ANM58-25A
ANM58-25A
    OPTIFUSE
    Blade,Miniature
    FUSE AUTO 25A 58VDC BLADE MINI
ANM58-25A 数据手册
Type ANM58 Automotive Blade Fuse Miniature www.optifuse.com Specifications: · Voltage: 58VDC · Amperage: 500mA, 1A, 2A, 3A, 4A, 5A, 7.5A, 10A, 15A, 20A, 25A, 30A · Body: Nylon with 25% Fiberglass · Cover: Nylon with 25% Fiberglass, Blue · Terminals: Copper alloy, Tin plated · Interrupt Rating – 1000A @ 58 VDC Time Characteristics: % of Rated Current Min Hold Time Max Hold Time 110% 135% 200% 350% 600% 100h 750ms 150ms 40ms 20ms ~ 1800s 30s 500ms 100ms (619) 593-5050 Part Number Amperage ANM58-500mA ANM58-1A ANM58-2A ANM58-3A ANM58-4A ANM58-5A ANM58-7.5A ANM58-10A ANM58-15A ANM58-20A ANM58-25A ANM58-30A 500mA 1A 2A 3A 4A 5A 7.5A 10A 15A 20A 25A 30A Body Color Dark Blue Black Gray Violet Pink Tan Brown Red Blue Yellow Clear Green Mechanical Dimensions: Inches [mm] Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible electrical arcing and/or flame. -Avoid contact of device with chemical solvent. Prolonged contact will damage the device performance. Note: All specifications subject to change without notice. Rev A 06/2018 - Page: 1/1 Code G02-01H
ANM58-25A 价格&库存
很抱歉,暂时无法提供与“ANM58-25A”相匹配的价格&库存,您可以联系我们找货
