being relied on is current and complete. All products are sold subject to the terms and conditions of sale supplied at the time of order acknowledgment, including those pertaining to warranty, patent infringement, and limitation of liability. TI warrants performance of its products to the specifications applicable at the time of sale in accordance with TI’s standard warranty. Testing and other quality control techniques are utilized to the extent TI deems necessary to support this warranty. Specific testing of all parameters of each device is not necessarily performed, except those mandated by government requirements. Customers are responsible for their applications using TI components. In order to minimize risks associated with the customer’s applications, adequate design and operating safeguards must be provided by the customer to minimize inherent or procedural hazards. TI assumes no liability for applications assistance or customer product design. TI does not warrant or represent that any license, either express or implied, is granted under any patent right, copyright, mask work right, or other intellectual property right of TI covering or relating to any combination, machine, or process in which such products or services might be or are used. TI’s publication of information regarding any third party’s products or services does not constitute TI’s approval, license, warranty or endorsement thereof. Reproduction of information in TI data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations and notices. Representation or reproduction of this information with alteration voids all warranties provided for an associated TI product or service, is an unfair and deceptive business practice, and TI is not responsible nor liable for any such use. Resale of TI’s products or services with statements different from or beyond the parameters stated by TI for that product or service voids all express and any implied warranties for the associated TI product or service, is an unfair and deceptive business practice, and TI is not responsible nor liable for any such use. Also see: Standard Terms and Conditions of Sale for Semiconductor Products. www.ti.com/sc/docs/stdterms.htm Mailing Address: Texas Instruments Post Office Box 655303 Dallas, Texas 75265 Copyright  2001, Texas Instruments Incorporated
SN74FB2033ARC 价格&库存
很抱歉,暂时无法提供与“SN74FB2033ARC”相匹配的价格&库存,您可以联系我们找货
