TLK2201JRGQE
TLK2201JRGQE
    ROCHESTER(罗切斯特)
    VFBGA80
    ETHERNET TRANSCEIVER, 1-TRNSVR
TLK2201JRGQE 数据手册
         SCAS652F − AUGUST 2000 − REVISED MAY 2007 D 1.0-to 1.6-Gigabits Per Second (Gbps) D D D D D D D D Interfaces to Backplane, Copper Cables, or Serializer/Deserializer Low Power Consumption < 250 mW at 1.25 Gbps PECL Compatible Differential I/O on High-Speed Interface Single Monolithic PLL Design Support for 10-Bit Interface (TBI) or Reduced Interface 5-Bit Double Data Rate (DDR) Clocking Receiver Differential Input Thresholds 200 mV Minimum IEEE 802.3 (Gigabit Ethernet) Compliant Advanced 0.25-µm CMOS Technology Optical Modules No External Filter Capacitors Required Comprehensive Suite of Built-In Testability IEEE 1149.1 JTAG Support 2.5-V Supply for Lowest Power Operation 3.3-V Tolerant on TTL Inputs Hot Plug Protection ESD Protection 2-kV HBM 5 mm × 5 mm Footprint Removes Space Limitations With Small Form-Factor MicroStar Junior BGA Packaging D D D D D D D D description The TLK2201JR is a member of the transceiver family of multigigabit transceivers, optimized for use with small form-factor optical transceivers that require footprints smaller than 14 mm. The TLK2201JR gigabit ethernet transceiver is fully compliant with IEEE 802.3 requirements for serializer/deserializer functions at 1.25 Gbps. The TLK2201JR supports a wide range of serial data rates from 1.0 Gbps to 1.6 Gbps. The primary application of this device is to provide building blocks for point-to-point baseband data transmission over controlled impedance media of 50 Ω or 75 Ω. The transmission media can be printed-circuit board traces, copper cables, or fiber-optical media. The ultimate rate and distance of data transfer is dependent upon the attenuation characteristics of the media and the noise coupling to the environment. A B C D E F G H J 9 RD1 RD2 RD3 RD4 RD5 RD6 RD7 RD8 RD9 9 8 RD0 VDD VDD JTDI VDD VDD SYNC/ PASS 8 7 RXN VDDA GNDA GNDA GND GND GND RBC RBC0 MODE 7 6 RXP GND GND GND TEST EN RBC1 6 5 LOS VDDA GNDA GNDA GNDA GND GND JTCLK JTDO 5 4 TXN VDDA GND GND GND GND GND PRBS EN SYNC EN 4 3 TXP VDD PLL Open GND GND GND GND MODE SEL REF CLK 3 2 TD0 VDD VDD VDD VDD EN ABLE VDD VDD LOOP EN 2 1 TD1 TD2 TD3 TD4 TD5 TD6 TD7 TD8 TD9 1 A B C D E F G H J VDDA JTMS JTRST N GNDA GNDA Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet. MicroStar Junior is a trademark of Texas Instruments. Copyright  2001, Texas Instruments Incorporated   ! "#$   % &'""( $% ! )' *&$   +$ ( " +'& % & ! "# %)(&!&$  % )(" ,( ("#% ! (-$% % "'#( % % $+$"+ .$""$ / " +'&   )" &(%%0 + (%  (&(%%$"*/ &*'+( (% 0 ! $** )$"$#( ("% POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 1          SCAS652F − AUGUST 2000 − REVISED MAY 2007 description (continued) The TLK2201JR performs the data serialization, deserialization, and clock extraction functions for a physical layer interface device. The transceiver operates at 1.25 Gbps (typical), providing up to 1.0 Gbps of data bandwidth over a copper or optical media interface. The TLK2201JR supports both the defined 10-bit interface (TBI) and a reduced 5-bit interface with double data rate (DDR) clocking. In the TBI mode the serializer/deserializer (serdes) accepts 10-bit wide 8-bit/10-bit (8b/10b) parallel encoded data bytes. The parallel data bytes are serialized and transmitted differentially at PECL compatible voltage levels. The serdes extracts clock information from the input serial stream and deserializes the data, outputting a parallel 10-bit data byte. In the DDR mode the parallel interface accepts 5-bit wide 8-bit/10-bit encoded data aligned to both the rising and falling edge of the reference clock. The data is clocked most significant bit first (i.e., bits 0−4 of the 8-bit/10-bit encoded data) on the rising edge of the clock, and the least significant bits (i.e., bits 5−9 of the 8-bit/10-bit encoded data) are clocked on the falling edge of the clock. The transceiver automatically locks onto incoming data without the need to prelock. The TLK2201JR provides a comprehensive series of built-in tests for self-test purposes including loopback and PRBS generation and verification. An IEEE 1149.1 JTAG port is also supported. The TLK2201JR is housed in a high-performance, thermally enhanced, 80-pin land grid array (LGA) MicroStarJr package. Use of the MicroStarJr package does not require any special considerations. All ac performance specifications in this data sheet are measured with the MicroStarJr soldered to the test board. The TLK2201JR is characterized for operation from 0°C to 70°C. The TLK2201JR uses a 2.5-V supply. The I/O section is 3.3-V compatible. With the 2.5-V supply the chipset is very power efficient dissipating less than 250 mW typical power when operating at 1.25 Gbps. The TLK2201JR is designed to be hot plug capable. A power-on reset holds RCB0 and RCB1 low. The parallel side output pins, TXP and TXN go to high-impedance during power up. differences between TLK2201JR and TNETE2201 The TLK2201JR is a functional equivalent of the TNETE2201B. There are several differences between the two devices as noted below. D The VCC is 2.5 V for the TLK2201JR versus 3.3 V for TNETE2201. D The PLL filter capacitors on pins 16, 17, 48, and 49 of the TNETE2201 are no longer required. D No pulldown resistors are required on the TXP/TXN outputs. 