93057553
93057553
    THOMASRESEARCHPRODUCTS
    NFC WAND FOR SELECTSYNC LED DRVR
93057553 数据手册
Hardware Configuration SelectSYNC Hardware Description REV 3-2-18 a) Universal Configurator Module (UCM) 93057530 The UCM has 5 connections ports:  USB2.0 Type-A (ALT COM port)  DB-15 Serial WPC/DALI com port  DB-9 Serial Rset-A com port  USB2.0 Type A USB/ALT com 2 port  USB2.0 Type B PC com port b) Wired Programming Cradle (WPC) 93057529 The WPC has one wired set-up connection port for use by the Serial DB-15 Male-Male (UCM-to-WPC) c) NFC Wand com tool (NFCW) 93057553 The NFC has one wired set-up connection type MiniB port for use by the Cable USB2.0/3.0 Type A-to MiniB (PC-to-NFCW) Note: The NFC Wand must be connected to a USB port on a PC. d) Flying Lead Module com tool (FLM) 93057547 The FLM has four connection posts for wired connection to the flying leads of our DALI programmable driver. It also has a wired set-up connection by the Serial DB-15 Male-Male (UCM-to-FLM) e) Compact Programmer com tool (CP) 93057558 The CP has one wire set-up connection port for use by the Serial DB-15 Male-Male (UCM-to-CP) f) Cable USB2.0 Type A-to-B for PC-to-UCM connection The USB2.0 Type A-to-B (PC-to-UCM) cable is supplied with the UCM. It interconnects the USB2.0 Type-A port of a PC to the Type B port on the Universal Configurator Module, (UCM). g) Cable Serial DB-15 Male-Male for UCM-to-WPC or UCM-to-FLM connection The standard Serial DB-15 (UCM-to-WPC) cable is supplied with the WPC or FLM It interconnects the UCM’s WPC /DALI output port to the Driver Receptacle Module (WPC) input port or the Dali Flying Lead Module (FLM) input port. h) Cable Usb2.0/3.0 Type A-to-MiniB for PC-to-NFCW connection The cable USB2.0/3.0 Type A-to-MiniB (PC-to-NFCW) is supplied with the NFCW. It connects the USB2.0/3.0 Type A, PC output port to the NFC Wand’s USB2.0/3.0 MiniB NFCW input port. The cable must be used directly connected to a PC USB port or powered USB hub. Part # / LED driver 93057517 S025W-056C1300-C01-UN-D2 93057518 S025W-056C1300-C02-UN-D2 93057523 S027W-038C1000-R01-UN-DA1 93057524 S030W-052C1050-L03-UN-D2 93057519 S040W-056C1500-C01-UN-D2 93057520 S040W-056C1500-C02-UN-D2 93057521 S040W-028C1400-L01-UN-D2 93057525 S050W-052C1400-L03-UN-D2 93057522 S075W-038C2000-L02-UN-D2 Configurator Required Hardware/Module UCM Yes 93057530 93057529 WPC Yes 93057530 93057529 WPC Yes 93057530 93057547 FLM No N/A 93057553 NFCW Yes 93057530 93057529 WPC Yes 93057530 93057529 WPC No N/A 93057553 NFCW No N/A 93057553 NFCW No N/A NFCW 93057553 Thomas Research Products • 1225 Bowes Rd • Elgin, IL 60123 USA • T 847-515-3057 • F 847-515-3047 • trpssl.com Hardware Optional CP CP CP CP 93057558 93057558 N/A N/A 93057558 93057558 N/A N/A N/A
93057553 价格&库存
很抱歉,暂时无法提供与“93057553”相匹配的价格&库存,您可以联系我们找货
  • 1+3262.675391+424.23765
库存:4
