ANK58-5A
ANK58-5A
    OPTIFUSE
    Blade,Micro
    FUSE AUTO 5A 58VDC BLADE MICRO
ANK58-5A 数据手册
Type ANK58 Automotive Blade Fuse 3 Terminal (Micro3) www.optifuse.com Specifications: · Voltage: 58V DC · Amperage: 5A, 7.5A, 10A, 15A, 20A · Body Material: Nylon with 25% Fiberglass · Cover Material: Nylon with 25% Fiberglass, Blue · Metal Material: Copper Alloy, gal Sn · Element: Zinc Alloy, Sn plated · Interrupting Rating: 1000A @ 58 VDC Time Characteristics: % of Rated Current Min Hold Time Max Hold Time 110% 135% 200% 350% 600% 100h 750ms 150ms 40ms 10ms 1800s 30s 500ms 100ms Part Number ANK58-5A ANK58-7.5A ANK58-10A ANK58-15A ANK58-20A (619) 593-5050 Amperage 5A 7.5A 10A 15A 20A Body Color Tan Brown Red Blue Yellow Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev A 06/2018 - Page: 1/1 Code G02-01H
ANK58-5A 价格&库存
很抱歉,暂时无法提供与“ANK58-5A”相匹配的价格&库存,您可以联系我们找货
