ICM60-300
ICM60-300
    TRI-MAG
    30V AC/DC 外部 壁装(II 类) 适配器 固定插片,多插片(单独出售) 输入
ICM60-300 数据手册
GR EEN POW ER Power Supplies ICM48 / ICM60 Series 48W / 65W International Adapters • DOE Level VI Efficiency Rating • Universal Input: 90 ~ 264Vac, 47/63 Hz • UL/cUL Safety Approved • Corded DC Output Connector • US, UK, AU & EU AC adapters available • Light Weight and Compact Min Rated Peak Voltage Accuracy Ripple Noise Line Reg. Load Reg. ITE +9.0V 0 5.3 — ±5% < ± 1% ± 1% ± 5% ICM48-120 ITE +12.0V 0 4.0 — ±5% < ± 1% ± 1% ± 5% ICM48-180 ITE +18.0V 0 2.7 — ±5% < ± 1% ± 1% ± 5% ICM48-240 ITE +24.0V 0 2.0 — ±5% < ± 1% ± 1% ± 5% ICM48-360 ITE +36.0V 0 1.3 — ±5% < ± 1% ± 1% ± 5% ICM48-480 ITE +48.0V 0 1.0 — ±5% < ± 1% ± 1% ± 5% ICM60-090 ITE +9.0V 0 6.0 — ±5% < ± 1% ± 1% ± 5% ICM60-120 ITE +12.0V 0 5.0 — ±5% < ± 1% ± 1% ± 5% ICM60-180 ITE +18.0V 0 3.3 — ±5% < ± 1% ± 1% ± 5% ICM60-240 ITE +24.0V 0 2.5 — ±5% < ± 1% ± 1% ± 5% L6R60-360 ITE +36.0V 0 1.8 — ±5% < ± 1% ± 1% ± 5% L6R60-480 ITE +48.0V 0 1.3 — ±5% < ± 1% ± 1% ± 5% Application ICM48-090 • • • • • • Output Connector Output Current Output Voltage Model No. 2.1mm I.D. x 5.5mm O.D. x 9.5mm Barrel Output voltages from 5.0Vdc to 48.0Vdc are available in increments of 0.1V. Please contact Tri-Mag, LLC for the part number and specifications for your output voltage requirement and application. Output voltages from 6.0V to 8.9V do not meet Level VI efficiency requirements and are subject to associated importation regulations. The output voltage is verified to specs at 60 percent rated load condition. The line regulation is defined by changing ± 10 percent of input voltage from the nominal line at rated load. The load regulation is defined by changing ± 40 percent of the measured output load from 60 percent of the rated load. The ripple and noise is measured by using 20MHz bandwidth limited oscilloscope with each output terminated with a 10 µF electrolytic and a 0.1 µF capacitor at rated load and nominal line. The efficiency is measured at rated load and nominal line. 1601 N. Clancy Ct. • Visalia, CA 93291 • (559) 651-2222 • FAX (559) 651-0188 • sales@tri-mag.com • tri-mag.com Power Supplies ICM48 / ICM60 Series Economical and dependable international adapter whether powering stationary or portable devices. choose from: 5.0Vdc to 48.0Vdc (in increments of 0.1V), to match your specific need. This DOE Level VI compliant power supply/adapter is rated up to 65W, with plenty of voltage levels to Call us (800-657-0853) for the part number to match your particular need. Specifications Input Input Voltage Input Frequency No Load Input Power Input Current Inrush Current Leakage Current Input Connection Dimensions and Notes • • • • • • • 90 Vac ~ 264 Vac 47 Hz to 63 Hz < 0.1W 1.2A Max. 40A Max. 0.25mA Max. US (others available) Output Voltage Range Output Current Range Minimum Load Line Regulation • • • • • Load Regulation Ripple & Noise Overvoltage Protection Overload Protection Short Circuit Protection • • • • • 5.0 to 48.0 Vdc L6R48: 5.3 - 1.3 A, 48W Max. L6R60: 6.0 - 1.6A, 65W Max. No min. load required. ± 1% at rated load across input voltage range ± 5% < 1%, 240mVp-p Max. Auto recovery Auto recovery Auto recovery Dimensions in mm Tolerance Size Weight Connectors Output Cord length • • • • • ± 0.2mm 117.3 x 54.5 x 41.2 mm 4.62 x 2.15 x 1.62 Inches Approx. 200g (7.0oz.) AC input, US, UK, AU and EU adapters available • DC output, standard 2.1mm x 5.5mm x 9.5mm corded dc barrel connector or per customer specification. • 1000 ± 20 mm (39.3 ± .8”) Mechanical Drawing General Insulation Resistance Efficiency MTBF • 50MΩ Min. • Level VI compliant • 50,000 hrs to MIL-HDBK-217F at +25°C Environmental Operating Temperature Operating Humidity Storage Temperature • 0°C to 40°C • 5% - 95% RH, Non-Condensing • -20°C to +80°C EMC & Safety Safety Approvals EMC Approvals • UL: UL60950-1 • cUL: UL60950-1 • FCC Warranty Warranty Period • 3 years 888991000 888992000 888993000 888994000 Four-adapter set: 888990000 2019-09 1601 N. Clancy Ct. • Visalia, CA 93291 • (559) 651-2222 • FAX (559) 651-0188 • sales@tri-mag.com • tri-mag.com
ICM60-300 价格&库存
很抱歉,暂时无法提供与“ICM60-300”相匹配的价格&库存,您可以联系我们找货
ICM60-300
  • 1+217.392911+28.12558
  • 5+199.867425+25.85819
  • 10+192.7889110+24.94240
  • 25+183.7999025+23.77943
  • 50+177.2804650+22.93596
  • 100+170.99167100+22.12234
  • 250+163.02111250+21.09114
  • 500+157.23903500+20.34307
库存:248
