L6R90D-480-C14
L6R90D-480-C14
    TRI-MAG
    48V 90 W AC/DC 外部 台式(类 I) 适配器 缆线(单独出售) 输入
L6R90D-480-C14 数据手册
GR EEN POW ER Power Supplies L6R90D Series 90W Desktop Power Supply • DOE Level VI Efficiency Rating • Universal Input: 90 ~ 264Vac, 47/63 Hz • UL/cUL/IEC 62368-1 Approved • Corded Output Connection • IEC 60320 C6 and C14 AC input connectors • Light Weight and Compact Peak Voltage Accuracy Ripple Noise Line Reg. Load Reg. Min Rated ITE +12.0V 0 7.00 — ±5% < ± 2% ± 1% ± 5% L6R90D-150 ITE +15.0V 0 6.00 — ±5% < ± 2% ± 1% ± 5% L6R90D-160 ITE +16.0V 0 5.63 — ±5% < ± 2% ± 1% ± 5% L6R90D-180 ITE +18.0V 0 5.00 — ±5% < ± 2% ± 1% ± 5% L6R90D-190 ITE +19.0V 0 4.74 — ±5% < ± 2% ± 1% ± 5% L6R90D-200 ITE +20.0V 0 4.50 — ±5% < ± 2% ± 1% ± 5% L6R90D-240 ITE +24.0V 0 3.75 — ±5% < ± 2% ± 1% ± 5% L6R90D-300 ITE +30.0V 0 3.00 — ±5% < ± 2% ± 1% ± 5% L6R90D-480 ITE +48.0V 0 1.88 — ±5% < ± 2% ± 1% ± 5% L6R90D-560 ITE +56.0V 0 1.60 — ±5% < ± 2% ± 1% ± 5% Application L6R90D-120 Output Connector Output Current (A) Output Voltage Model No.1 2.5mm I.D. x 5.5mm O.D. x 9.5mm Barrel 1. Add “C6” or “C14” for the required AC input connector configuration. • • • • • The output voltage is verified to specs at 60 percent rated load condition. The line regulation is defined by changing ± 10 percent of input voltage from the nominal line at rated load. The load regulation is defined by changing ± 40 percent of the measured output load from 60 percent of the rated load. The ripple and noise is measured by using 20MHz bandwidth limited oscilloscope with each output terminated with a 10 µF electrolytic and a 0.1 µF capacitor at rated load and nominal line. The efficiency is measured at rated load and nominal line. 1601 N. Clancy Ct. • Visalia, CA 93291 • (559) 651-2222 • FAX (559) 651-0188 • sales@tri-mag.com • tri-mag.com Power Supplies L6R90D Series Innovative, reliable, and inexpensive. This 12.0 to 56.0Vdc (per the model number table) to economical DOE Level VI compliant power supply/ match your needs. Rated up to 90W when powering charger is available in a variety of voltage levels, either stationary or charging portable devices. Specifications Input Input Voltage Input Frequency No Load Input Power Input Current Inrush Current Leakage Current Input Connection Environmental • • • • • • • 90 Vac ~ 264 Vac 47 Hz to 63 Hz < 0.21W 1.2A Max. 60A Max. / 230Vac 3.5mA Max. IEC 60320 C6 or C14 Output Voltage Range Output Current Range Minimum Load Line Regulation • • • • Load Regulation Ripple & Noise Overvoltage Protection Overload Protection Short Circuit Protection • • • • • 12.0 to 56.0Vdc 1.6 to 7.0A No min. load required. ± 1% at rated load across input voltage range ± 5% (typical) 2% Vp-p Max. @ full load Auto recovery Auto recovery Auto recovery Output General Dielectric Withstand Efficiency MTBF • 3,000Vac Primary to Secondary • Level VI, ErP Stage 2, CoC Tier 2 compliant • 300,000 hrs. @ 25ºC per Telcordia SR-332 Operating Temperature Operating Humidity Storage Temperature Storage Humidity • • • • 0°C to 40°C 20 to 80% RH, Non-Condensing -20°C to +80°C 10 to 90%, Non-Condensing EMC & Safety Safety Approvals EMC Approvals • UL/cUL: UL/cUL 62368-1, 60950-1 • CE: IEC 62368-1, 60950-1 • FCC Warranty Warranty Period • 1 year Dimensions and Notes Dimensions in mm Tolerance • ± 0.2mm Size • C6: L 139 x W 61 x H 36 (mm) L 5.5” x W 2.4” x H 1.4” • C14: L 151 x W 64 x H 36 (mm) L 5.9” x W 2.5” x H 1.4” Weight • Approx. 460g (1.0 lb.) Connectors • AC input; IEC 60320 C6 or C14 connector • DC output; Standard 2.5mm x 5.5mm x 9.5mm barrel connector or per customer specification. Output Cord length • 1500 ±30 mm (59 ±1.2”) Mechanical Drawing 2020-12 1601 N. Clancy Ct. • Visalia, CA 93291 • (559) 651-2222 • FAX (559) 651-0188 • sales@tri-mag.com • tri-mag.com
L6R90D-480-C14 价格&库存
很抱歉,暂时无法提供与“L6R90D-480-C14”相匹配的价格&库存,您可以联系我们找货