2 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265          SCAS652F − AUGUST 2000 − REVISED MAY 2007 transceiver family The TLK2201JR is a member of the transceiver family of CMOS multigigabit transceivers intended for use in high-speed bidirectional point-to-point data transmission systems. Other members of the the transceiver family include: D TLK1501 − A 0.6-Gbps to 1.5-Gbps transceiver with on-chip 8-bit/10-bit ENDEC providing up to 1.28 Gbps of data bandwidth, packaged in a 64-pin VQFP PowerPAD package. D TLK2500/TLK2501 − A 1.6-Gbps to 2.5-Gbps transceiver with on-chip 8-bit/10-bit ENDEC, providing up to 2 Gbps of data bandwidth, packaged in a 64-pin VQFP PowerPAD package. D TLK2701 − A 2.5-Gbps to 2.7-Gbps transceiver with on-chip 8-bit/10-bit ENDEC, providing up to 2.16 Gbps of data bandwidth with k-character control, packaged in a 64-pin VQFP PowerPAD package. D TLK3101 − A 2.5-Gbps to 3.125-Gbps transceiver with on-chip 8-bit/10-bit ENDEC, providing up to 2.5 Gbps of data bandwidth, packaged in a 64-pin VQFP PowerPAD package. D TLK3104SC − A 3-Gbps to 3.125-Gbps quad transceiver with on-chip 8-bit/10-bit ENDEC and a 16-bit low voltage differential signaling (LVDS) parallel interface, packaged in 289 pin PBGA. D TLK3104SA − A 3-Gbps to 3.125-Gbps quad transceiver with on-chip 8-bit/10-bit ENDEC, an IEEE 802.3ae defined XGMII parallel interface with SSTL_2 I/O, packaged in 289 pin PBGA. functional block diagram PRBSEN LOOPEN TXP PRBS Generator TXN 2:1 MUX TD0−9 Parallel to Serial 10 Bit Register Clock Phase Generator REFCLK MODESEL ENABLE TESTEN RBC1 RBC0 SYNC/PASS Control Logic Interpolator and Clock Extraction PRBS Verification Clock Clock Serial to Parallel and Comma Detect RD0−RD9 2:1 MUX 2:1 MUX Data RXP RXN SYNCEN RBCMODE LOS JTMS JTRSTN JTDI TCK JTAG Control Register JTDO PowerPAD is a trademark of Texas Instruments. POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 3          SCAS652F − AUGUST 2000 − REVISED MAY 2007 detailed description data transmission The TLK2201JR supports both the defined 10-bit interface (TBI) and a reduced 5-bit interface with DDR clocking. When MODESEL is low, the TBI mode is selected. When MODESEL is high, the DDR mode is selected. In the TBI mode, the transmitter portion registers incoming 10-bit wide data words (8b/10b encoded data, TD0−TD9) on the rising edge of REFCLK. The REFCLK is also used by the serializer, which multiplies the clock by a factor of 10, providing a signal that is fed to the shift register. The 8b/10b encoded data is transmitted sequentially bit 0 through 9 over the differential high-speed I/O channel. In the DDR mode, the transmitter accepts 5-bit wide 8-b/10-b encoded data on pins TD0−TD4. In this mode data is aligned to both the rising and falling edges of REFCLK. The data is then formed into a 10-bit wide word and sent to the serializer. The data is clocked most significant bit first (i.e. the bits 0−4 of the 8-b/10-b encoded data). transmission latency The data transmission latency of the TLK2201JR is defined as the delay from the initial 10-bit word load to the serial transmission of bit 9. The minimum latency in TBI mode is 19 bit times. The maximum latency in TBI mode is 20 bit times. The minimum latency in DDR mode is 29 bit times, and maximum latency in DDR mode is 30 bit times. 10 Bit Code b9 TXP, TXN Td(Tx latency) TD(0−9) 10 Bit Code REFCLK Figure 1. Transmitter Latency Full Rate Mode data reception The receiver portion of the TLK2201JR deserializes the differential serial data. The serial data is retimed based on an interpolated clock generated from the reference clock. The serial data is then aligned to the 10-bit word boundaries and presented to the protocol controller along with receive byte clocks (RBC0, RBC1). 4 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265          SCAS652F − AUGUST 2000 − REVISED MAY 2007 detailed description (continued) receiver clock select mode The TLK2201JR provides two modes of operation for the parallel busses. 1)The 10-bit (TBI) mode and 2) 5-bit (DDR) mode. When in TBI mode, there are two user-selectable clock modes that are controlled by the RBCMODE pin:1) Full-rate clock on RBC0 and 2) Half-rate clocks on RBC0 and RBC1. When in the DDR mode, only a full-rate clock is available on RBC0. Table 1 shows the mode selection. Table 1. Mode Selection MODESEL RBCMODE MODE FREQUENCY 0 0 TBI half-rate 100−125 MHz 0 1 TBI full-rate 100−160 MHz 1 0 DDR 100−125 MHz 1 1 DDR 100−125 MHz In the half-rate mode, two receive byte clocks (RBC0 and RBC1) are 180 degrees out of phase and operate at one-half the data rate. The clocks are generated by dividing down the recovered clock. The received data is output with respect to the two receive byte clocks (RBC0, RBC1), allowing a protocol device to clock the parallel bytes using the RBC0 and RBC1 rising edges. The TLK2201 outputs to the protocol device. Byte 0 of the received data is valid on the rising edge of RBC1. Figure 2 shows the timing diagram. td(S) RBC0 td(S) RBC1 td(H) SYNC td(H) RD(0−9) K28.5 DXX.X DXX.X DXX.X K28.5 DXX.X Figure 2. Synchronous Timing Characteristics Waveforms (TBI Half-Rate Mode) In the normal-rate mode, only RBC0 is used, and it operates at full data rate (i.e., 1.25-Gbps data rate produces a 125-MHz clock). The received data is output with respect to the rising edge of RBC0. RBC1 is low in this mode. Figure 