ASR00016
ASR00016
    TINYCIRCUITS
    直流电机 齿轮电机
ASR00016 数据手册
      200:1 Gear Reduction Motor ASR00016 DESCRIPTION  Add motion to your TinyDuino project! This gear motor uses the same JST connector that can be found on our Dual Motor TinyShield, meaning it can be plugged right in without any soldering or crimping. This motor has a built in gearbox which achieves 200:1 speed reduction for high torque. This makes it great for applications like robotics and anything else that would require high torque in a small package. Fits any wheel, gear, or other attachment that fits a 3mm diameter D profile shaft, like our 45mm Wheels. TECHNICAL DETAILS Dimensions o Wire Length: 100mm o Shaft Diameter x Length: 3mm x 9mm o Motor and Gearbox Dimensions: 26mm L, 12mm W, 10mm T o JST-SH Connector Pitch: 1mm (0.039")                                          https://tinycircuits.com/products/200‐1‐gear‐reduction‐motor#downloads‐anchor 1‐24‐18
ASR00016 价格&库存
很抱歉,暂时无法提供与“ASR00016”相匹配的价格&库存,您可以联系我们找货
ASR00016
