TINYLILY MINI PROCESSOR
ASM2101
DESCRIPTION
The TinyCircuits TinyLily Mini is an Arduino compatible module in an ultra compact
package. Designed to be used in e-textile and wearable applications, the TinyLily Mini is
very similar to the Arduino LilyPad with the same processing power and Arduino software
compatibility – but at 1/12th the size!
o
Arduino and LilyPad Compatible
o
Atmel Atmega328P processor (same as is used on the Arduino Uno and LilyPad)
o
Washable
o
Sewtabs for 8 I/O (4 Digital, 4 Analog / Digital) and 4 Power Sewtabs (2 for power,
2 for ground)
Note: To program this board, you need to use the TinyLily Mini USB Board, which is sold
separately.
TECHNICAL DETAILS
o
o
Washable
o
Robust Gold Finish – makes soldering easy and is non-corrosive
o
Sewtabs for 8 I/O (4 Digital, 4 Analog / Digital) and 4 Power Sewtabs (2 for power, 2 for
ground)
o
Sewtabs are 1.2mm in diameter, easy to use with standard conductive thread and
needles
o
Arduino Bootloader preprogrammed (uses approx 0.5 KBytes of Flash Memory)
o
USB expansion header (for use with the TinyLily Mini USB Board)
o
Ultra compact size and weight (smaller than a US Dime!)
o
o
o
14.0mm (0.55 inch) diameter
o
Max Height: 2.8mm (0.11 inches)
o
Ultra-thin 0.61mm (0.024 inches) PCB
o
Weight: .39 grams (.01 ounces)
Atmel ATmega328P Microcontroller
o
32KB Flash, 2KB RAM, 1KB EEPROM
o
1.2mA (typical) @ 3V, 4MHz
o
Clock speed: 8MHz
2.7V – 5.5V operating voltage
NOTES
o
If you are brand new to the TinyLily, buying a kit is the best way to go since it will have
all the parts needed. Check out the kits.
o
This board does not include a voltage regulator – do not supply more than +5.5V or you
will permanently damage the board and ruin your day.
https://tinycircuits.com/products/tinylily‐mini‐processor 7‐14‐17
很抱歉,暂时无法提供与“ASM2101”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+94.864861+12.30864
