193A
193A
    TPI(TPI 公司)
    自动/手动 手持型 数字(DMM) 万用表 10.0 位 LCD 条码图形 显示 电容,电流,频率,电阻,温度,电压 功能特性 最小/最大,相对
193A 数据手册
193A True-RMS Auto Ranging Automotive DMM True-RMS Auto Ranging Automotive DMM LCD Display 40000 count with 42 segment bar graph. REC (Record Mode) Store minimum, maximum, and average readings over a measurement period. RANGE Manually select the appropriate range AC/DC Manually select AC or DC measurement functin. FUNCTION Toggle between functions on Ohm, TEMP, and IG modes Hz (Frequency) Measure the frequency of sensors and signals. Ω (Ohms, Resistance) Measure the resistance of spark plug wires, coils, sensors, and continuity of wiring. ACmV and DCmV Ranges Additional 40 millivolt DC range with 0.01mV resolution for improved accuracy when performing low voltage measurements. DCV, ACV (DC Volts, AC Volts) Measure the voltage of circuits and sensors. Measure the voltage of ABS wheel sensors. REL (Relative Mode) Factor out lead resistance for improved low ohm measurements or compare readings to a known standard. Can also be used for differential measurements. (Capacitance) Measure the capacitance of condensors or capacitors found in today's hybrid automobiles. IP, IG (Automotive Functions) Measure RPM, Duty, Dwell, mS pulse width, Frequency. Built in Tilt Stand The tilt stand in built into the instrument housing adding strength and integrity to the design. HOLD Lock the reading on the display for hard to read locations or future reference. Quickly Test Condition of Internal Fuses You can determine the status of the internal fuses before you open the battery/fuse compartment. Simply set the instrument to the diode test function, plug the black test lead into the "VΩ" input jack and touch the prod end of the black lead to the metal inside the "A" or "UAmA" input lack. If the meter reads "OL, the fuse is blown. If there is a reading on the LCD besides "OL", the fuse is good. PEAK-H (Peak Hold) Capture signals spikes as fast as 1mS to diagnose intermittant events. Separate Fuse/Battery Compartment Easily replace fuses and batteries in this separate compartment. Fuses are clearly labeled with replacement part number. CYL (Cylinder) Selects the number of cylinders in IG mode. TEMP (Temperature) Measure temperature with included temperature probe. AC/DC Current Functions Measure the parasitic draw from the battery. UL61010-1 CAT II-1000V, CAT III-600V POLLUTION DEGREE 2 Safety! cULus 61010-1 Listed Meets CE and IEC61010-1 safety standards. Test the TPI Advantage: Value, Performance, Service, Safety www.testproductsintl.com 800-368-5719 193a True-RMS Auto Ranging Automotive DMM Test the TPI Advantage: Value, Performance, Service, Safety Copyright © 2022 Test Products International, Inc. www.testproductsintl.com www.testproductsintl.com 800-368-5719 193A Product Sheet 0622
很抱歉,暂时无法提供与“193A”相匹配的价格&库存,您可以联系我们找货
