ASR00008
ASR00008
    TINYCIRCUITS
    LITHIUM ION POLYMER BATTERY 3.7V
ASR00008 数据手册
Lithium Ion Polymer Battery 1100mAh - ASR00008 tinycircuits.com/products/lithium-ion-polymer-battery-3-7v-1100mah DESCRIPTION This is a tiny rechargeable Lithium ion polymer battery that fits perfectly behind the TinyDuino Processor board to power your projects. The battery has a capacity of 1100mAh at 3.7V, the voltage can range from 4.2V when fully charged to 3.0V when completely discharged. The battery includes protection circuitry to protect the battery from over charging or completely discharging. This battery includes a micro JST SH connector, which is used on TinyCircuits products that support Lithium ion batteries. ​Note: ​As the 1100mAH battery is much larger in capacity than our other battery sizes, charge time will be significantly longer. TECHNICAL DETAILS 1/2 Dimensions: 40.5mm x 41.5mm x 6.1mm (1.59" x 1.63" x 0.24") Wire Length: 40.0mm (1.575") Weight: 18.50 grams 3.7V, 1100mAh 2/2
ASR00008 价格&库存
很抱歉,暂时无法提供与“ASR00008”相匹配的价格&库存,您可以联系我们找货
