ANM-I-25A
ANM-I-25A
    OPTIFUSE
    Blade,Miniature
    FUSE AUTO 25A 32VDC BLADE MINI
ANM-I-25A 数据手册
Type ANM-I Automotive Blade Fuse Miniature – LED Indicating www.optifuse.com Specifications: · Voltage: 32VDC · Amperage: 2A, 3A, 4A, 5A, 7.5A, 10A, 15A, 20A, 25A, 30A · Body: PA 66 · Indicating LED when fuse is opened · Terminals: Zinc alloy · Designed to meet SAE and ISO 8820 Standards. · Interrupt Rating – 1000A @ 32 VDC Time Characteristics: % of Rated Current Min Hold Time Max Hold Time 110% 135% 200% 100h ~ ~ ~ 1800s 5s Part Number ANM-I-2A ANM-I-3A ANM-I-4A ANM-I-5A ANM-I-7.5A ANM-I-10A ANM-I-15A ANM-I-20A ANM-I-25A ANM-I-30A (619) 593-5050 Amperage 2A 3A 4A 5A 7.5A 10A 15A 20A 25A 30A Body Color Gray Violet Pink Tan Brown Red Blue Yellow Clear Green Time Current Curve Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev A 06/2018 - Page: 1/1 Code H02-01H
ANM-I-25A 价格&库存
很抱歉,暂时无法提供与“ANM-I-25A”相匹配的价格&库存,您可以联系我们找货
