DY075-7
DY075-7
    TRI-MAG
    开放框架 AC DC 转换器 2 输出 12V 5V 90 ~ 264 VAC 输入
DY075-7 数据手册
1601 N. CLANCY CT. • VISALIA, CA 93291 (559) 651-2222 • FAX (559) 651-0188 http://www.tri-mag.com sales@tri-mag.com DY075 SERIES 75Watts For Medical & Industrial Applications 120 Watts Peak Current Low Cost DESCRIPTION DY075 series is a universal input multiple output power supply. The series is a 75 watts power supply in the size of 3”x 5” with a wattage density of 3.9W/in3. The efficiency can reach up to 75-87% depending on model. GENERAL SPECIFICATIONS Input Voltage………………...…... 90VAC to 264VAC Input Frequency……………………….. 47Hz to 63Hz Inrush Current (cold)…………...…… Less than 30A at 115VAC, 25°C Operating Temperature……………..……….. 0 to 70ºC de-rated 2.5%/°C >50°C Storage Temperature……………………-20°C to 85°C Cooling………………………….. Free Air Convection Efficiency……………………………..…...75% to 87% Holdup Time……………………….>20ms at 115VAC Overvoltage Type…….………………….… Latch Off Overload Protection……...…………….. Auto recovery Short Circuit Protection…………………Auto recovery Earth Leakage…………...…...300μA Max @ 240VAC Designed in full compliance with UL 60950, UL2601-1 CSA 22.2 #601-1,#234 EN60601-1 EMI ……….…………….EN55022 “B”, EN55011 “B” FCC docket class “B” EMS…………………...EN61000-4-2,-3,-4,-5,-6,-8,-11 Harmonics…………………...… EN61000-3-2 Class A MECHANICAL SPECIFICATIONS FEATURES x x x x x x EMI FCC Class B No Minimum Load Required Single and Multiple Output Universal input 90VAC to 264VAC Low Leakage Current Double Fused APPLICATIONS x x x x x x Computer Peripherals Telecommunications Tape Drives Test Instrumentation Product Data Acquisition Medical & Dental Connector: TB1—AC input : Molex 5277-02A or equivalent TB2—DC output : Molex 5273-08A or equivalent TB3 for LED use : Molex 5045-02A or equivalent TB4 for Remote sense : Molex 5045-02A or equivalent Size: 76.2mm X 127mm X 30mm, 3” X 5” X 1.18” Mounting Holes: 64.8mm X 115.6mm, 2.55” X 4.55” All specifications and prices subject to change without notice 1601 N. CLANCY CT. • VISALIA, CA 93291 (559) 651-2222 • FAX (559) 651-0188 http://www.tri-mag.com sales@tri-mag.com OUTPUT SPECIFICATIONS Model Watts DY075-6 75 DY075-7 75 DY075-8 75 DY075-9 75 DY075-3 75 DY075-1 75 DY075-19 75 DY075-14 DY075-18 75 50 Load (A) Voltage (Vdc) Min. Rate +5V +12V +5V +15V +5V +24V +5V +5V +12V +5V +12V -12V +3.3V +5V +12V -12V +48V +3.3V 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 14 5.6 0.5 4.8 0.5 3.0 0.5 3.5 4.0 3.5 3.5 0.3 6.0 4.0 2.0 0.6 1.6 15 Regulation Tolerance ± Peak Ripple & Noise Line Load 9.0 8.0 5.0 5.0 9.0 5.0 9.0 10.0 7.0 - 100 mV 100 mV 50 mV 100 mV 50 mV 200 mV 50 mV 50 mV 100 mV 50 mV 100 mV 100 mV 50 mV 50 mV 120 mV 120 mV 300 mV 50 mV 1.0% 1.0% 1.0% 1.0% 1.0% 1.0% 1.0% 1.0% 1.0% 1.0% 1.0% 1.0% 1.0% 1.0% 1.0% 1.0% 1.0% 1.0% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±3% ±3% ±3% ±3% ±5% ±3% ±3% ±5% ±5% ±1% ±1% 1% 1% 5% 1% 5% 1% 5% 1% 5% 1% 5% 5% 3% 5% 5% 1% 1% 1% Note: Contact factory for Safety Agency Approved status. 1. 2. 3. 4. 5. Each output can provide up to peak load temporarily. Continuous staying in more than rated load is not allowed. At factory, in 60% rated load condition, each output is checked to be within voltage accuracy. Line regulation is defined by changing ±10% of input voltage from nominal line at rated load. Load regulation is defined by changing ±40% of measured ouput load from 60% rated load. The ripple and noise is measured by using 15MHz bandwidth limited oscilloscope and terminated each output with a 0.47 μF capacitor at rated load and nominal line. ENCLOSURES (optional) ECS EUS Our Standard power supplies, the DY075 Series, can be installed into a fully enclosed chassis or in a ‘U’ shape chassis as an option. These options offer two mounting planes to choose from. The fully enclosed option help to reduce radiated noise. Example Part Number: DY075-9ECS or DY075-9EUS *Note DY040 pictured in chassis All specifications and prices subject to change without notice 1601 N. CLANCY CT. • VISALIA, CA 93291 (559) 651-2222 • FAX (559) 651-0188 http://www.tri-mag.com sales@tri-mag.com DY075 SERIES 75 WATT— PIN ASSIGNMENT Pin Model DY075-6 DY075-7 DY075-8 DY075-9 DY075-3 DY075-1 DY075-19 DY075-14 DY075-18 1 2 3 4 5 6 7 8 +5V +12V +15V +24V +5V +5V +3.3V +48V +3.3V +5V +12V +15V +24V +5V +5V +3.3V +48V +3.3V +5V +12V +15V +24V COM COM COM +48V +3.3V +5V COM COM COM COM COM COM COM +3.3V COM COM COM COM COM +12V +5V COM COM COM COM COM COM COM +12V +5V COM COM COM COM COM COM +12V -12V -12V COM COM COM +5V +5V +5V +12V N/C +12V +5V COM All specifications and prices subject to change without notice
DY075-7 价格&库存
很抱歉,暂时无法提供与“DY075-7”相匹配的价格&库存,您可以联系我们找货