3 shows the synchronous timing characteristics waveforms (TBI full-rate mode). RBC0 td(S) td(H) SYNC RD(0−9) K28.5 DXX.X DXX.X DXX.X K28.5 DXX.X Figure 3. Synchronous Timing Characteristics Waveforms (TBI Full-Rate Mode) In the double data rate mode, the receiver presents the data on both the rising and falling edges of RBC0. RBC1 is low impedance. The data is clocked bit-0 first, and aligned to the rising edge of RBC0. Figure 4 shows the synchronous timing characteristics waveforms (DDR mode). POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 5          SCAS652F − AUGUST 2000 − REVISED MAY 2007 receiver clock select mode (continued) td(S) RBC0 td(S) td(H) td(H) SYNC RD(0−4) K28.5 K28.5 DXX.X DXX.X DXX.X DXX.X DXX.X DXX.X K28.5 K28.5 DXX.X Bits 0−4 Bits 5−9 Figure 4. Synchronous Timing Characteristics Waveforms (DDR Mode) The receiver clock interpolator can lock to the incoming data without the need for a lock-to-reference preset. The received serial data rate (RXP and RXN) must be at the same baud rate as the transmitted data stream, ±0.02% (200 PPM) for proper operation (see page 11). receiver word alignment The TLK2201 uses the IEEE 802.3 Gigabit Ethernet defined 10-bit K28.5 character (comma character) word alignment scheme. The following sections explain how this scheme works and how it realigns itself. comma character on expected boundary The TLK2201 provides 10-bit K28.5 character recognition and word alignment. The 10-bit word alignment is enabled by forcing the SYNCEN terminal high. This enables the function that examines and compares serial input data to the seven-bit synchronization pattern. The K28.5 character is defined by 8-bit/10-bit coding scheme as a pattern consisting of 0011111010 (a negative number beginning with disparity) with the 7 MSBs (0011111) referred to as the comma character. The K28.5 character was implemented specifically for aligning data words. As long as the K28.5 character falls within the expected 10-bit boundary, the received 10-bit data is properly aligned and data realignment is not required. Figure 2 shows the timing characteristics of RBC0, RBC1, SYNC, and RD0−RD9 while synchronized. (Note: the K28.5 character is valid on the rising edge of RBC1). comma character not on expected boundary If synchronization is enabled and a K28.5 character straddles the expected 10-bit word boundary, then word realignment is necessary. Realignment or shifting the 10-bit word boundary truncates the character following the misaligned K28.5, but the following K28.5 and all subsequent data is aligned properly as shown in Figure 5. The RBC0 and RBC1 pulse width is stretched or stalled in their current state during realignment. With this design the maximum stretch that occurs is 20 bit times. This occurs during a worst case scenario when the K28.5 is aligned to the falling edge of RBC1 instead of the rising edge. Figure 5 shows the timing characteristics of the data realignment. 6 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265          SCAS652F − AUGUST 2000 − REVISED MAY 2007 comma character not on expected boundary (continued) 31 Bit Times Max Receive Path Latency INPUT DATA K28.5 DXX.X 30 Bit Times (Max) K28.5 DXX.X DXX.X DXX.X DXX.X K28.5 RBC0 RBC1 Worst Case Misaligned K28.5 RD(0−9) DXX.X DXX.X Misalignment Corrected Corrupt Data K28.5 DXX.X DXX.X K28.5 DXX.X DXX.X DXX.X K28.5 SYNC Figure 5. Word Realignment Timing Characteristics Waveforms Systems that do not require framed data may disable byte alignment by tying SYNCEN low. When a SYNC character is detected, the SYNC signal is brought high and is aligned with the K28.5 character. The duration of the SYNC pulse is equal to the duration of the data when in TBI mode. When in DDR mode the SYNC pulse is present for the entire RBC0 period. data reception latency The serial to parallel data latency is the time from when the first bit arrives at the receiver until it is output in the aligned parallel word with RD0 received as first bit. The minimum latency in TBI mode is 22 bit times and the maximum latency is 31 bit times. The minimum latency in DDR mode is 28 bit times and maximum latency is 34 bit times. 10 Bit Code RXP, RXN Td(Rx latency) RD(0−9) 10 Bit Code RBC0 Figure 6. Receiver Latency−TBI Normal Mode Shown loss of signal detection The TLK2201 has a loss of signal (LOS) detection circuit for conditions where the incoming signal no longer has sufficient voltage level to keep the clock recovery circuit in lock. The LOS is intended to be an indication of gross signal error conditions, such as a detached cable or no signal being transmitted, and not an indication of signal coding health. Under a PRBS serial input pattern, LOS is high for signal amplitudes greater than 150 mV. The LOS is low for all amplitudes below 50 mV. Between 50 mV and 150 mV, LOS is undetermined. POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 7          SCAS652F − AUGUST 2000 − REVISED MAY 2007 detailed description (continued) testability The loopback function provides for at-speed testing of the transmit/receive portions of the circuitry. The enable function allows for all circuitry to be disabled so that an Iddq test can be performed. The PRBS function also allows for a BIST( built-in self test). The terminal setting, TESTEN high, enables the test mode. The terminal TESTEN has an internal pulldown