ASL1001-LG
ASL1001-LG
    TINYCIRCUITS
    TINYLILYLED0402 GREEN
ASL1001-LG 数据手册
    TINYLILY LED 0402 ASL1001-LG     DESCRIPTION So you want the smallest possible sewable LED for your project? Try out the TinyLily LED 0402 which sports a total size of just 6.5mm x 2.5mm! Yet this tiny little guy still includes standard TinyLily sewtabs and a current limiting resistor, so you don’t have to worry about blowing it up or adding an external resistor. Available with Red, Green and Amber LED color options. TECHNICAL DETAILS o Washable o Two Sewtabs – 1.2mm in diameter, easy to use with standard conductive thread and needles o Robust Gold Finish – makes soldering easy and is non-corrosive Power Requirements o Voltage: 3.0V - 5.5V o Current: o 1.5mA per LED (3.0V) o 5.0mA per LED (5.0V) Dimensions o 6.5mm x 2.5mm (0.26 inches x 0.1 inches) o Max Height: 1.11mm (0.044 inches) o Ultra-thin 0.61mm (0.024 inches) PCB o Weight: .02 grams (0.0007 ounces)        https://tinycircuits.com/products/tinylily‐led‐0402 10‐16‐17
ASL1001-LG 价格&库存
很抱歉,暂时无法提供与“ASL1001-LG”相匹配的价格&库存,您可以联系我们找货
