ASL1003
ASL1003
    TINYCIRCUITS
    TINYLILY RGB LED
ASL1003 数据手册
TINYLILY RGB LED ASL1003 DESCRIPTION This sewable board features a 5mm RGB LED, enabling you to add 24-bit resolution color to your Tiny Project! This LED has a built in driver IC, so it requires special libraries and serial data, not just applied voltage. The solder tabs allow you to string together multiple LEDs with conductive thread or wire, and you can individually control every LED with just one digital pin. TECHNICAL DETAILS o o o Washable Four Sewtabs – 1.2mm in diameter, easy to use with standard conductive thread and needles Robust Gold Finish – makes soldering easy and is non‐corrosive Power Requirements o Voltage: 3.0V ‐ 5.5V o Current: (depends on color and brightness) o Red: 30mA o Green: 20mA o Blue: 30mA o White: 65mA Dimensions o Dimensions: 10mm diameter(0.394 inches) o Max Height: 2.5mm (0.1 inches) o Ultra‐thin 0.61mm (0.024 inches) PCB o Weight: .192 grams (0.007 ounces) https://tinycircuits.com/products/tinylily‐rgb‐led/12‐12‐18
ASL1003 价格&库存
很抱歉,暂时无法提供与“ASL1003”相匹配的价格&库存,您可以联系我们找货
