Type 153 Series
Manual Reset Circuit Breaker
Automotive Type III
High Current - Waterproof
Specifications:
Voltage: 42 VDC Maximum (32VDC – CURUS approved)
Amperage: 25A, 30A, 40A, 50A, 60A, 70A, 80A, 90A, 100A,
120A, 135A, 140A, 150A, 180A, 200A
Interrupting Rating: 3000A @ 30VDC
IP Rating: IP67
Material:
Frame: Thermoset Plastic, UL rated 94-V0
Stud Insulators: EPDM plastic
Mounting Torque: 40in-lb Max.
Stud Torque: 50in-lb Max.
ABYCE-11 compliant
Operating Temperature: -32° C ~ +92° C
Designed to meet: SAE J162S; SAE J1171 (Ignition Protected)
www.optifuse.com
(619) 593-5050
Part number format
153xxx
Where xxx = Amperage
025 through 200
Agency Standards and Listings:
50A – 150A @ 32VDC
Mechanical Dimensions: Inches [mm]
Note: All specifications subject to change without notice.
Rev F 04/2018 - Page: 1/2
Code B01-01H
Type 153 Series
Automotive Type III
www.optifuse.com
(619) 593-5050
Time Characteristics:
% of Rated Min Hold Max Hold
Current
Time
Time
100%
135%
200%
300%
Warning:
No Trip
12s
3.5s
30m
45s
15s
-Operation beyond the specified maximum ratings or improper use may result in damage and possible
electrical arcing and/or flame.
-Device are intended for occasional overcurrent protection. Application for repeated overcurrent condition
and/or prolonged trip are not anticipated.
-Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance.
Rev F 04/2018 - Page: 2/2
Code B01-01H
很抱歉,暂时无法提供与“153180”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+442.161591+57.37010
- 10+394.7840210+51.22290
