ASM2001-R-L
ASM2001-R-L
    TINYCIRCUITS
    Atmega328P TinyDuino AVR® AVR MCU 8-位 评估板 - 嵌入式
ASM2001-R-L 数据手册
      TINYDUINO PROCESSOR BOARD ASM2001-R-L         DESCRIPTION The TinyCircuits TinyDuino is an Arduino compatible board in an ultra compact package. The TinyDuino processor board is roughly equivalent to the Arduino Uno board – same processor, same signals brought out to a shield connector. In fact, most Arduino sketches will work as is without any changes. The TinyDuino Processor Board is available in three variations: o With Lithium Battery Support - has an on-board Lithium battery charger that will charge the battery when attached to USB o With coin cell battery support - for low power applications, use a simple CR1632 coin cell battery that can be easily changed o Without battery options - the lightest and lowest cost option Main Features: o Atmega328P processor (same as is used on the Arduino Uno) o Power Switch o Status LED o 8MHz ceramic resonator o External power supported with a 0.1″ power connection holes o Supports automatic switching between +5V and VBATT (if +5V is present, it will be used instead of the battery) To learn more about the TinyDuino Platform, click here https://tinycircuits.com/pages/tinyduino-overview TECHNICAL DETAILS o Arduino Compatible o Expandable with Stackable TinyShield Boards o Optional battery connector for CR1612-CR1632 coin cell batteries o Optional Lithium battery connector and charger o 0.1″ spaced solder holes for external power source o Robust Gold Finish – makes soldering easy and is non-corrosive o Ultra compact size and weight (smaller than a US Quarter!) o 20mm x 20mm (.787 inches x .787 inches) o Max Height (without battery holder): 2.9mm (0.12 inches) o Max Height (with coin cell battery holder): 6.58mm (0.26 inches) o o Ultra-thin 0.61mm (0.024 inches) PCB o Weight: 1.10 grams (0.039 ounces) - Lithium version Atmel ATmega328P Microcontroller o 32KB Flash, 2KB RAM, 1KB EEPROM o 1.2mA (typical) @ 3V, 4MHz o Default Clock speed: 8MHz o 2.7V – 5.5V operating voltage o 20 I/Os (14 Digital, 6 Analog / Digital I/O) – All the signals on the Arduino Shield connectors are supported! o Arduino Bootloader preprogrammed (uses approx 0.5 KBytes of Flash Memory) NOTES o If you are brand new to the TinyDuino, buying a kit is the best way to go since it will have all the parts needed. Check out the TinyDuino Kits. o All batteries are sold separately o To program this board, you need to use the TinyShield USB Board o This board does not include a voltage regulator – do not supply more than +5.5V to VBATT or the +5V signal or you will permanently damage the board and ruin your day.                                                             https://tinycircuits.com/products/tinyduino‐processor‐board 7‐14‐17
ASM2001-R-L 价格&库存
很抱歉,暂时无法提供与“ASM2001-R-L”相匹配的价格&库存,您可以联系我们找货
ASM2001-R-L
    • 1+190.228961+24.72513
    库存:13
