AST1024
AST1024
    TINYCIRCUITS
    VL53L0X 光,3D 飞行时间(ToF) 传感器 Wireling 平台评估扩展板
AST1024 数据手册
TOF DISTANCE SENSOR WIRELING AST1024 This Wireling features a VL53L0X Infrared Time-of-Flight sensor, most often used for distance detection between 2cm and 2m! Note* 5-Pin Wireling cables not included and sold separately. VL53L0X Time-of-Flight Sensor Specs • • • • Fully integrated miniature module o 940 nm laser VCSEL o VCSEL driver o Ranging sensor with advanced embedded microcontroller Fast, accurate distance ranging o Measures absolute range up to 2m o Reported range is independent of the target reflectance o Advanced embedded optical cross-talk compensation to simplify cover glass selection Eye safe I²C o Compatible with 400 kHz (FAST mode) o Address: 0x52 TinyDuino Power Requirements • • Voltage: 3.0V - 5.5V Current: o Hardware Standby: 5uA o Software Standby: 6uA o Timed Ranging Inter Measurement: 16uA o Active Ranging Average Consumption: 19mA Pins Used • • A5/SCL - I²C Serial Clock line A4/SDA - I²C Serial Data line Dimensions • • • 10mm x 10mm (.393 inches x .393 inches) Max Height (from the lower bottom of Wirelingto upper top Wireling Connector): 3.70mm (0.15 inches) Weight: 1 gram (.04 ounces) You can also use this Wireling without the TinyDuino – modifying the connecting cable by removing the opposite connector and stripping/tinning the wires, you can solder the connector cable to any other microcontroller board of your choice! • • • • VL53L0X Datasheet Schematic Eagle Files Sample Arduino code https://tinycircuits.com/products/tof-distance-sensor-wireling-vl53l0x?_pos=1&_sid=c90a8965e&_ss=r/2-24-20
AST1024 价格&库存
很抱歉,暂时无法提供与“AST1024”相匹配的价格&库存,您可以联系我们找货
AST1024
  • 1+94.813501+12.30198
库存:11