resistor, so it defaults to normal operation. The TESTEN is only used for factory testing, and is not intended for the end-user. loopback testing The transceiver can provide a self-test function by enabling (LOOPEN to high level) the internal loopback path. Enabling this function cause serial transmitted data to be routed internally to the receiver. The parallel data output can be compared to the parallel input data for functional verification. (The external differential output is held in a high-impedance state during the loopback testing.) enable function When held low, enable disables all quiescent power in both the analog and digital circuitry. This allows an ultralow-power idle state when the link is not active. PRBS function The TLK2201 has a built-in 27−1 PRBS function. When the PRBSEN control bit is set high, the PRBS test is enabled. A PRBS is generated and fed into the 10-bit parallel transmitter input bus. Data from the normal parallel input source is ignored during PRBS test mode. The PBRS pattern is then fed through the transmit circuitry as if it were normal data and sent out to the transmitter. The output can be sent to a (BERT) bit error rate tester or to the receiver of another TLK2201. Since the PRBS is not really random and is really a predetermined sequence of ones and zeros, the data can be captured and checked for errors by a BERT. The TLK2201 also has a built-in BERT function on the receiver side that is enabled by PRBSEN. It can receive a PRBS pattern and check for errors, and then reports the errors by forcing the SYNC/PASS terminal low. When PRBS is enabled, RBCMODE is ignored. MODESEL must be low for the PRBS verifier to function correctly. The PRBS testing supports two modes (normal and latched), which are controlled by the SYNC enable input. When SYNCEN is low, the result of the PRBS bit error rate test is passed to the SYNC/PASS terminal. When SYNCEN is high the result of the PRBS verification is latched on the SYNC/PASS output (i.e., a single failure forces SYNC/PASS to remain low). 8 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265          SCAS652F − AUGUST 2000 − REVISED MAY 2007 Terminal Functions TERMINAL NO. GQE NO. RCP† I/O DESCRIPTION TXP TXN A3 A4 62 61 PECL O Differential output transmit. TXP and TXN are differential serial outputs that interface to a copper or an optical I/F module. TXP and TXN are put in a high-impedance state when LOOPEN is high and are active when LOOPEN is low. RXP RXN A6 A7 54 52 PECL I Differential input receive. RXP and RXN together are the differential serial input interface from a copper or an optical I/F module. REFCLK J3 22 I Reference clock. REFCLK is an external input clock that synchronizes the receiver and transmitter interface (100 MHz to 160 MHz). The transmitter uses this clock to register the input data (TD0−TD9) for serialization. NAME SIGNAL In the TBI mode that data is registered on the rising edge of REFCLK. In the DDR mode, the data is registered on both the rising and falling edges of REFCLK with the most significant bits aligned to the rising edge of REFCLK. TD0−TD9 RD0−RD9 RBC0 RBC1 A2, A1, B1, C1, D1, E1, F1, G1, H1, J1 2−4, 6−9, 11−13 I A8, A9, B9, C9, D9, E9, F9, G9, H9, J9 45, 44, 43, 41, 40, 39, 38, 36, 35, 34 O J7 J6 31 30 O Transmit data. When in the TBI mode (MODESEL = low) these inputs carry 10-bit parallel data output from a protocol device to the transceiver for serialization and transmission. This 10-bit parallel data is clocked into the transceiver on the rising edge of REFCLK and transmitted as a serial stream with TD0 sent as the first bit. When in the DDR mode (MODESEL = high) only TD0−TD4 are valid. The 5-bit parallel data is clocked into the transceiver on the rising and falling edge of REFCLK and transmitted as a serial stream with TD0 sent as the first bit. Receive data. When in TBI mode (MODESEL = low) these outputs carry 10-bit parallel data output from the transceiver to the protocol layer. The data is referenced to terminals RBC0 and RBC1, depending on the receive clock mode selected. RD0 is the first bit received. When in the DDR mode (MODESEL = high) only RD0−RD4 are valid. RD5−RD9 are held low. The 5-bit parallel data is clocked out of the transceiver on the rising edge of RBC0. Receive byte clock. RBC0 and RBC1 are recovered clocks used for synchronizing the 10-bit output data on RD0−RD9. The operation of these clocks dependant upon the receive clock mode selected. In the half-rate mode, the 10-bit output data words are valid on the rising edges of RBC0 and RBC1. These clocks are adjusted to half-word boundaries in conjunction with synchronous detect. The clocks are always expanded during data realignment and never slivered or truncated. RBC0 registers bytes 1 and 3 of received data. RBC1 registers bytes 0 and 2 of received data. In the normal rate mode, only RBC0 is valid and operates at 1/10 the serial data rate. Data is aligned to the rising edge. In the DDR mode, only RBC0 is valid and operates at 1/10 the serial data rate. Data is aligned to both the rising and falling edges. RBCMODE H7 32 I P/D‡ Receive clock mode select. When RBCMODE and MODESEL are low, half-rate clocks are output on RBC0 and RBC1. When MODESEL is low and RBCMODE is high, a full baud-rate clock is output on RBC0 and RBC1 is held low. When MODESEL is high, RBCMODE is ignored and a