PROTO BOARD TINYSHIELD
ASD2009-R
DESCRIPTION
This proto board brings all of the TinyShield signals out to a point that you can solder to. All
of the signals are marked and are spaced with 0.1″ spacing (same spacing as on the
standard Arduino Uno), so a standard 0.1″ header can be used if desired.
This proto board can be ordered with or without a top stackable connector. By default, a
top connector is not needed since the standard method is to use this proto board as the top
board in a TinyDuino stack for the easiest access to the signals. However, when this board
is ordered with the top stackable connector, it can be an inner layer of the TinyDuino stack
(which can be useful in some projects).
Note:This TinyShield replaces all of the older style Proto1, Proto2 and Proto3 boards, which
have been discontinued.
To learn more about the TinyDuino Platform, click here
https://tinycircuits.com/pages/tinyduino-overview
TECHNICAL DETAILS
Pins Supported
o
All Shield signals supported
o
VCC, VBATT,+3V3, +5V, VIN, GND, RSV2, RSV1, RSV0, RESET, 0, 1, 2, 3, 4, 5, 6, 7,
8, 9, SS, MOSI, MISO, SCK, AREF, A0, A1, A2, A3, A4/SDA, A5/SDL
Dimensions
o
20mm x 20mm (.787 inches x .787 inches)
o
Max Height (No Top Connector): (from lower bottom TinyShield Connector to upper
PCB level): 2.81mm (0.111 inches)
o
Max Height (With Top Connector): (from lower bottom TinyShield Connector to upper
PCB level): 5.11mm (0.201 inches)
o
Weight (No Top Connector): 0.70 grams
o
Weight (With Top Connector): 0.85 grams
NOTES
o
When using soldered wires, take care not to allow this to short out to boards above or
below in the stack (ie, some pins could short out to the USB connector if the wires are
long). If needed, use tape to insulate the solder connections
https://tinycircuits.com/products/proto‐board‐tinyshield?variant=14984618887 7‐14‐17
很抱歉,暂时无法提供与“ASD2009-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+28.177101+3.64546
