ASL1201
ASL1201
    TINYCIRCUITS
    TINYLILYBATTERYADAPTER
ASL1201 数据手册
      TINYLILY BATTERY ADAPTER ASL1201         DESCRIPTION Connect up your TinyLily Mini to standard battery packs that use the JST SH connector (the kind that we sell at TinyCircuits). You can also use this without the JST connector with two large through holes to connect to an external power supply or battery pack. Note: The battery is not included. TECHNICAL DETAILS o Washable o 2-Pin JST SH Connector to allow external batteries to be plugged in o Includes two solder tabs as an extra point to bring in external power o Robust Gold Finish – makes soldering easy and is non-corrosive Dimensions o Dimensions: 12mm x 7mm (0.472 inches x 0.276 inches) o Max Height: 3.7mm (0.146 inches) o Ultra-thin 0.61mm (0.024 inches) PCB o Weight: 0.32 grams (0.011 ounces)                                                               https://tinycircuits.com/products/tinylily‐battery‐adapter 10‐16‐17
ASL1201 价格&库存
很抱歉,暂时无法提供与“ASL1201”相匹配的价格&库存,您可以联系我们找货
