ACBP4-PML-30A
ACBP4-PML-30A
    OPTIFUSE
    MINI FUSE FOOTPR. CB-TYPE I, 30A
ACBP4-PML-30A 数据手册
Type ACBP4-PML Auto Reset Circuit Breaker Automotive Type I Standard Mini Blade - Extended Body Specifications: Mini Blade Automatic Reset Type Circuit Breaker Voltage: 14VDC Amperage: 5A, 7.5A, 10A, 15A, 20A, 25A, 30A Materials: Thermoplastic – (UL Rated 94-V-0) Terminals: Tin plated Copper Alloy Testing Standard: SAE J553 Type I Cover is color coded to Amperage Ratings Operating Temperature: -40º C ~ 85º C Interrupt Rating 150A @ 14 VDC 225A @ 14 VDC 300A @ 14 VDC 450A @ 14 VDC Part Number ACBP4-PML-5A ACBP4-PML-7.5A ACBP4-PML-10A ACBP4-PML-15A ACBP4-PML-20A ACBP4-PML-25A ACBP4-PML-30A www.optifuse.com (619) 593-5050 Part number: ACBP4-PML Time Current Curves (5A-10A) (15A) (20A) (25A-30A) Amperage Body Color 5A Tan 7.5A Brown 10A Red 15A Blue 20A Yellow 25A White 30A Green Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Device are intended for occasional overcurrent protection. Application for repeated overcurrent condition and/or prolonged trip are not anticipated. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev A 10/2014 - Page: 1/1 Code B01-01H
ACBP4-PML-30A 价格&库存
很抱歉,暂时无法提供与“ACBP4-PML-30A”相匹配的价格&库存,您可以联系我们找货
