GR EEN POW ER
Power Supplies
ICM48 / ICM60 Series
48W / 65W International Adapters
DOE Level VI Efficiency Rating
Universal Input: 90 ~ 264Vac, 47/63 Hz
UL/cUL Safety Approved
Corded DC Output Connector
US, UK, AU & EU AC adapters available
Light Weight and Compact
Min
Rated
Peak
Voltage
Accuracy
Ripple
Noise
Line
Reg.
Load
Reg.
ITE
+9.0V
±5%
< ± 1%
± 1%
± 5%
ICM48-120
ITE
+12.0V
±5%
< ± 1%
± 1%
± 5%
ICM48-180
ITE
+18.0V
±5%
< ± 1%
± 1%
± 5%
ICM48-240
ITE
+24.0V
±5%
< ± 1%
± 1%
± 5%
ICM48-360
ITE
+36.0V
±5%
< ± 1%
± 1%
± 5%
ICM48-480
ITE
+48.0V
±5%
< ± 1%
± 1%
± 5%
ICM60-090
ITE
+9.0V
±5%
< ± 1%
± 1%
± 5%
ICM60-120
ITE
+12.0V
±5%
< ± 1%
± 1%
± 5%
ICM60-180
ITE
+18.0V
±5%
< ± 1%
± 1%
± 5%
ICM60-240
ITE
+24.0V
±5%
< ± 1%
± 1%
± 5%
L6R60-360
ITE
+36.0V
±5%
< ± 1%
± 1%
± 5%
L6R60-480
ITE
+48.0V
±5%
< ± 1%
± 1%
± 5%
Application
ICM48-090
Output
Connector
Output Current
Output
Voltage
Model No.
2.1mm I.D. x
5.5mm O.D. x
9.5mm Barrel
Output voltages from 5.0Vdc to 48.0Vdc are available in increments of 0.1V. Please contact Tri-Mag, LLC for the part number and specifications for your output voltage
requirement and application. Output voltages from 6.0V to 8.9V do not meet Level VI efficiency requirements and are subject to associated importation regulations.
The output voltage is verified to specs at 60 percent rated load condition.
The line regulation is defined by changing ± 10 percent of input voltage from the nominal line at rated load.
The load regulation is defined by changing ± 40 percent of the measured output load from 60 percent of the rated load.
The ripple and noise is measured by using 20MHz bandwidth limited oscilloscope with each output terminated with a 10 µF electrolytic and a 0.1 µF capacitor at rated load
and nominal line.
The efficiency is measured at rated load and nominal line.
1601 N. Clancy Ct. • Visalia, CA 93291 • (559) 651-2222 • FAX (559) 651-0188 • sales@tri-mag.com • tri-mag.com
Power Supplies
Economical and dependable international adapter
whether powering stationary or portable devices.
choose from: 5.0Vdc to 48.0Vdc (in increments of
0.1V), to match your specific need.
This DOE Level VI compliant power supply/adapter
is rated up to 65W, with plenty of voltage levels to
Call us (800-657-0853) for the part number to match
your particular need.
Specifications
Input
Input Voltage
Input Frequency
No Load Input Power
Input Current
Inrush Current
Leakage Current
Input Connection
Dimensions and Notes
90 Vac ~ 264 Vac
47 Hz to 63 Hz
< 0.1W
1.2A Max.
40A Max.
0.25mA Max.
US (others available)
Output Voltage Range
Output Current Range
Minimum Load
Line Regulation
Load Regulation
Ripple & Noise
Overvoltage Protection
Overload Protection
Short Circuit Protection
5.0 to 48.0 Vdc
L6R48: 5.3 - 1.3 A, 48W Max.
L6R60: 6.0 - 1.6A, 65W Max.
No min. load required.
± 1% at rated load across input
voltage range
± 5%
< 1%, 240mVp-p Max.
Auto recovery
Auto recovery
Auto recovery
Dimensions in mm
Tolerance
Size
Weight
Connectors
Output
Cord length
± 0.2mm
117.3 x 54.5 x 41.2 mm
4.62 x 2.15 x 1.62 Inches
Approx. 200g (7.0oz.)
AC input, US, UK, AU and EU
adapters available
• DC output, standard 2.1mm x 5.5mm x
9.5mm corded dc barrel connector or per
customer specification.
• 1000 ± 20 mm (39.3 ± .8”)
Mechanical Drawing
General
Insulation Resistance
Efficiency
MTBF
• 50MΩ Min.
• Level VI compliant
• 50,000 hrs to MIL-HDBK-217F at +25°C
Environmental
Operating Temperature
Operating Humidity
Storage Temperature
• 0°C to 40°C
• 5% - 95% RH, Non-Condensing
• -20°C to +80°C
EMC & Safety
Safety Approvals
EMC Approvals
• UL: UL60950-1
• cUL: UL60950-1
• FCC
Warranty
Warranty Period
• 3 years
888991000 888992000 888993000 888994000
Four-adapter set: 888990000
2019-09
很抱歉,暂时无法提供与“ICM60-090”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+200.293631+25.69994
- 5+184.156985+23.62943
- 10+177.6217910+22.79089
- 25+169.3434725+21.72869
- 50+163.3378450+20.95810
- 100+157.54369100+20.21464
- 250+150.19992250+19.27235
- 500+144.87252500+18.58879
