TE0841-02-035-2I
TE0841-02-035-2I
    TRENZELECTRONIC
    IC MODULE USCALE 2GB 64MB
TE0841-02-035-2I 数据手册
Micromodule with Xilinx Kintex UltraScale KU035, 2 GByte DDR4, Speedgrade 2 Order number: TE0841-02-035-2I Product information "Micromodule with Xilinx Kintex UltraScale KU035, 2 GByte DDR4, Speedgrade 2" The Trenz Electronic TE0841-02-035-2I is a powerful FPGA module integrating a Xilinx Kintex UltraScale KU035, 2 GByte DDR4, 64 MByte (512 MBit) SPI Boot Flash for configuration and operation, and powerful switch-mode power supplies for all on-board voltages. A large number of configurable I/O's is provided via rugged high-speed stacking strips. All this on a tiny footprint, smaller than a credit card, at the most competitive price. Modules in 4 x 5 cm form factor are fully mechanically and largely electrically compatible among each other. All parts are at least industrial temperature range of -40°C to +85°C. The module operating temperature range depends on customer design and cooling solution. Please contact us for options. Key Features • • • • • • • Xilinx Kintex UltraScale KU035 FPGA XCKU035-2SFVA784I Rugged for industrial application Size: 40 x 50 mm 3 mm mounting holes for skyline heat spreader 2 GByte (2 x 1 GByte) 16-Bit width DDR4 SDRAM 64 MByte SPI Boot Flash B2B Connectors: 3 x Razor Beam, total 260 terminals o User I/O: HR 56, HP 84 o Serial transceiver: GTH 8 lanes (all) o GT clock inputs: 2 • Clocking o o • Si5338 - 4 output PLL, GT and PL clocks 200 MHz LVDS oscillator Power o o • All power supplies on board, single supply operation supported. User defined IO-Bank power Evenly spread supply pins for good signal integrity. Other assembly options for cost or performance optimization plus high volume prices available on request. Recommended Software Vivado HL Design Edition Overview Xilinx Vivado Versions Development Support There are different base boards available for this module. Latest documentation, design support files and reference designs with source files are available for download free of charge. Package Content • 1 x TE0841-02-035-2I Micromodule 4 x 5 cm mit Kintex UltraScale XCKU035 (industrial temperature range) All modules produced by Trenz Electronic are developed and manufactured in Germany. https://shop.trenz-electronic.de/en/TE0841-02-035-2I-Micromodule-with-Xilinx-Kintex-UltraScale-KU035-2-GByte-DDR4-Speedgrade-2?path=Trenz_Electronic/Modules_and_Module_Carriers/4x5/TE0841/REV01 3-23-18
TE0841-02-035-2I 价格&库存
很抱歉,暂时无法提供与“TE0841-02-035-2I”相匹配的价格&库存,您可以联系我们找货
