ASL2002
ASL2002
    TINYCIRCUITS
    TINYLILY ACCELEROMETER
ASL2002 数据手册
TINYLILY ACCELEROMET ER ASL2002 DESCRIPTION This TinyLily Sewable sensor board features the high performance and low power Bosch BMA250 3-axis accelerometer. The BMA250 allows measurement of accelerations in three perpendicular axes and thus senses tilt, motion, shock, and vibration in your projects. There is also an integrated temperature sensor built in. Even though the BMA250 is designed to run at 1.8V – the Accelerometer TinyShield incorporates level shifters and a local power supply to ensure proper and safe operation over the entire TinyDuino operating voltage range up to 5V. TECHNICAL DETAILS o o o Washable Four Sewtabs – 1.2mm in diameter, easy to use with standard conductive thread and needles Robust Gold Finish – makes soldering easy and is non-corrosive Power Requirements o Voltage: 3.0V - 5.5V Dimensions o Dimensions: 14mm diameter(0.0.55 inches) o Max Height: 2.5mm (0.1 inches) o Ultra-thin 0.61mm (0.024 inches) PCB o Weight: .305 grams (0.0108 ounces) DOWNLOADS o o Schematic Eagle Files https://tinycircuits.com/products/tinylily-accelerometer/12-12-18
ASL2002 价格&库存
很抱歉,暂时无法提供与“ASL2002”相匹配的价格&库存,您可以联系我们找货
