DK-TD2023
DK-TD2023
    TRANSFORMING(转型)
    带子 多卷胶纸座(3" 卷芯) 胶带宽度
DK-TD2023 数据手册
Rev: 2022-01-20 Industrial Tape Dispenser A high quality steel desktop tape dispenser comes with a weight rubber lined base to secure the dispenser to the worksurface. The dispensers are compatible with tapes with a 3 in. core diameter and the maximum outside roll diameter that can be supported/hold is 5 in. so it works perfectly with office supply tapes and ESD tapes from Transforming Technologies. The extra-wide serrated blade reduces the working time required to align the tape with the cutting edge, which increases speed and efficiency. A pivoting blade guard provides protection from accidental contact. When closed, it will also assist in keeping the tape secure from rolling back on itself. The two available sizes make way for wider rolls of antistatic tape, or mixing and matching multiple widths on the same ESD tape dispenser. Features • High Quality Steel Desktop Dispenser • Weighted-Rubber Lined Based for Stability and One Hand use • Serrated Blade with Pivoting Blade Guard for Safety • Specifications: Material: Color: Size: Capabilities: Safety: Powder Coated Steel Gray/Blue 10.25 x 6.5in TD1023: 1Roll TD2023: 2 Rolls Pivoting Blade Guard Part Numbers: TD1023 TD2023 Tape Dispenser—1 roll, 3in Tape Dispenser—2 roll, 3in For Use With Tape Up To 3in Wide Applications: Industrial grade steel desk tape dispenser that's made for 3-inch diameter core tape. It can hold up to a 5-inch outside roll diameter, so it's ideal for office supply, packing and anti-static tapes. This document is prepared for our customers as a service, and is to the best of our knowledge true and accurate. However, it is understood and agreed by the users of this document that we will accept no liability for the conclusions reached. Users of this document may therefore wish to perform additional testing before determining that products mentioned are suitable. www.transforming-technologies.com 3719 King Road Toledo Ohio 43617 Phone: 419-841-9552 info@transforming-technologies.com
DK-TD2023 价格&库存
很抱歉,暂时无法提供与“DK-TD2023”相匹配的价格&库存,您可以联系我们找货