full baud-rate clock is output on RBC0 and RBC1 is held low. SYNCEN J4 24 I P/U§ Synchronous function enable. When SYNCEN is asserted high, the internal synchronization function is activated. When this function is enabled, the transceiver detects the K28.5 comma character (0011111 negative beginning disparity) in the serial data stream and realigns data on byte boundaries if required. When SYNCEN is low, serial input data is unframed in RD0−RD9. SYNC/PASS J8 47 O Synchronous detect. The SYNC output is asserted high upon detection of the comma pattern in the serial data path. SYNC pulses are output only when SYNCEN is activated (asserted high). In PRBS test mode (PRBSEN=high), SYNC/PASS outputs the status of the PRBS test results (high=pass). LOS A5 26 O Loss of signal. Indicates a loss of signal on the high-speed differential inputs RXP and RXN. If magnitude of RXP−RXN > 150 mV, LOS = 1, valid input signal If magnitude of RXP−RXN < 150 mV and > 50 mV, LOS is undefined If magnitude of RXP−RXN < 50 mV, LOS = 0, loss of signal † For cross reference to TLK2201 RCP package only. ‡ P/D = pulldown § P/U = pullup POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 9          SCAS652F − AUGUST 2000 − REVISED MAY 2007 Terminal Functions (Continued) TERMINAL NO. GQE NO. RCP† I/O DESCRIPTION H3 15 I P/D‡ Mode select. This terminal selects between the 10-bit interface and a reduced 5-bit DDR interface. When low the 10-bit interface (TBI) is selected. When pulled high, the 5-bit DDR mode is selected. The default mode is the TBI. LOOPEN J2 19 I P/D‡ Loop enable. When LOOPEN is high (active), the internal loop-back path is activated. The transmitted serial data is directly routed to the inputs of the receiver. This provides a self-test capability in conjunction with the protocol device. The TXP and TXN outputs are held in a high-impedance state during the loop-back test. LOOPEN is held low during standard operational state with external serial outputs and inputs active. JTCLK/TCK H5 49 I JTDI F8 48 I P/U§ JTDO J5 27 O JTRSTN E8 56 I P/U§ Reset signal. IEEE1149.1 (JTAG) JTMS D8 55 I P/U§ Test mode select. IEEE1149.1 (JTAG) ENABLE F2 28 I P/U§ When this terminal is low, the device is disabled for Iddq testing. RD0−RD9, RBC, TXP, and TXN are high-impedance. The pullup and pulldown resisters on any input are disabled. When ENABLE is high, the device operates normally. PRBSEN H4 16 I P/D§ PRBS enable. When PRBSEN is high, the PRBS generation circuitry is enabled. The PRBS verification circuit in the receive side is also enabled. A PRBS signal can be fed to the receive inputs and checked for errors that are reported by the SYNC/PASS terminal indicating low. TESTEN H6 17 I P/D‡ Manufacturing test terminal. VDD B8, C8, G8, H8, B2, C2, D2, E2, G2, H2 5, 10, 20, 23, 29, 37, 42, 50, 63 Supply Digital logic power. Provides power for all digital circuitry and digital I/O buffers. VDDA B7, B6, B5, B4 53, 57, 59, 60 Supply Analog power. VDDA provides power for the high-speed analog circuits, receiver, and transmitter B3 18 Supply PLL power. Provides power for the PLL circuitry. This terminal requires additional filtering. GNDA C7, D7, C6, D6, C5, D5, E5 51,58 Ground Analog ground. GNDA provides a ground for the high-speed analog circuits, RX and TX. GND C4, D3, D4, E3, E4, E6, E7 F3, F4, F5, F6, F7, G3, G4, G5, G6, G7 1, 14, 21, 25, 33, 46 Ground Digital logic ground. Provides a ground for the logic circuits and digital I/O buffers. NAME MODESEL TEST Test clock. IEEE1149.1 (JTAG) Test data input. IEEE1149.1 (JTAG) Test data output. IEEE1149.1 (JTAG) POWER VDDPLL GROUND GNDPLL N/A 64 Ground PLL ground. Provides a ground for the PLL circuitry. Tied to GNDA in the GQE package. † For cross reference to TLK2201 RCP package only. ‡ P/D = pulldown § P/U = pullup 10 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265          SCAS652F − AUGUST 2000 − REVISED MAY 2007 absolute maximum ratings over operating free-air temperature (unless otherwise noted)† Supply voltage, VDD (see Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −0.3 V to 3 V Input voltage, VI, (TTL) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −0.5 V to 4 V DC input voltage (I/O ) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −0.3 V to 3 V Voltage range at any terminal . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −0.3 V to VCC +0.3 V Storage temperature, Tstg . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . −65°C to 150°C Electrostatic discharge . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . HBM:2 kV, CDM: 1 kV Characterized free-air operating temperature range . