TE0803-03-4DE21-L
TE0803-03-4DE21-L
    TRENZELECTRONIC
    MODULE SOM TE0803-03
TE0803-03-4DE21-L 数据手册
  MPSoC Module with Xilinx Zynq UltraScale+ ZU4EV-1E, 4 GByte DDR4, 5.2x7.6 cm, LP  Order number: TE0803-03-4DE21-L       Product information "MPSoC Module with Xilinx Zynq UltraScale+ ZU4EV-1E, 4 GByte DDR4, 5.2x7.6 cm, LP" This article is the replacement of the TE0803-02-04EV-1E3. All changes caused by the new revision are included in the Product Change Notification (PCN). Identical to variant TE0803-xx-4DE11-A except for the lower 1 mm Samtec socket strips and the 4 GByte DDR4 SDRAM. The Trenz Electronic TE0803-03-4DE21-L is an industrial-grade MPSoC module integrating a Xilinx Zynq UltraScale+ with ZU4EV, 4 GByte DDR4 SDRAM, 128 MByte Flash memory for configuration and operation, and powerful switch-mode power supplies for all on-board voltages. A large number of configurable I/O's is provided via rugged high-speed stacking connections. All this on a tiny footprint of 5.2 x 7.6 cm at the most competitive price. These high-density integrated modules are smaller than a credit card and available in several variants. All parts are at least extended temperature range of 0°C to +85°C. The module operating temperature range depends on customer design and cooling solution. Please contact us for options. This product is or has been in development until recently. For this reason it is possible that no complete documentation is stored yet. This product is not always in stock, but will be produced on customer order (on demand). Please ask for any minimum quantities. Key Features               Xilinx Zynq UltraScale+ XCZU4EV-1SFVC784E ZU4EV, 784 Pin Packages Dimensions: 5.2 x 7.6 cm Plug-on module with 4 x 160 pin B2B connectors (low profile, 1 mm) 3 mm mounting holes for skyline heat spreader Rugged for shock and high vibration 4 GByte 64-Bit width DDR4 SDRAM 128 MByte QSPI Boot Flash dual parallel 2 KBit Serial EEPROM for MAC Address 48 High-density (HD) I/O's (2 banks) Graphic Processing Unit (GPU) + Video codec unit (VCU) User I/O o 65 x multi-use I/O's (MIO) o 156 high-performance (HP) I/O's (3 banks) o Serial transceiver: PS GTR 4; PL GTH 4 o Programmable 4-channel PLL clock generator All power supplies on board, single 3.3V power source required Evenly spread supply pins for good signal integrity Other assembly options for cost or performance optimization plus high volume prices available on request. Recommended Software Vivado Design Suite - HLx Edition Download Vivado Design Suite HLx Editions include Partial Reconfiguration at no additional cost with the Vivado HL Design Edition and HL System Edition. In-warranty users can regenerate their licenses to gain access to this feature. Overview of all Editions of Vivado Design Suite Editions Development Support There is a base board available for this module. Latest documentation, design support files and reference designs with source files are available for download free of charge. Scope of Delivery  1 x MPSoC module TE0803-03-4DE21-L with Zynq UltraScale+ ZU4EV, low profile Additional Information    Manufacturer's article number: TE0803-03-4DE21-L Trenz Electronic TE0803 Wiki Support Forum All modules produced by Trenz Electronic are developed and manufactured in Germany. The online pictures of this product are not a legally binding offer, but are symbol pictures for illustration and presentation only.               https://shop.trenz‐electronic.de/en/TE0803‐03‐4DE21‐L‐MPSoC‐Module‐with‐Xilinx‐Zynq‐UltraScale‐ZU4EV‐1E‐4‐GByte‐DDR4‐5.2x7.6‐cm‐LP?path=Trenz_Electronic/Modules_and_Module_Carriers/5.2x7.6/TE0803/REV03/Documents/6‐12‐19
TE0803-03-4DE21-L 价格&库存
很抱歉,暂时无法提供与“TE0803-03-4DE21-L”相匹配的价格&库存,您可以联系我们找货
