Compass TinyShield - ASD2511-R-C
tinycircuits.com/collections/sensors/products/compass-tinyshield
DESCRIPTION
This TinyShield features the high performance and low power Honeywell
HMC5883L 3-axis compass. The HMC5883L includes state-of-the-art, highresolution HMC118X series magneto-resistive sensors plus an ASIC containing
amplification, automatic degaussing strap drivers, offset cancellation, and a
12-bit ADC that enables 1° to 2° compass heading accuracy.
The Compass TinyShield incorporates level shifters and a local power supply
to ensure proper and safe operation over the entire TinyDuino operating
voltage range up to 5V.
To learn more about the TinyDuino Platform, click here
TECHNICAL DETAILS
1/2
To see what other TinyShields this will work with or conflict with, check out
the TinyShield Compatibility Matrix
Honeywell HMC5883L Compass Specs
3-axix (X, Y & Z)
Digital resolution: 12bit (2 milli-gauss Field Resolution in ±8 Gauss Fields)
1° to 2° Degree Compass Heading Accuracy
Wide Magnetic Field Range (+/-8 Oe)
Low Power: 100uA
TinyDuino Power Requirements
Voltage: 3.0V - 5.5V
Current: 100uA Due to the low current, this board can be run using the
TinyDuino coin cell option
Pins Used
A5/SCL - I2C Serial Clock line
A4/SDA - I2C Serial Data line
Dimensions
20mm x 20mm (.787 inches x .787 inches)
Max Height (from lower bottom TinyShield Connector to upper top
TinyShield Connector): 5.11mm (0.201 inches)
Weight: .96 grams (.03 ounces)
Notes
You can also use this shield without the TinyDuino – there are 0.1″
spaced connections for power, ground, and the two I2C signals along the
side of the TinyShield to allow you to connect a different system.
Previous versions of this board will look a bit different and have the
board number ASD2613-R, however they are functionally equivalent to
this updated version and the compass circuitry is identical. Earlier
versions also had two interrupt pins broken out to solder points, these
are not present on the current version of this board.
2/2
很抱歉,暂时无法提供与“ASD2511-R-C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+142.678801+18.54477