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0°C to 70°C † Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. NOTE 1: All voltage values, except differential I/O bus voltages, are with respect to network ground terminal. DISSIPATION RATING TABLE‡ PACKAGE θJA (°C/W) θJC (°C/W) TA = 25°C POWER RATING GQE 37.8 4.56 3.3 W ‡ This data was taken using 2 oz. trace and copper pad that is soldered directly to a JEDEC standard ‡ 4-layer, 3-in. x 3-in. PCB. thermal characteristics PARAMETER RθJA RθJC Junction-to-free-air thermal resistance Junction-to-case-thermal resistance TEST CONDITION MIN TYP Board-mounted, no air flow, high conductivity TI recommended test board, chip soldered or greased to thermal land 21.47 Board-mounted, no air flow, high conductivity TI recommended test board with thermal land but no solder or grease thermal connection to thermal land 42.20 Board-mounted, no air flow, JEDEC test board 75.83 0.38 Board-mounted, no air flow, high conductivity TI recommended test board with thermal land but no solder or grease thermal connection to thermal land 0.38 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 UNIT °C/W Board-mounted, no air flow, high conductivity TI recommended test board, chip soldered or greased to thermal land Board-mounted, no air flow, JEDEC test board MAX °C/W 7.8 11          SCAS652F − AUGUST 2000 − REVISED MAY 2007 recommended operating conditions Supply voltage, VDD, VDD(A) Total supply current IDD, IDD(A) Frequency = 1.25 Gbps, PRBS pattern Frequency = 1.6 Gbps, Worst case pattern† MIN NOM MAX 2.3 2.5 2.7 UNIT V 80 111 Frequency = 1.25 Gbps, PRBS pattern Total power dissipation PD Frequency = 1.6 Gbps, Worst case pattern† 310 Total shutdown current IDD, IDD(A) Enable = 0, Vdda , Vdd = 2.7 V 50 Startup lock time, PLL VDD, VDD(A) = 2.5 V, EN↑ to PLL acquire mA 190 Operating free-air temperature, TA 0 mW µA 500 µs 70 °C † Worst case pattern is a pattern that creates a maximum transition density on the serial transceiver. reference clock (REFCLK) timing requirements over recommended operating conditions (unless otherwise noted) MIN TYP MAX UNIT Frequency PARAMETER Minimum data rate TEST CONDITIONS TYP−0.01% 100 TYP−0.01% MHz Frequency Maximum data rate TYP−0.01% 160 TYP−0.01% MHz 100 ppm Accuracy −100 Duty cycle 40% Jitter 50% 60% Random plus deterministic 40 ps TTL electrical characteristics over recommended operating conditions (unless otherwise noted) PARAMETER VOH VOL High-level output voltage VIH VIL High-level input voltage IIH IIL Input high current Low-level output voltage TEST CONDITIONS IOH = −400 µA IOL = 1 mA TYP 2.1 2.3 GND 0.25 1.7 Low-level input voltage Input low current VDD = 2.3 V, VDD = 2.3 V, VIN = 2.0 V VIN = 0.4 V CIN 12 MIN MAX V 0.5 V 3.6 V 0.8 V 40 µA µA −40 4 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 UNIT pf          SCAS652F − AUGUST 2000 − REVISED MAY 2007 transmitter/receiver characteristics PARAMETER TEST CONDITIONS Vod = |TxD−TxN| V(cm) Transmit common mode voltage range MIN TYP MAX Rt = 50 Ω 600 850 1100 Rt = 75 Ω 800 1050 1200 Rt = 50 Ω 1000 1250 1400 Rt = 75 Ω 1000 1250 1400 Receiver Input voltage requirement, Vid = |RxP − RxN| 200 Receiver common mode voltage range, (RxP + RxN)/2 1000 Ilkg(R) CI Receiver input leakage current −350 t(TJ) Serial data total jitter (peak-to-peak) t(DJ) Serial data deterministic jitter (peak-to-peak) tr, tf Differential signal rise, fall time (20% to 80%) RL = 50 Ω, CL = 5 pF, See Figures 7 and 8 100 Serial data jitter tolerance minimum required eye opening, (per IEEE-802.3 specification) Differential input jitter, random + determinisitc, PRBS pattern at zero crossing 0.25 1250 Data relock time from loss of synchronization TBI modes Tx latency TBI modes (see Figure 6) td(Rx latency) Rx latency DDR mode 80% 50% 20% TX+ mV 2250 mV 350 µA 2 pF 0.24 UI 0.12 UI 250 ps 500 µs 1024 Bit times 19 20 29 30 1 Gpbs 22 27 1.25 Gpbs 23 28 1.6 Gpbs 25 31 1 Gpbs 27 32 1.25 Gpbs 28 33 1.375 Gpbs 30 34 UI UI UI ∼V ∼V tf tr 80% 50% 20% TX− tf ∼V CL 5 pF 20% 50 kΩ ∼V 50 kΩ tr ∼ 1V 80% VOD See Figure 1 DDR mode mV UI Receiver data acquisition lock time from powerup td(Tx latency) mV 1600 Receiver input capacitance Differential output jitter, Random + deterministic, PRBS pattern, Rω = 125 MHz Differential output jitter, PRBS pattern, Rω = 125 MHz UNIT 0V CL 5 pF ∼ −1V Figure 7. Differential and Common-Mode Output Voltage Definitions POST OFFICE BOX 655303 Figure 8. Transmitter Test Setup • DALLAS, TEXAS 75265 13          SCAS652F − AUGUST 2000 − REVISED MAY 2007 1.4 V CLOCK tf tr 80% 50% 20% DATA 2V 0.8 V tf tr Figure 9. TTL Data I/O Valid Levels for AC Measurement LVTTL output switching characteristics over recommended operating conditions (unless otherwise noted) PARAMETER TEST CONDITIONS MIN TYP MAX tr(BRC) tf(RBC) Clock rise time 0.3 1.5 Clock fall time 0.3 1.5 tr tf Data rise time 0.3 1.5 0.3 1.5 80% to 20% output voltage, C = 5 pF (see Figure 9) Data fall time UNIT ns ns tsu(D1) Data setup time (RD0..RD9), Data valid prior to RBC0 rising TBI normal mode, (see Figure 3) 2.5 ns th(D1) Data hold time (RD0..RD9), Data valid after RBC0 rising TBI normal mode, (see Figure 3) 2 ns tsu(D2) th(D2) Data setup time (RD0..RD4) DDR mode, Rω = 125 MHz, (see Figure 4) 2 ns Data hold time (RD0..RD4) DDR mode, Rω = 125 MHz, (see Figure 4) 0.8 ns tsu(D3) th(D3) Data setup time (RD0..RD9) TBI half-rate mode, Rω = 125 MHz, (see Figure 2) 2.5 ns Data hold time (RD0..RD9) TBI half-rate mode, Rω = 125 MHz, (see Figure 2) 1.5 ns transmitter timing requirements over recommended operating conditions (unless otherwise noted) TEST CONDITIONS tsu(D4) th(D4) Data setup time (TD0..TD9) tsu(D5) th(D5) Data setup time (TD0..TD9) tr, tf TD[0,9] Data rise and fall time 14 Data hold time (TD0..TD9) Data hold time (TD0..TD9) MIN NOM MAX UNIT 1.6 TBI modes ns 0.8 0.7 DDR modes See Figure 9 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 ns 0.5 2 ns          SCAS652F − AUGUST 2000 − REVISED MAY 2007 APPLICATION INFORMATION 8B/10B transmission code The PCS maps GMII signals into ten-bit code groups and vice versa, using an 8b/10b block coding