TE0887-02M
TE0887-02M
    TRENZELECTRONIC
    ICOBOARD V1 8MBIT SRAM
TE0887-02M 数据手册
    icoBoard Version 1.1 with 8 MBit SRAM  Order number: TE0887-02M   Product information "icoBoard Version 1.1 with 8 MBit SRAM" The icoBoard contains a Lattice FPGA with 8k LUT, 100 MHz max. clock, 8 MBit of SRAM and is programmable in Verilog by a complete open source FPGA toolchain. The icoBoard is pin-compatible with the RaspberryPi 2B and all newer versions and any board using the same pinout. Bitstreams for programming the FPGA can directly be generated on the RaspberryPi. The ICE40 FPGA is a cheap FPGA without special hardware blocks like multipliers or SerDes or SDRAM interfaces. With its 8k LUT he is one of the smaller FPGAs, but large enough to hold significant projects like a complete Risc-V 32 bit SoC. The icoBoard is a perfect learning tool to get the feet wet with logic circuit design in Verilog without having to do the heavy lifting of the professional huge programming tools from Xilinx or Altera. When Professors want to introduce their students to Verilog, it is much easier for them to hand out the open source toolchain directly than to ask students to register with a manufacturer to get a student license and to install from the manufacturer several GByte. The PMod connectors make it very easy to work with a wide variety of sensors and interfaces. A selection of PMod sensors can be found at trenz-electronic.de/pmodlist. To load the bitstream into the flash memory of the icoBoard, a RaspberryPi is needed. Key Features           Lattice ICE40HX8k Supported by the open source toolchain icoTC consisting of Yosys, ArachnePnR, icestorm Mainly for learners and tinkerers 4 PMod connectors with unbuffered 3.3 V interfaces 4 by 16 100mil I/O connectors 4 flatflex connectors with 36 3.3 I/O lines each 16-Bit-wide 8 MBit SRAM 16 MByte SPI Flash memory for storing 4 bitstreams or data 3 programmable status LED, green 2 push buttons If IicoBoard is connected to RaspberryPi, power is supplied by RaspberryPi. If icoBoard is operated standalone, 5V power need to be provided to the power supply pins. A working microSD card image for the RaspberryPi with all tools is available for download. Getting started Here is how you use the icoBoard with a RaspberryPi: http://icoboard.org/get-started-with-your-icoboard-anda-raspi.html Optional Accessories Peripherie Module von Digilent Pmod is Digilent’s name for the line of over 60 peripheral modules that we offer to add extra functionality to both microcontrollers and FPGAs (field-programmable gate array). This functionality includes audio amplifiers, GPS receivers, USB to UART interface, seven-segment displays, accelerometers, H-bridges with input feedback, analog-to-digital converters, and much more. Package Content 1 x icoBoard Version 1.1 with 8 MBit SRAM                                         https://shop.trenz‐electronic.de/en/TE0887‐02M‐icoBoard‐Version‐1.1‐with‐8‐MBit‐SRAM?path=Trenz_Electronic/TE0887/REV02/Documents4‐21‐2017
TE0887-02M
物料型号:TE0887-02M
器件简介:iCoBoard包含一个Lattice FPGA,具有8k LUT、100 MHz最大时钟频率和8 MBit的SRAM,可通过完整的开源FPGA工具链用Verilog编程。
引脚分配:iCoBoard与RaspberryPi 2B及所有更新版本以及使用相同引脚布局的任何板兼容。
参数特性: - Lattice ICE40HX8k FPGA - 支持开源工具链icoTC,包括Yosys、ArachnePnR、icestorm - 4个PMod连接器,具有未缓冲的3.3V接口 - 4个16针100mil I/O连接器 - 4个扁平柔性连接器,每个具有36条3.3V I/O线 - 16位宽8MBit SRAM - 16MByte SPI Flash存储器,可存储4个位流或数据 - 3个可编程状态LED(绿色) - 2个按钮
功能详解:iCoBoard是学习Verilog逻辑电路设计的完美工具,无需使用Xilinx或Altera的专业大型编程工具。PMod连接器使得与各种传感器和接口的配合变得非常容易。
应用信息:iCoBoard可用于教授学生Verilog,教授可以更容易地直接分发开源工具链,而不是要求学生注册制造商以获取学生许可证并安装数GB的软件。
封装信息:如果iCoBoard连接到RaspberryPi,电源由RaspberryPi提供。如果iCoBoard独立操作,需要向电源引脚提供5V电源。
附加信息:文档还提供了用于RaspberryPi的microSD卡镜像下载链接,其中包含所有工具,以及如何使用iCoBoard与RaspberryPi的入门指南链接。
TE0887-02M 价格&库存
很抱歉,暂时无法提供与“TE0887-02M”相匹配的价格&库存,您可以联系我们找货
