ASD2020
ASD2020
    TINYCIRCUITS
    ATtiny88 操纵杆 人机接口 TinyDuino 平台评估扩展板
ASD2020 数据手册
    JOYSTICK TINYSHIELD ASD2020 DESCRIPTION This TinyShield lets you add some control to your TinyDuino projects! Control your very own robot or play a video game with your TinyScreen. This TinyShield has two analog joysticks on both sides as well as two push buttons along the top to create a tiny controller for your TinyDuino. This TinyShield uses the I2C bus for communication and can safely run over the full TinyDuino voltage range. Note: This joystick works with the standard TinyScreen but not with the TinyScreen+. To learn more about the TinyDuino Platform, click here https://tinycircuits.com/pages/tinyduino-overview TECHNICAL DETAILS To see what other TinyShields this will work with or conflict with, check out the TinyShield Compatibility Matrix Built in ATTiny88 microcontroller, preprogrammed o Two Analog Joysticks, 10-bit ADC reading for each axis of each joystick returned o Two discrete pushbuttons TinyDuino Power Requirements o Voltage: 3.0V - 5.5V o Current: 5mA. Due to the low current, this board can be run using the TinyDuino coin cell option Pins Used o A5/SCL - I2C Serial Clock line o A4/SDA - I2C Serial Data line Dimensions o 68mm x 25mm (2.68 inches x .984 inches) o Max Height (from lower bottom TinyShield Connector to upper top of joysticks): 12.0 mm (0.472 inches) o Weight: 5.95 grams (.21 ounces) NOTES o This joystick does not work TinyScreen+. Because the TinyScreen+ is a processor board, the connectors for the two board will not line up. https://tinycircuits.com/products/joystick-tinyshield 7-14-17
ASD2020 价格&库存
很抱歉,暂时无法提供与“ASD2020”相匹配的价格&库存,您可以联系我们找货