scheme. The PCS uses the transmission code to improve the transmission characteristics of information to be transferred across the link. The encoding defined by the transmission code ensures that sufficient transitions are present in the PHY bit stream to make clock recovery possible in the receiver. Such encoding also greatly increases the likelihood of detecting any single or multiple bit errors that may occur during transmission and reception of information. The 8b/10b transmission code specified for use has a high transition density, is run length limited, and is dc-balanced. The transition density of the 8b/10b symbols range from 3 to 8 transitions per symbol. The definition of the 8b/10b transmission code is specified in IEEE 802.3 Gigabit Ethernet and ANSI X3.230-1994 (FC−PH), clause 11. 8b/10b transmission code uses letter notation describing the bits of an unencoded information octet. The bit notation of ABCDEFGH for an unencoded information octet is used in the description of the 8b/10b transmission code-groups, where A is the LSB. Each valid code group has been given a name using the following convention: /Dx.y/ for the 256 valid data code-groups and /Kx.y/ for the special control code-groups, where y is the decimal value of bits EDCBA and x is the decimal value of bits HGF (noted as K). Thus, an octet value of FE representing a code-group value of K30.7 is represented in bit notation as 111 11110. VDD ZO TXP 5 kΩ RXP 7.5 kΩ ZO GND + _ VDD ZO 5 kΩ ZO TXN RXN Transmitter Media 7.5 kΩ GND Receiver Figure 10. High-Speed I/O Directly-Coupled Mode VDD TXP ZO 5 kΩ RXP 7.5 kΩ ZO GND + _ VDD ZO 5 kΩ TXN Transmitter ZO RXN Media 7.5 kΩ GND Receiver Figure 11. High-Speed I/O AC-Coupled Mode POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 15          SCAS652F − AUGUST 2000 − REVISED MAY 2007 APPLICATION INFORMATION 5 Ω at 100 MHz 2.5 V 2.5 V 18 VDD VDDA 0.01 µF VDDPLL GND GNDPLL 64 GNDA TLK2201 17 TESTEN 10 TD0−TD9 22 16 TXP 62 Controlled Impedance Transmission Line 61 Controlled Impedance Transmission Line 54 Controlled Impedance Transmission Line REFCLK PRBSEN 19 LOOPEN 24 Host Protocol Device 47 10 SYNCEN TXN SYNC/PASS RD0−RD9 2 RBC0−RBC1 28 26 ENABLE RXP LOS 32 Rt 50 Ω Rt 50 Ω RBCMODE 15 MODESEL 49 55 JTAG Controller 48 56 27 TCK JTMS RXN 52 JTDI JTRSTN JTDO Figure 12. Typical Application Circuit (AC mode) 16 POST OFFICE BOX 655303 • DALLAS, TEXAS 75265 Controlled Impedance Transmission Line PACKAGE OPTION ADDENDUM www.ti.com 12-Aug-2016 PACKAGING INFORMATION Orderable Device Status (1) TLK2201JRGQE LIFEBUY Package Type Package Pins Package Drawing Qty BGA MICROSTAR JUNIOR GQE 80 360 Eco Plan Lead/Ball Finish MSL Peak Temp (2) (6) (3) TBD SNPB Level-2A-235C-4 WKS Op Temp (°C) Device Marking (4/5) 0 to 70 TLK2201 (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) Eco Plan - The planned eco-friendly classification: Pb-Free (RoHS), Pb-Free (RoHS Exempt), or Green (RoHS & no Sb/Br) - please check http://www.ti.com/productcontent for the latest availability information and additional product content details. TBD: The Pb-Free/Green conversion plan has not been defined. Pb-Free (RoHS): TI's terms "Lead-Free" or "Pb-Free" mean semiconductor products that are compatible with the current RoHS requirements for all 6 substances, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, TI Pb-Free products are suitable for use in specified lead-free processes. Pb-Free (RoHS Exempt): This component has a RoHS exemption for either 1) lead-based flip-chip solder bumps used between the die and package, or 2) lead-based die adhesive used between the die and leadframe. The component is otherwise considered Pb-Free (RoHS compatible) as defined above. Green (RoHS & no Sb/Br): TI defines "Green" to mean Pb-Free (RoHS compatible), and free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material) (3) MSL, Peak Temp. - The Moisture Sensitivity Level rating according to the JEDEC industry standard classifications, and peak solder temperature. (4) There may be additional marking, which relates to the logo, the lot trace code information, or the environmental category on the device. (5) Multiple Device Markings will be inside parentheses. Only one Device Marking contained in parentheses and separated by a "~" will appear on a device. If a line is indented then it is a continuation of the previous line and the two combined represent the entire Device Marking for that device. (6) Lead/Ball Finish - Orderable Devices may have multiple material finish options. Finish options are separated by a vertical ruled line. Lead/Ball Finish values may wrap to two lines if the finish value exceeds the maximum column width. Important Information and Disclaimer:The information provided on this page represents TI's knowledge and belief as of the date that it is provided. TI bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. TI has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. TI and TI suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. Addendum-Page 1 Samples PACKAGE OPTION ADDENDUM www.ti.com 12-Aug-2016 In no event shall TI's liability arising out of such information exceed the total purchase price of the TI part(s) at issue in this document sold by TI to Customer on an annual basis. Addendum-Page 2 IMPORTANT NOTICE Texas Instruments Incorporated and its subsidiaries (TI) reserve