IZD0007
IZD0007
    REDPITAYA(红火龙果)
    STEMLab 125-14 多用途测量 C,Jupyter,LABview,MATlab,Python,Scilab,Vivado 初级入门套件
IZD0007 数据手册
STEMlab 125‐14 Starter Kit  Order number: 27761   Product information "STEMlab 125-14 Starter Kit" STEMLab 125-14 (with original Red Pitaya v1.1) Formerly Red Pitaya Starter Kit. STEMLab is available in two versions and both offer the same functions and features with the difference in technical specification of high-frequency inputs and outputs, RAM capacity some other differences (find more info in the comparison table bellow). They are addressed to target different groups and / or needs. Where STEMLab 14 has 14bit input / output channels for highly accurate measurement results in professional environment, STEMLab 10 has 10bit input / output channels and is perfect for universities, students and makers. Package Content   STEMlab 125-14 board (Red Pitaya v1.1 board) Accessories (preloaded SD card 4GB C6, interchangeable power supply, 1 m Ethernet cable)     4 different applications (oscilloscope, signal generator, spectrum analyzer, Bode analyzer) Marketplace access MATLAB/LABVIEW remote control Possibility to create own app (open source code available)       STEMlab 125-10 STEMlab 125-14       STEMLab 125-14 (originally Red Pitaya v1.1) vs. STEMLab 125-10 STEMLab is available in two versions and both offer the same functions and features with the difference in technical specification of high-frequency inputs and outputs, RAM capacity some other differences (find more info in the comparison table bellow). They are addressed to target different groups and / or needs. Where STEMLab 14 has 14bit input / output channels for highly accurate measurement results in professional environment, STEMLab 10 has 10bit input / output channels and is perfect for universities,students and makers. STEMLAB 125-10 STEMLAB 125-14 Processor Processor DUAL CORE ARM CORTEX A9 DUAL CORE ARM CORTEX A9 Processor DUAL CORE ARM CORTEX A9 DUAL CORE ARM CORTEX A9 FPGA FPGA Xilinx Zynq 7010 SOC Xilinx Zynq 7010 SOC FPGA Xilinx Zynq 7010 SOC Xilinx Zynq 7010 SOC RAM 256MB (2Gb) 512MB (4Gb) System memory Micro SD up to 32GB Micro SD up to 32GB Console connection USB to serial converter required micro USB Power connector Micro USB Micro USB Power connector Micro USB Micro USB Basic Power consumption Connectivity RF inputs 5V, 1,5A max 5V, 2A max STEMLAB 125-10 STEMLAB 125-14 Ethernet 1Gbit 1Gbit USB USB 2.0 USB 2.0 WIFI requires WIFI dongle requires WIFI dongle Synchronisation - Daisy chain connector (up to 500 Mbps) STEMLAB 125-10 STEMLAB 125-14 RF input channels 2 2 Sample rate 125 MS/s 125 MS/s ADC resolution 10 bit 14 bit Input impedance 1MOhm/10pF 1MOhm/10pF Full scale voltage range +-20 V +-20 V Absolute max. Input voltage range 30V 30V Input ESD protection Yes Yes Overload protection Protection diodes Protection diodes STEMLAB 125-10 STEMLAB 125-14 2 2 RF outputs RF output channels Sample rate 125 MS/s 125 MS/s DAC resolution 10 bit 14 bit Load impedance 50 Ohm 50 Ohm Voltage range +-1V +-1V Ouput slew rate 200V/us 200V/us Short circut protection Yes Yes Connector type SMA SMA STEMLAB 125-10 STEMLAB 125-14 Digital IOs 16 16 Analog inputs 4 4 Analog inputs voltage range 0-3,5V 0-3,5V Sample rate 100kS/s 100kS/s Resolution 12bit 12bit Analog outputs 4 4 Analog outputs voltage range 0-1,8V 0-1,8V Communication interfaces I2C, SPI, UART I2C, SPI, UART Available voltages +5V,+3,3V,-4V +5V,+3,3V,-4V Extension connector https://shop.trenz-electronic.de/en/27761-STEMlab-125-14-Starter-Kit 12/20/2016
IZD0007 价格&库存
很抱歉,暂时无法提供与“IZD0007”相匹配的价格&库存,您可以联系我们找货
