AST1029
AST1029
    TINYCIRCUITS
    PCM12SMTR 滑动开关 人机接口 Wireling 平台评估扩展板
AST1029 数据手册
SLIDE SWITCH WIRELING AST1029 This Wireling uses the same slide switch found on our Tiny Arcade Kit, as a simple logic level switch. Use this board to mechanically choose between HIGH or LOW. Note* 5-Pin Wireling cables not included and sold separately. Specs • • Cover: Stainless Steel Mechanical Lifecycle: 10,000 cycles TinyDuino Power Requirements • Voltage: 3.0V - 5.5V Pins Used • • A5/SCL - I²C Serial Clock line A4/SDA - I²C Serial Data line Dimensions • • • 10mm x 10mm (.394 inches x .394 inches) Max Height (from the lower bottom of Wireling to upper top Wireling Connector): 3.70mm (0.15 inches) Weight: 1 gram (.04 ounces) You can also use this shield without the TinyDuino – modifying the connecting cable by removing the opposite connector and stripping/tinning the wires, you can solder the connector cable to any other microcontroller board of your choice! • DOWNLOADS • • • • PCM12SMTR Datasheet Schematic Eagle Files Sample Arduino code https://tinycircuits.com/products/switch-wireling/2-24-20
AST1029 价格&库存
很抱歉,暂时无法提供与“AST1029”相匹配的价格&库存,您可以联系我们找货
AST1029
  • 1+28.177101+3.64546