the right to make corrections, enhancements, improvements and other changes to its semiconductor products and services per JESD46, latest issue, and to discontinue any product or service per JESD48, latest issue. Buyers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. All semiconductor products (also referred to herein as “components”) are sold subject to TI’s terms and conditions of sale supplied at the time of order acknowledgment. TI warrants performance of its components to the specifications applicable at the time of sale, in accordance with the warranty in TI’s terms and conditions of sale of semiconductor products. Testing and other quality control techniques are used to the extent TI deems necessary to support this warranty. Except where mandated by applicable law, testing of all parameters of each component is not necessarily performed. TI assumes no liability for applications assistance or the design of Buyers’ products. Buyers are responsible for their products and applications using TI components. To minimize the risks associated with Buyers’ products and applications, Buyers should provide adequate design and operating safeguards. TI does not warrant or represent that any license, either express or implied, is granted under any patent right, copyright, mask work right, or other intellectual property right relating to any combination, machine, or process in which TI components or services are used. Information published by TI regarding third-party products or services does not constitute a license to use such products or services or a warranty or endorsement thereof. Use of such information may require a license from a third party under the patents or other intellectual property of the third party, or a license from TI under the patents or other intellectual property of TI. Reproduction of significant portions of TI information in TI data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. TI is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. Resale of TI components or services with statements different from or beyond the parameters stated by TI for that component or service voids all express and any implied warranties for the associated TI component or service and is an unfair and deceptive business practice. TI is not responsible or liable for any such statements. Buyer acknowledges and agrees that it is solely responsible for compliance with all legal, regulatory and safety-related requirements concerning its products, and any use of TI components in its applications, notwithstanding any applications-related information or support that may be provided by TI. Buyer represents and agrees that it has all the necessary expertise to create and implement safeguards which anticipate dangerous consequences of failures, monitor failures and their consequences, lessen the likelihood of failures that might cause harm and take appropriate remedial actions. Buyer will fully indemnify TI and its representatives against any damages arising out of the use of any TI components in safety-critical applications. In some cases, TI components may be promoted specifically to facilitate safety-related applications. With such components, TI’s goal is to help enable customers to design and create their own end-product solutions that meet applicable functional safety standards and requirements. Nonetheless, such components are subject to these terms. No TI components are authorized for use in FDA Class III (or similar life-critical medical equipment) unless authorized officers of the parties have executed a special agreement specifically governing such use. Only those TI components which TI has specifically designated as military grade or “enhanced plastic” are designed and intended for use in military/aerospace applications or environments. Buyer acknowledges and agrees that any military or aerospace use of TI components which have not been so designated is solely at the Buyer's risk, and that Buyer is solely responsible for compliance with all legal and regulatory requirements in connection with such use. TI has specifically designated certain components as meeting ISO/TS16949 requirements, mainly for automotive use. In any case of use of non-designated products, TI will not be responsible for any failure to meet ISO/TS16949. Products Applications Audio www.ti.com/audio Automotive and Transportation www.ti.com/automotive Amplifiers amplifier.ti.com Communications and Telecom www.ti.com/communications Data Converters dataconverter.ti.com Computers and Peripherals www.ti.com/computers DLP® Products www.dlp.com Consumer Electronics www.ti.com/consumer-apps DSP dsp.ti.com Energy and Lighting www.ti.com/energy Clocks and Timers www.ti.com/clocks Industrial www.ti.com/industrial Interface interface.ti.com Medical www.ti.com/medical Logic logic.ti.com Security www.ti.com/security Power Mgmt power.ti.com Space, Avionics and Defense www.ti.com/space-avionics-defense Microcontrollers microcontroller.ti.com Video and Imaging www.ti.com/video RFID www.ti-rfid.com OMAP Applications Processors www.ti.com/omap TI E2E Community e2e.ti.com Wireless Connectivity www.ti.com/wirelessconnectivity Mailing Address: Texas Instruments, Post Office Box 655303, Dallas, Texas 75265 Copyright © 2016, Texas Instruments Incorporated
TLK2201JRGQE 价格&库存
很抱歉,暂时无法提供与“TLK2201JRGQE”相匹配的价格&库存,您可以联系我们找货
