ASR00029
ASR00029
    TINYCIRCUITS
    BOX PLASTIC BLK 2.01"L X 2.01"W
ASR00029 数据手册
        PLASTIC PROJECT ENCLOSURE BOX 51MM X 51MM X 20MM ASR00029 DESCRIPTION Is your TinyDuino looking a little bare? Stick it in a plastic enclosure box to protect it and give your project a clean look! This enclosure box is made of sturdy black plastic, which makes it easy to cut and drill. It also makes this little box tough! The two halves are assembled with two steel screws to hold it together. The case tapers towards the bottom, so at it's widest point, the exterior dimensions are 51mm wide, 51mm tall, and 20mm deep. Interior dimensions at it's most narrow point are 44.5mm wide, 44.5mm tall, and 15.1mm deep. That's enough space to have two stacks of four boards and a 150mAh battery. Note: The pictured TinyDuino Processor is not included, and is only shown to provide a sense of scale. To learn more about the TinyDuino Platform, click here TECHNICAL DETAILS Dimensions o Interior Dimensions: 44.5 x 44.5 x 15.1mm o Exterior Dimensions: 51 x 51 x 20mm o Weight: 18g (0.635 oz.)        https://tinycircuits.com/products/plastic‐project‐enclosure‐box‐51mm‐x‐51mm‐x‐20mm 4‐27‐18
ASR00029 价格&库存
很抱歉,暂时无法提供与“ASR00029”相匹配的价格&库存,您可以联系我们找货
