5-PIN WIRELING CABLE
ASR00022
DESCRIPTION
Wirelings use a 5 Pin Cable in order to make our platform plug-andplay so you can build fast without soldering or using messy
breadboards. These cables come in lengths of 50mm, 100mm, and
200mm and a variety of quantities.
These cables can be cut and used to solder other components so that
they can be easily used with all of the Wireling Platform.
Power: Two wires are used for power (3V3) and ground (GND) in
order to power the connected Wireling (of course!)
Communication: Many Wirelings use I²C, a serial communication
protocol that uses two other wires for SDA and SCL to collect
complex data like temperature readings.
Analog Pin: The fifth wire is connected to an Analog pin for
Wireling that just need an I/O pin to function, like the Momentary
Button, and the RGB LEDs.
https://tinycircuits.com/products/5‐pin‐extension‐cable?_pos=1&_sid=c9e1d32f7&_ss=r/2‐24‐20
很抱歉,暂时无法提供与“ASR00022”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8.718331+1.13247
