TEBT0782-01
TEBT0782-01
    TRENZELECTRONIC
    TE0782 TE0783 TE0784 Zynq-7000 AP SoC 载板 TE0782,TE0783,TE0784 Zynq®-7000 FPGA 评估板
TEBT0782-01 数据手册
    Test Fixture for Trenz Electronic TE0782 SoC  Order number: TEBT0782-01 Product information "Test Fixture for Trenz Electronic TE0782 SoC" Test Fixture for TE0782. Most Board to Board IO pins looped back for simple I/O test. Module bottom side is accessible for measurements. Features            3 x Samtec ASP-122953-01 160-pin stacking compatible to TE0782 2 mm MC LB2-A solder-in and TE1.5/2-3.5H plug connectors for power supply (12V Input) 4 SMA connectors for MGT (1xTX 1xRX) 2 x 12 Pin Header for XMOD 1 x DIP-switch for Module CPLD Access 2 x RJ45 connector 1 x USB A connector (2 stacked) Assembled with two XMOD FTDI JTAG Adapter, TE0790 and TE0790-xxL (compatible with/independent from Xilinx tools) Power regulators for 5V and 3.3V Size 115 x 115 mm Two pre-assembled TE0790 XMOD FTDI JTAG adapters Package Content  1 x Test Fixture für TE0782 Additional Information    Manufacturer's article number: TEBT0782-01 Trenz Electronic TE0782 Wiki Support Forum All modules produced by Trenz Electronic are developed and manufactured in Germany.         https://shop.trenz‐electronic.de/en/TEBT0782‐01‐Test‐Fixture‐for‐Trenz‐Electronic‐TE0782‐SoC?path=Trenz_Electronic/Modules_and_Module_Carriers/8.5x8.5/8.5x8.5_Carriers/TEBT0782/REV01/Documents 4‐12‐18
TEBT0782-01
- 物料型号: TEBT0782-01 - 器件简介: 测试夹具适用于TE0782,大多数板对板I/O引脚循环测试,模块底部可进行测量。 - 引脚分配: 3个Samtec ASP-122953-01 160针堆叠兼容TE0782,2毫米MC LB2-A焊接和TE1.5/2-3.5H插头连接器用于电源供应(12V输入),4个SMA连接器用于MGT(1xTX 1xRX),2个12针头用于XMOD,1个DIP开关用于模块CPLD访问,2个RJ45连接器,1个USB A连接器(2个堆叠)。 - 参数特性: 包括5V和3.3V的电源调节器,尺寸为115 x 115毫米。 - 功能详解: 组装了两个XMOD FTDI JTAG适配器TE0790和TE0790-xxL(与Xilinx工具兼容/独立)。 - 应用信息: 用于Trenz Electronic TE0782模块的测试。 - 封装信息: 包括1个TE0782测试夹具。
TEBT0782-01 价格&库存
很抱歉,暂时无法提供与“TEBT0782-01”相匹配的价格&库存,您可以联系我们找货
