TE0720-03-1CFA-S
TE0720-03-1CFA-S
    TRENZELECTRONIC
    STARTER KIT XILINX ZYNQ MICROSOM
TE0720-03-1CFA-S 数据手册
TE0720-03-1CFA-S Starter Kit • Order number: TE0720-03-1CFA-S Product information "TE0720-03-1CFA-S Starter Kit" The Trenz Electronic Starter Kit TE0720-03-1CFA-S consists of a TE0720-03-1CFA module on a TE0703-05 carrier board including heatsink. Supplied with a 5 V power supply, two VG96 connectors (DIN 41612), a 16 GB micro SD card and a USB cable. TE0720-03-1CFA The Trenz Electronic TE0720-03-1CFA are SoC modules with commercial temperature range integrating a Xilinx Zynq-Z020, a gigabit Ethernet transceiver, 1 GByte DDR3 SDRAM, 8 GByte e.MMC, 64 MByte Flash memory for configuration and operation, and powerful switch-mode power supplies for all on-board voltages. A large number of configurable I/O's is provided via rugged highspeed stacking strips. TE0720-03-1CFA Key Features • • • • • • • • • • • • • • • • • • • Xilinx XC7Z020-1CLG484C Rugged for high shock and vibration ARM dual-core Cortex-A9 MPCore 10/100/1000 tri-speed Gigabit Ethernet transceiver (PHY), SGMII accessible on a board-toboard connector USB 2.0 high speed ULPI transceiver 32-Bit-wide 1 GByte DDR3 SDRAM 32 MByte QSPI Flash memory (for configuration and operation) 8 GByte e.MMC (up to 32 GByte) Plug-on module with 2 × 100-pin and 1 x 60-pin high-speed hermaphroditic strips 152 FPGA I/O's (75 LVDS pairs possible) and 14 MIO's available on board-to-board connectors On-board high-efficiency DC-DC converters o 4.0 A x 1.0 V power rail o 1.5 A x 1.5 V power rail o 1.5 A x 1.8 V power rail System management and power sequencing eFUSE bit-stream encryption AES bit-stream encryption Valid MAC Address and 2K serial EEPROM SHA-256 authentication chip with unique serial number RTC, temperature compensated 3 user LED Evenly-spread supply pins for good signal integrity Recommended Software Vivado HL WebPACK Edition (free version) The Vivado Design Suite HL WebPACK Edition is the FREE version of the design suite. Vivado HL WebPACK delivers instant access to some basic Vivado features and functionality at no cost. Overview of all editions of Vivado Design Suite TE0703-05 base board The Trenz Electronic TE0703-05 carrier board offers an economical way to connect every Trenz Electronic 4 x 5 cm SoC micromodule and connect it with your own circuits. TE0703-05 Key Features • • • • • • • • • • • • • 2 x VG96 Connectors (Mounting Holes and Solder Pads) SDIO Port Expander with Voltage-Level Translation Micro SD Card Connector - Zynq SDIO0 Bootable SD port 4 x User LEDs o D1 and D2 are connected to the Carrier Controller, their function depends on the Firmware o D3 and D4 are connected to the 4x5 Module B2B Connector pins, and are directly controlled by the module Mini USB Connector (USB JTAG and UART Interface) 1 x User Push Button o Connected to "intelligent Carrier Controller (iCC)" and can be used as module reset button. Other usage possible, actual function depend on the code loaded into iCC. RJ45 GbE Connector USB Host Connector Barrel jack for 5V* Power Supply 4A High-Efficiency Power SoC DC-DC Step-Down Converter with Integrated Inductor (Enpirion EN6347) for 3.3V Power Supply Trenz 4x5 Module Socket (3x Samtec LSHM Series Connectors) USB JTAG and UART Interface (FTDI FT2232H), compatible with Xilinx Tools (also with many other tools) 4 User DIP Switches o Enable/disable update of the "intelligent Carrier Controller" o MIO0 (readable signal by iCC and Module) o 2 "Mode" bits Package Content TE0720-03-1CFA-S Starter Kit • • • • • • • 1 x TE0720-03-1CFA SoC Micromodule with Xilinx Zynq-7020 XC7Z020-1CLG484C 1 x TE0703-05 carrier board for Trenz Electronic modules with 4 x 5 cm form factor 1 x Pre-installed heatsink for TE0720, spring-loaded 2 x VG96 Connectors (DIN 41612) 1 x Power supply 5V with 4000 mA current 1 x 16 GB Class 4 microSDHC card 1 x USB cable, Typ A to Typ B Mini, 2 meter length Important Notes All VCCIO Jumpers are set for 3.3 V IO supply in this Starter Kit. https://shop.trenz-electronic.de/en/TE0720-03-1CFA-S-TE0720-03-1CFA-S-Starter-Kit?path=Trenz_Electronic/Modules_and_Module_Carriers/4x5/TE0720/REV03/Documents 6-8-17
TE0720-03-1CFA-S 价格&库存
很抱歉,暂时无法提供与“TE0720-03-1CFA-S”相匹配的价格&库存,您可以联系我们找货
