ASR00030-G
ASR00030-G
    TINYCIRCUITS
    PREWIRED LED GREEN
ASR00030-G 数据手册
          PRE-WIRED 3MM LED ASR00030-R Color Red ASR00030-G Color Green ASR00030-B Color Blue     DESCRIPTION This is one of the easiest ways to add some color to your TinyDuino project. These crystal clear 3mm LEDs are already wired with a built in current limiting resistor, so all you need to do is solder the pre-tinned wires to a power source. TECHNICAL DETAILS LED Diameter: 3mm Wire Length: 20mm Resistor Value: 510 Ohms Operating Voltage: 3-12V Current Draw: 10-30mA (Depending on color and supply voltage)        https://tinycircuits.com/products/pre‐wired‐3mm‐led 4‐27‐18
ASR00030-G 价格&库存
很抱歉,暂时无法提供与“ASR00030-G”相匹配的价格&库存,您可以联系我们找货
