AST2001
AST2001
    TINYCIRCUITS
    分接板 连接性 Wireling 平台评估扩展板
AST2001 数据手册
        0.1" BREAKOUT I²C WIRELING AST2001 Includes 0.1" connections for GND, 3V3, SCL, SDA, and INT so that you can connect any I2C device, button, or another device into a Wireling project. Note* 5-Pin Wireling cables not included and sold separately. TinyDuino Power Requirements  Voltage: 3.0V - 5.5V Pins Used   A5/SCL - I²C Serial Clock line A4/SDA - I²C Serial Data line Dimensions    10mm x 13mm (.394 inches x .512 inches) Max Height (from the lower bottom of Wireling to upper top Wireling Connector): 3.70mm (0.15 inches) Weight: 1 gram (.04 ounces) You can also use this Wireling without the TinyDuino – modifying the connecting cable by removing the opposite connector and stripping/tinning the wires, you can solder the connector cable to any other microcontroller board of your choice!                 https://tinycircuits.com/products/0‐1‐breakout‐i2c‐wireling?_pos=1&_sid=320816804&_ss=r/2‐24‐20
AST2001 价格&库存
很抱歉,暂时无法提供与“AST2001”相匹配的价格&库存,您可以联系我们找货
